  3800 SC Manual Transmission Swap
3800 SC Manual Transmission Swap by GWSFieroGT
Started on: 01-26-2014 08:46 PM
Replies: 8 (3220 views)
Last post by: Spoon on 02-20-2020 08:20 PM
GWSFieroGT
Report this Post01-26-2014 08:46 PM Click Here to See the Profile for GWSFieroGTSend a Private Message to GWSFieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious (at the moment, anyway) - is there a common 3800 SC/manual transmission swap?
MstangsBware
Total ratings: 459
Report this Post01-26-2014 08:57 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes
jonathan2014
Report this Post01-26-2014 10:44 PM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
It how I did mine and I love it!
mitchjl22
Report this Post01-27-2014 12:13 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, look at my signature
My Car - 87' GT 3800sc
https://www.fiero.nl/forum/F.../HTML/121571.html#p0
FIEROFLYER
Total ratings: 180
Report this Post01-27-2014 11:13 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the manual swaps are using the Getrag 5 speed that came in the Fiero or the V6 4 speed also from the Fiero. A better option is the F23 manual 5 speed which has now been done many times or the F40 6 speed which is a bit more involved but still able to be done. Dan
DARN Cars now open with
Monstertone
Report this Post02-19-2020 02:20 PM Click Here to See the Profile for MonstertoneSend a Private Message to MonstertoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regarding the 87/88 Fiero 5 speed transaxle, aka Muncie/Getrag 282 MG2. The common shortcomings that always come up when mating this transmission to the 3800 is, it was never designed to take the amount of torque the 3800 is capable of producing. (repeated off the line dumping the clutch) The alternatives usually recommended are either the Fiero Getrag 4 speed, the F-23, or the F-40. While the latter two are excellent trannie's, they involve a lot more money than the application of a little common sense and keeping the 282 5 speed.
I found these figures on gears ratios for Muncie/Getrag Fiero 5 speed transaxles.
Manual Transmission Gear Ratios
Year ____Style __Code Axle 1st 2nd 3rd 4th 5th rev.
1988 4cyl 5 speed MT2 3.35 3.73 2.04 1.45 1.03 0.74 3.50
1988 V6 5 speed MG2 3.61 3.50 2.05 1.38 0.94 0.72 3.41
OK, this may either sound like a dumb question or, a too good to be true question. The question is, are the final drive gear sets interchangeable? Upping the final drive ratio from 3.61 to 3.35 in the MG2 Tranny would result in approx 9% taller final drive ratio. If this is possible, why has no one done it? Like said, sounds too good to be true. For a 3800SC swap having more than enough low end torque, it would not only offer lower rpms at highway speeds, but lessen the stresses fed back thru the drive train in the lower gears.
And, if this IS possible, since I am facing a rebuild of my 282 anyway, should anyone have that 3.35 final drive gear set laying around gathering dust, I sure would be interested in taking it off your hands. Please PM me with any offers.
[This message has been edited by Monstertone (edited 02-19-2020).]
OntarioKev
Report this Post02-19-2020 05:56 PM Click Here to See the Profile for OntarioKevSend a Private Message to OntarioKevEdit/Delete MessageReply w/QuoteDirect Link to This Post
6 year revival
hnthomps
Total ratings: 51
Report this Post02-19-2020 09:13 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I still have operational Getrag 282 transmissions mated with 3800 SC Series II and III engines for at least six years with no issues.
Nelson
Spoon
Total ratings: 61
Report this Post02-20-2020 08:20 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Look in the archives and you will find plenty. 3800 SC/manual transmission swaps are not uncommon.
These have been done with 4 spd, 5 spd and 6 spd manual transmissions.
Spoon
