  4T65E or HD
4T65E or HD by TbirdMarc
Started on: 01-08-2014 12:39 PM
Replies: 8 (965 views)
Last post by: katatak on 01-09-2014 08:33 PM
TbirdMarc
Report this Post01-08-2014 12:39 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am trying to find out what tranny I have connected to my 3800 SC engine. The Donor car was a 97 Park ave ultra with 30k on it. I got the engine, tranny and harness but no axles. I looked at these two threads:
https://www.fiero.nl/forum/Forum2/HTML/123686.html
https://www.fiero.nl/forum/Forum2/HTML/127100.html
and I tried searching on the web but I can't find what I need. I have located the casting numbers on the tranny but I cant seem to find the data plate. I don't have access to the car either to get the codes from the option list. I guess my question is this:
Assuming the drivetrain is original to the 97 Park Ave Ultra, did this year and model only come with th HD version of this trans, or was the HD introduced in later years?
[This message has been edited by TbirdMarc (edited 01-08-2014).]
Lou6t4gto
Report this Post01-08-2014 01:17 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
easiest way, if you don't have the ID Tag, is: Try to slip one of your Fiero AXLES into the passenger side. If it "Fits", it's a reg 6t65, if the Fiero axle is Too Small to fit, the Trans is a HD. The only difference is the "differential carrier" (Mostly the passenger side AXLE Stub.) I'm in the process of rebuilding a HD trans right now.
TbirdMarc
Report this Post01-08-2014 01:31 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks but sadly I don't have any loose axles laying around at this time... Where exactly is the tag? Is it visible with the trans attached to engine?
revin
Total ratings: 234
Report this Post01-08-2014 01:35 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
HD= passenger side is beefy.
Sorry that is all I got at work.
Darth Fiero
Total ratings: 361
Report this Post01-08-2014 03:22 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rear of the transmission near where the differential housing bolts on. Here's a picture of one:
-ryan
OVERKILL IS UNDERRATED
TbirdMarc
Report this Post01-08-2014 06:34 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies. I see the area where the tag is supposed to be but it is missing. I measured the splined shaft coming out of the drivers side and it's about an inch across. The splined hole in the passenger side is about 1 and 1/4 inches. Does this mean it's an HD?
Lou6t4gto
Report this Post01-08-2014 10:25 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the HD pass side axle IS about 1 1/4" reg is about an inch.
dratts
Total ratings: 118
Report this Post01-09-2014 03:00 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did 3800scs come with anything other than the HD?
katatak
Total ratings: 82
Report this Post01-09-2014 08:33 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4T65E-HD (code MN7) is a heavy duty version of the 4T65-E used with more powerful engines such as the LS4 V8 and L67/L32 supercharged V6.
Applications:
2.93:1 MN7 Oldsmobile 88 LSS L67
Pontiac Bonneville SSEi L67
Chevrolet Impala L67
Chevrolet Monte Carlo L67
Pontiac Grand Prix GTP/GXP
Buick Regal GS
Buick Riviera L67 (97-99)
3.05:1 MN7 Buick Park Avenue Ultra
3.06:1 MN7 Chevrolet Impala SS
Chevrolet Monte Carlo SS (2006-2007)
3.29:1 MN7 Buick LaCrosse Super
Pontiac Grand Prix GTP Comp G
