  Does flipping over the strut top mounting plate change the Fiero's rear height? (Page 2)
Does flipping over the strut top mounting plate change the Fiero's rear height? by Patrick
Started on: 11-21-2013 02:17 AM
Replies: 56 (3251 views)
Last post by: Spadesluck on 11-12-2023 06:11 PM
Total ratings: 259
Report this Post01-29-2022 09:25 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
When flipping the strut plate, the bottom surface of the bump stop moves up as well.
Does this create the potential for the tire to hit/rub the plastic wheel well liner, or perhaps other issues? 84-87 toe-link hitting the frame rail? My Fiero is covered in snow; can't look now.
Tire rubbing is largely dependent diameter and width of tire and offset of wheel. If the wheel/tire combo is close to stock, tires should not nub. Wider/taller tires likely will. This is less of an issue with the 88's as the 88 knuckle is taller (from wheel center), so you reach the end of strut travel with the wheel further from the underside
Tie tie rod link will likely interfere with the frame rail. On page 18 of Will's thread he cycles his 84-87 suspension to full compression w/o any springs or bump stops and the strut hat in stock orientation, the tire rod is about 1/8 from the frame. The flange and rail could be trimmed slightly for additional clearance.
pmbrunelle
Total ratings: 63
Report this Post01-29-2022 09:46 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's good info, thanks for finding it.
Flipping a KYB strut plate will move the strut rod up by ~1.050".
Probably with the right bumpstop the toe link can be kept far enough away from the frame rail notch.
I suppose that without a spring, if the rear of the car is jacked up via the knuckle (the entire rear end weight squishing one bumpstop) that would represent a worst-case bumpstop squish.
[This message has been edited by pmbrunelle (edited 01-29-2022).]
Total ratings: 259
Report this Post01-30-2022 09:30 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the sway bar disconnected (if you have one) and no spring, it is quite easy to cycle to the suspension to full compression. While it is there, you might as well put the trans in neutral and spin the wheels by hand to check for Tripot binding. As you maximize the limits of suspension travel, tripot clearance becomes more important to check. Especially if you like to lower the drivetrain as low as possible in the chassis.
wilberto
Report this Post01-30-2022 12:21 PM Click Here to See the Profile for wilbertoSend a Private Message to wilbertoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a complete new suspension on my 85 GT, rebodied as a 308. Bushings, rear struts, shocks and Eibach springs. I flipped the strut towers before installing new springs and it lowered my rear suspension about .5" I do have more travel as well, no bottoming out. The springs are what lowered it the most. I also installed 2" wheel spacers in front and 2 3/8" wheel spacers in the rear to give it the proper stance. I wasn't thinking about handling when I did the wheel spacers but...WOW. Unbelievable handling, like a rally car, Very tight and responsive.
Total ratings: 465
Report this Post01-30-2022 04:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by wilberto:
I flipped the strut towers before installing new springs and it lowered my rear suspension about .5"... The springs are what lowered it the most.
For clarification... it was just the new springs that lowered your suspension. Flipping over the top mounting plates played no part in lowering the suspension.
It's possible that using spacers of that thickness contributes to lowering the car as well, as the wheels being pushed out by that distance changes suspension geometry, leverage on the springs etc. Maybe fieroguru could comment on this.
[This message has been edited by Patrick (edited 01-30-2022).]
wilberto
Report this Post02-02-2022 08:43 AM Click Here to See the Profile for wilbertoSend a Private Message to wilbertoEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you read my post, I said I flipped the strut towers before installing the springs and it lowered the car by .5". I can't be more clear on that.
Total ratings: 237
Report this Post02-02-2022 09:27 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/.../000121-21.html#p817
Bump stop removed; measurements taken at metal-to-metal contact between the gland nut of the Koni strut and the dished washer underneath the strut top mount.
Tire pictured is 285/30-18 on a C5 Corvette 18x9.5 Conestoga (61mm offset) with a 1" spacer/adapter.
Flipping the top mount and installing a bump stop would result in a bit more wheel travel possible, but the tire would definitely rub the fender on large excursions.
jjd2296
Report this Post02-02-2022 12:18 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure if this was previously mentioned, but why not just install the tie rod end to the bottom of the knuckle rather than on the top to compensate for the additional height as a result of the kyb strut plate being upside-down?
[This message has been edited by jjd2296 (edited 02-02-2022).]
pmbrunelle
Total ratings: 63
Report this Post02-02-2022 01:11 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assuming I install the spring with the same preload (1/4") in both cases (standard/flipped), the coilover assembly will provide exactly the same compression/droop travel relative to the resting position.
So the main difference between standard/flipped would be a ~1" difference in ride height.
Standard:
Car CG a bit higher, less risk of rubbing things
Flipped:
Car CG a bit lower, more risk of rubbing things
Next spring/summer I will check which alternative I prefer by cycling the suspension with my tire of choice.
My main focus is to make my Fiero easy to drive / predictable, while not having the highest limits. If I lose a bit of grip because its CG is higher, I won't cry over that.
Total ratings: 237
Report this Post02-02-2022 01:41 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would require using a tapered reamer to cut the correct taper into the knuckle and would create large amounts of bump steer.
Total ratings: 237
Report this Post02-02-2022 01:47 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
Standard:
Flipped:
If you moved the lower perch to maintain pre-load, then yes, that would change ride height.
Without moving the lower perch, there's no change in ride height.
At the higher ride height, the Fiero suspension has a higher roll center. '88's actually like this. Lowering the car lowers the roll center more than the car is lowered, so even though the CG is lower, the roll moment ends up HIGHER due to longer lever arm from CG to roll center.
[This message has been edited by Will (edited 02-03-2022).]
Total ratings: 465
Report this Post02-02-2022 03:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I read your post. What exactly are you referring to... "strut towers"...? You and I might be using different terminology. What did you actually flip?
wilberto
Report this Post02-05-2022 03:45 PM Click Here to See the Profile for wilbertoSend a Private Message to wilbertoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just flipped the hats. I've read numerous articles on this subject...some people say it lowers the vehicle, some say it doesn't. I've got it where I want it so that's fine with me. We may be using different terminology for the same part, that can vary from manual to manual.
Total ratings: 465
Report this Post02-05-2022 10:17 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It doesn't.
I'm glad you got it where you want it, but it wasn't from flipping the hats.
Wilberto, the whole reason why I started this thread nine years ago was because of all the erroneous information that was floating around online about this simple mod. I felt there needed to be a thread at PFF where this was set straight once and for all. I have to admit I'm rather surprised that after all that's been posted in this thread, that there still appears to be some confusion. Several contributors to this thread, some much more knowledgeable than myself, have all agreed and stated quite clearly that flipping over the hats does not affect ride height at all. It is what it is.
87GT3800SC5SPD
Report this Post11-12-2023 05:21 PM Click Here to See the Profile for 87GT3800SC5SPDSend a Private Message to 87GT3800SC5SPDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't visited the forum since sometime before this discussion began in 2013. It is nice to return and see that these kind of discussions are still going on.
My Fiero has been lowered three times in the past 26 years of ownership. The last time, it received 2" drop spindles in the front, 4 OMG firm springs and adjustable coil overs in the rear.
The final adjustment, after ride height was determined, was to reverse the top hat in the rear for the purpose of slightly increasing rear suspension travel. That change required the previously mentioned, small modification in the vents that is hardly noticeable. When the ride is similar to a shifter cart, you appreciate an additional .5" in suspension travel.
I can also verify that occasionally, an unexpected dip in the road will cause tires to contact the fender well liners. Those rub marks help identify where the liners need to be modified.
Total ratings: 465
Report this Post11-12-2023 05:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome back... but aw man, another thread with missing images. I'll have to see if I can locate my missing images to re-post.
Spadesluck
Report this Post11-12-2023 06:11 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
On a stock height Fiero, I would say no unless you are jumping the car. Now, on a lowered car hitting the inner liner is always an issue depending on the ride height.
With my 87 lowered with coil overs in the back I never had an issues with toe or hitting liner. The front is another issue as there isn't as much tuck room.
