  Brake Master Cylinder squirting in reservoir
Brake Master Cylinder squirting in reservoir by Chris Merrick
Started on: 12-31-2013 04:06 PM
Replies: 6 (7234 views)
Last post by: theogre on 01-02-2014 09:29 AM
Chris Merrick
Report this Post12-31-2013 04:06 PM Click Here to See the Profile for Chris MerrickClick Here to visit Chris Merrick's HomePageSend a Private Message to Chris MerrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just bled the whole brake system, and the pedal still goes to the floor...
if I look in the reservoir on the master cylinder I see a little fountain of brake fluid bubbling up
[img]https://dl.dropboxusercontent.com/u/891782/IMG_2479.JPG[/img]
does this mean my master cylinder is shot ?? new seals in it ??
My gut feeling is this is not normal...
Blacktree
Total ratings: 350
Report this Post12-31-2013 04:18 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it's a geyser of brake fluid, and not air, then it's perfectly normal.
If your brake pedal still goes to the floor, then you have air in the system somewhere.
Dodgerunner
Total ratings: 323
Report this Post12-31-2013 06:51 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will get a squirt of fluid when the peddle first starts to move but should stop after the peddle travels a ways. Once the piston is past the fill hole it normally stops. But until that happens it spurts up in the reservoir.
Also if you have an old master and you have been pushing the peddle to the floor a lot you might have damaged the piston seals. It's often good to put a 2x4 or something under the peddle so it does not go all the way to the floor.
On an old master crud builds up in the piston bore and if you push the piston into the unused part it can possible damage the seals. Putting a board under the peddle helps to keep it out of the bad area.
This may or may not be the problem.
Total ratings: 291
Report this Post12-31-2013 07:09 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you pump the brake pedal and then the pedal gets hard that means there is air in the system.
If you stab the pedal quickly and then it is hard but if you press the pedal gently and then it just goes to the floor, that is an indication that the seals in the MC are bad.
If you look under the car and see a puddle of brake fluid that indicates a leak. (other than your MC fountain splashes)
+1 on the quick fountain at the start of the pedal travel. That is normal and is why you have to put the cover back on the MC when manually bleeding brakes. I have learned that lesson quite a number of times. Not sure why I have to keep on relearning it but I'll be in the middle of bleeding the brakes, will have just refilled the MC and will forget to put the cover back on. Then there is brake fluid splashed all over and I will have learned the lesson one more time.
Chris Merrick
Report this Post01-01-2014 12:55 PM Click Here to See the Profile for Chris MerrickClick Here to visit Chris Merrick's HomePageSend a Private Message to Chris MerrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the responses...
the fountain (not air bubbles) happens the whole pedal travel when you press slowly.... if you stab it... it squirts a very high and makes a mess. but its the whole travel, not just the beginnings...
and I can press it to the floor every time.
is there a seal kit only or should I replace the whole thing with a rebuilt one ??
thanks
Total ratings: 291
Report this Post01-02-2014 07:46 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the cost difference I would simply replace it.
$21.82
http://www.rockauto.com/cat...249152&parttype=1836
[This message has been edited by phonedawgz (edited 01-02-2014).]
Report this Post01-02-2014 09:29 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
DIY rebuild MC is not recommended.
See my Cave, Brake Service covers that and more.
