  Fuel pump connector wiring diagram
Fuel pump connector wiring diagram by Csjag
Started on: 01-12-2014 03:27 PM
Replies: 10 (2010 views)
Last post by: ChapsDp on 09-23-2024 01:00 AM
Csjag
Report this Post01-12-2014 03:27 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my 85 2M4 2.5L I think I reversed the polarity of the fuel pump when I changed it and as a result its running backward. I want to reverse the wires at the plug connector in the engine compartment so I don't have to drop the tank again. The connector has 3 wires, 1 black, 1 red and 1 brown with a white stripe. Can anyone tell me which wires to cross to reverse the polarity so the pump will run in the correct direction? Thanks
Total ratings: 291
Report this Post01-12-2014 04:12 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't be done. The grounds are common between the fuel gauge and the fuel pump.
Tan/White - power to the pump
Black or Black/White - Grounds for both pump and gauge
Pink - Fuel Gauge Sender
It might be also that the Black wire is grounded to the tank itself via the fuel sender.
Csjag
Report this Post01-12-2014 05:43 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Darn Darn Darn! Well at least I know how to drop the tank now. Thanks
1984_barn_find
Report this Post07-24-2017 03:01 AM Click Here to See the Profile for 1984_barn_findSend a Private Message to 1984_barn_findEdit/Delete MessageReply w/QuoteDirect Link to This Post
So my problem is I bought an aftermarket fuel pump for my 1984 SE... turns out it did not come with a wiring connection... now I can't find a harness to fit and the OEM is completely different.. any ideas?
Total ratings: 291
Report this Post07-24-2017 12:43 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take pics of the connector and post them. by
1984_barn_find
Report this Post07-25-2017 09:07 AM Click Here to See the Profile for 1984_barn_findSend a Private Message to 1984_barn_findEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never mind... Autozone had one on the shelf so I snagged it.. that's the good news... bad news is I now have fuel all the way to fuel injector but nothing coming out of it... I will research the forum for this issues... thanks
Total ratings: 291
Report this Post07-25-2017 10:24 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need more than just fuel, you need fuel under pressure.
The ECM fires the injector by grounding one of the wires. The other wire has +12 switched from the fuse box. So if the ECM isn't working it won't fire the injector. Also if the ECM isn't receiving ignition pulses it won't fire the injector.
The most likely problem with an ECM is no power to the ECM. They do fail but not often.
Is the ECM running the fuel pump for two seconds via the fuel pump relay when you first turn the key to on? It should. Does the ECM turn on the check engine light, key on engine off? it should.
One of the more likely reasons your ECM isn't getting power is no power to the power distribution post below C500, or an ECM reset connector left unconnected.
http://cliff.hostkansas.com...2012/fuselinks_1.jpg
ChapsDp
Report this Post09-12-2024 09:18 PM Click Here to See the Profile for ChapsDpSend a Private Message to ChapsDpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello guys I need help with my 85v6 fiero. I’m not sure what happened to it but it seems like the fuel pump wiring got burn of cut, so I need to know how to connect the cables the right way, my fiero now only cranks but it won’t star please help.
Mickey_Moose
Total ratings: 145
Report this Post09-13-2024 09:41 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Download a copy of the factory service manual for your car. It has step by steps procedure for testing and finding faults.
Google search and you will find...
GodSend
Report this Post09-13-2024 01:38 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is perfect timing as I have been trying to figure out a fuel issue on my 3800sc swap. Already dropped the tank once. Trying to avoid it again as well. Im not intending to hijack this thread, but all the information should be relevant to both of us.
What is the expected behavior with the yellow fuel pump connector when probing? I have ground continuity on all 3 pins. Pin a should be ground, pin b is fuel gauge feed, and pin C is 12+ from a relay (actually from 203 pin L which is fed from the relay).
Before I dropped the tank I had ground on both the Gound pin (A) and pin (C). I figured that the pump was shorted because I did not expect ground on the pin thats being fed the 12+, (Someone on facebook mentioned its supposed to be like that, but I have my doubts) . After a swapping the pump im still having issues. I can jump pin C with 12+ from the terminal block close to 500C and get 45+psi easily in 1-2 seconds to my rail, but I get sparks. If I use a 18ish gauge wire it heats up FAST, (exacly what I expect when wring a 12+ to ground, who hasent made that mistake?). With a heavier gauge wire its not as much heat. Im not sure if the heat is just from too much current for a smaller gauge or if its legit a wiring issue.
ChapsDp
Report this Post09-23-2024 01:00 AM Click Here to See the Profile for ChapsDpSend a Private Message to ChapsDpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you so much guys I really appreciate the info. I’ll try 100% next time I’m working on my car. Thank you.
