  84' SE: Possible to convert for 5x4.75 bolt pattern and 0 offset ?
84' SE: Possible to convert for 5x4.75 bolt pattern and 0 offset ? by mckaymotoworks
Started on: 04-25-2014 04:12 PM
Replies: 8 (905 views)
Last post by: mckaymotoworks on 04-27-2014 04:42 PM
mckaymotoworks
Report this Post04-25-2014 04:12 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume the rotors would need to be changed and modified? I ask because I really want to keep my build period correct, I like the same era Firebird turbine style wheels in 15x7. I have never attempted or thought about such until now.
Fadingaway
Report this Post04-25-2014 04:18 PM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem with firebird wheels is offset, I had a set of Trans am snowflakes on the back of my 87 I used wheel adapters to put them on 1 inch thick. For the lug pattern you want to convert in the rear I would look into the s10 hub upgrade, I personally am running 4th Gen Camaro rims with wheel adapters and they are working out fine
mckaymotoworks
Report this Post04-25-2014 04:21 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
How would ride quality and safety be affected running adapters?
jscott1
Total ratings: 415
Report this Post04-25-2014 11:24 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 4th gen firebird and corvettes of the same years switched to a fwd friendly offset, but you still have to deal with the adapter to change the bolt pattern. Or a labor intensive modification.. If someone had a bolt on kit to adapt the hubs I would buy it in a heartbest.
jb1
Report this Post04-26-2014 02:39 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Olejoedad had a full setup for the front, spindles and all, for sale 5x4.75. You would still need the rear , 6000 uprights, s10 4x4 hub bearing and cv joints.
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a---sold
Northstar Rebuild
[This message has been edited by jb1 (edited 04-26-2014).]
jscott1
Total ratings: 415
Report this Post04-26-2014 02:48 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
On an 88 the fronts are easy...you can just redrill. The rears are the hard part. Still waiting for a 100% bolt on solution.
Archie
Total ratings: 547
Report this Post04-26-2014 03:35 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
With wheel adapters they will affect front scrub radius a little but, if you have a good quality adapter safety & ride won't change.
This guy makes the best adapters & he gets them done quick. I've bought from him about 10 times & he usually ships them out the day after you order them. http://www.wheeladapter.com/index.php
If you have them made with front & rear registers, they are just as safe as OEM wheels. when installed they effectively just move the wheel's offset towards the negative side. i.e. a wheel with a 35mm positive offset will have a Negative 15.8mm offsetwith a 2" adapter
If you have registers on them they are just as good as having custom wheels made.
Even if you are not changing the bolt pattern & want to move the wheel out from the hub, don't use spacers. Instead use adapters.
Archie
jb1
Report this Post04-26-2014 03:37 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah the 87 down are not to hard. I still have a set of front hubs myself I done the backs on my n* but ended up using 5x115 and left the fronts alone.
Northstar Rebuild
mckaymotoworks
Report this Post04-27-2014 04:42 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll most likely stick to my original plan of 18 or 20 hole 15x7 steelies powder coated silver, with chrome beauty rings. I have a friend in engineering that has access to a plastic molding machine (maker) I'll have him recreate new OEM Fiero black center caps.
Thanks for the feedback
