  Check engine light on freeway!
Check engine light on freeway! by DjGledhill54
Started on: 05-07-2014 01:58 PM
Replies: 7 (449 views)
Last post by: fiero5150 on 05-14-2014 11:32 PM
DjGledhill54
Report this Post05-07-2014 01:58 PM Click Here to See the Profile for DjGledhill54Send a Private Message to DjGledhill54Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just bought a 1988 GT and my check engine light seems to come on whenever I drive on the freeway. It never comes on when I drive in town only on the freeway. And when I turn the car off and back on the light doesn't come on... Unless I get on the freeway of course. I have checked for trouble codes and I got a code 32 and a code 35. What should I do to fix this problem? Any help is appreciated.
no2pencil
Report this Post05-07-2014 02:02 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum!
Did you check over the codes on the main menu?
Code 32 :EGR Vacuum Control
Code 32 is by far the most commonly encountered trouble code. The most common cause for this trouble code is a leak in the EGR vacuum lines. This code is often disregarded since a malfunctioning EGR system seldomly has any effect on the car's driveability, and only on the engine's emissions. It's also tremendously difficult to diagnose the problem. If your car passes emission tests and is otherwise running ok, it's often not worth the trouble trying to find the problem.
Code 35 : Idle Speed Error
The ECM will set code 35 when the engine speed is 75 RPM above or below the correct idle with closed throttle. This condition must be met for at least 45 seconds before the code is set. If idle speed is too high, check for vacuum leaks. If idle speed varies up and down, your engine might be running too lean (high air/fuel ratio). Check for low fuel pressure or water in fuel. If idle speed is too low, your engine might be running too rich (low air/fuel ration). Check for high fuel pressure or leaking/sticking injectors. Also, check all connections to the IAC and replace the IAC if necessary.
[This message has been edited by no2pencil (edited 05-07-2014).]
IanT720
Report this Post05-07-2014 02:05 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yup I was going to say probably EGR codes... Usually because the EGR solenoid (UFO shaped thing on exhaust) get filled with carbon and stops moving. It's just emissions mostly... You can take it off and clean it, obviously check for cracks in your vacuum lines running to it and the EVP solenoid (what controls the EGR near the passenger side of the intake ) and check the wiring to that too. Otherwise get a block off plate, and a custom chip from darth fiero removing the egr code... Have fun! Mine was on for years, till I did my engine swap.
1987 Fiero GTX 3800 Turbo... My Build, ST3 Cam, Lowered, Wheels, and pics enjoy!https://www.fiero.nl/forum/Forum1/HTML/089483.html
DjGledhill54
Report this Post05-07-2014 02:08 PM Click Here to See the Profile for DjGledhill54Send a Private Message to DjGledhill54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I looked over the codes. I read code 32 and am not too worried about that as my car passes smog and runs perfectly fine. But with 35, my car seems to idle just fine but then again I'm not entirely sure. It idles around 14-1500 when warming up then drops to around 1000 or so when warmed up.
Report this Post05-07-2014 02:15 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The idle sounds good. Your problem is probably a slight vacuum leak at the EGR valve or solenoid. Check the little rubber elbows for a tight fit...it does not take much to trigger a code 32.
no2pencil
Report this Post05-11-2014 10:18 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found this (again) & thought of your code 32 :
https://www.fiero.nl/forum/Forum2/HTML/122507.html
Boostdreamer
Total ratings: 98
Report this Post05-12-2014 08:19 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 V6 automatic w/air idles between 7 and 800. Yours is a bit high.
fiero5150
Report this Post05-14-2014 11:32 PM Click Here to See the Profile for fiero5150Send a Private Message to fiero5150Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check your gas cap. The rubber seal may be old and cracked thus preventing a tight seal.
