  Help..............2007 CHEVY IMPALA ENGINE 3.5 V6
Help..............2007 CHEVY IMPALA ENGINE 3.5 V6 by whitestar
Started on: 04-02-2014 01:53 PM
Replies: 12 (1926 views)
Last post by: fieroguru on 04-03-2014 09:08 AM
whitestar
Report this Post04-02-2014 01:53 PM Click Here to See the Profile for whitestarSend a Private Message to whitestarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would this be a good engine for a 87Gt Auto? I have looked on here and can't find much info on it. If it would be good what all would I need to get? Any and all thoughts, info. appreciated thank you.
Venomous
Report this Post04-02-2014 02:26 PM Click Here to See the Profile for VenomousSend a Private Message to VenomousEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty sure those are VVT motors which would be more work than its worth. The 3.5 you want would be out of the Malibu. Would need an external crank trigger and throttle body and adapter among other things to get the LX9 running.
87 GT: Need to get road worthy first
92 Cutlass Vert: LX9/20s/tons more
01 Impala: Wifes taxi
99 Blazer: Parts hauler/winter beater
carbon
Total ratings: 132
Report this Post04-02-2014 02:30 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
A 2007 Impala will have an LZ4 VVT 3500... that is going to be quite a bit of screwing around with cam phasers and the like...
What you are looking for is an 04-06 3500 out of a Malibu, Aura or G6 or one of the minivans... that would be the LX9, if you are looking for a 3500. No VVT to screw around with.
You'll need an external 7x reluctor and a throttle body adapter (LX5 3.5L Short* V6 throttle body) to run it with the ECMs most people use for swaps...
If you don't want to screw around with that, look into a 2000+ 3400 run off of a '7730 ECM. The 3400 is a cam away from the same power level as the 3500.
3500 Swap Questions - Good reading.
WOT-TECH 60V6 Store
Milzy Motorsports
Hope that gives you a good starting point!
FIEROFLYER
Total ratings: 180
Report this Post04-02-2014 03:17 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Or stick with the fly by wire and use the stock ECM/TCM and get it reprogrammed to remove the VAT's and retain the VVT
DARN Cars now open with
whitestar
Report this Post04-02-2014 03:19 PM Click Here to See the Profile for whitestarSend a Private Message to whitestarEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the WT that you are talking about? This is a link to it on e-bay and it is very close by:2007 CHEVY IMPALA ENGINE 3.5 V6 I am also confused by this here at wikipedia GM High Value engine LZ4 : " LZ4[edit]
The LZ4 3500 is an OHV engine based on the 3.9 L LZ9 V6. It was introduced for the 2006 model year in the Chevrolet Impala and Monte Carlo. It includes continuously variable cam timing (fixed overlap). It has a cast iron block and aluminum heads. Output is 211 hp (156.5 kW) at 5800 rpm and 214 lb·ft (290 N·m) at 4000 rpm. Bore is 99 mm (3.9 in), stroke is 76 mm (3.0 in) for a displacement of 3510 cc. Horsepower rating changed for the 2007 model year to 224 hp (167 kW) at 5800 rpm and 220 lb·ft (298 N·m) torque at 4000 rpm. The Chevrolet Malibu, Pontiac G6, and Saturn Aura became equipped with this engine for 2007 (previously the Malibu and G6 had the non-VVT 201 hp (150 kW) 3.5 L LX9). In 2008 SAE ratings dropped the horsepower ratings to 219, keeping torque as is. On Pontiac G6 convertible models, horsepower was rated at 217.
Applications:
2006–2009 Chevrolet Impala
2006–2007 Chevrolet Monte Carlo
2007–2010 Chevrolet Malibu/Chevrolet Malibu Maxx
2007–2009 Saturn Aura
2007–2009 Pontiac G6
2008–2009 Saturn Vue XE AWD (222 hp/220 lb-ft)
Note: GM often refers to this engine in its literature as a "3.5L V6 with Variable Valve Timing".
LZE[edit]
The LZE 3500 was an OHV flexible fuel engine based on the 3.9 L LZ9 V6 (it can use either plain gasoline or 15% Gasoline and 85% Ethanol, E85) and includes continuously variable cam timing (fixed overlap). It has a cast iron block and aluminum heads. Bore is 99 mm (3.9 in), stroke is 76 mm (3.0 in) for a displacement of 3510 cc (214 cu in). Output is 211 hp (157 kW) at 5800 rpm and 216 lb·ft (293 N·m) at 4000 rpm.
Applications:
2006–2011 Chevrolet Impala
2009-2010 Chevrolet Malibu
2009-2010 Pontiac G6
These engines should not be confused with the LX5 "Shortstar" DOHC V6 used in the Oldsmobile Intrigue from 1999–2002, which also displaced 3.5 "
Which motor is this at e-bay?
carbon
Total ratings: 132
Report this Post04-02-2014 04:01 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
V V T = Variable Valve Timing
2004-2006 LX9 3500 201HP - Like a high output 3400
2006-2011 LZ4 3500 220HP - Has variable valve timing
1999-2002 LX5 3.5L DOHC - Oldsmobile Aurora engine. Completely different beast based on the Cadillac Northstar.
The engine in that eBay listing is the LZ4 3500 VVT.
[This message has been edited by carbon (edited 04-02-2014).]
carbon
Total ratings: 132
Report this Post04-02-2014 04:06 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Member since Apr 2004
That's also an option, I suppose... gotta get the gas pedal assembly too.
whitestar
Report this Post04-02-2014 04:08 PM Click Here to See the Profile for whitestarSend a Private Message to whitestarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to you all that have replied. Carbon here's a for you. Thanks for the links and info. That did help me understand things better! Imight want to keep looking.
ericjon262
Total ratings: 67
Report this Post04-02-2014 04:10 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
might be able to retain the VVT, and use a cable throttle before long using a 7730 and $nAst1. I've been keeping my eyes on the progress, could open quite a few doors for us.
http://60degreev6.com/forum...ncepts-Thread/page62
1st class A**hole.
Total ratings: 259
Report this Post04-02-2014 08:30 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would just install it as is and keep vvt and dbw. I wouldn't mess with trying to downgrade it to obd1.
fieroguruperformance.com
Total ratings: 461
Report this Post04-02-2014 10:02 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a G6 with the LZE. I think it would be a lot of fun in a Fiero.
I think that the 3.9 may have been available with a manual tranny, but I'm not sure.
It might make a good base for the 3.5 with a manual.
[This message has been edited by Raydar (edited 04-02-2014).]
ericjon262
Total ratings: 67
Report this Post04-02-2014 10:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just hate dbw, I would consider just about any option to avoid it! but that's just my preference. when I have more time, I'm going to look into programming a 3400 PCM to control VVT.
[This message has been edited by ericjon262 (edited 04-02-2014).]
Total ratings: 259
Report this Post04-03-2014 09:08 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The DBW parameters are fully programable and you can set them to act just like a cable driven throttle. I jump between 4 cars and only my LS4/F40 is DBW and I can't tell the difference. My preference on swaps going forward is to use DBW anytime it is an option.
