  how to adjust the sunroof
how to adjust the sunroof by jonathan2014
Started on: 05-02-2014 07:22 PM
Replies: 4 (778 views)
Last post by: Patrick on 05-03-2014 12:33 AM
jonathan2014
Report this Post05-02-2014 07:22 PM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got any Sun roof assembly from the junkyard. but the shims that go on between the latch in the roof there was two and now there's another car with a sunroof and it only had one. how do I know how many shims to put on your mine?
hnthomps
Total ratings: 50
Report this Post05-02-2014 08:28 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My current sunroof car (87 MERA) only has one. My previous F308 rebody with a sun roof also used one clip/shim per side.
Nelson
84fiero123
Total ratings: 325
Report this Post05-02-2014 10:41 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
take a peace of paper, regular copy paper, set in under the roof when you get it all put in. close it and latch it, if you can do that and the paper is so tight to can't get it out try it in another spot and another spot all the way around the glass. if it is tight in all the places then its fine.
If its to tight to latch the glass you don't have enough shims, if its so lose the paper pulls out easily you have to many.
or maybe its the other way around, I forget. last test take a garden hose with no sprayer on it and run some water over it, if it leaks its to lose, if it doesn't its just right.
Steve
jonathan2014
Report this Post05-02-2014 11:59 PM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thxs so much. Just what I was looking for.
Report this Post05-03-2014 12:33 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect Jonathan was referring to the single latch at the back of the sunroof and not the two hinges at the front of the panel.
IMO the clamping force required has got more to do with eliminating wind noise (when closed) than keeping water out. Considering that a sunroof with functional drain holes doesn't leak water in the rain with the sunroof panel flipped open, I don't think a hose test with the panel closed will mean all that much (except maybe demonstrate that the drain holes are either plugged or non-existent).
