  Installing the clutch banjo to the pedal?
Installing the clutch banjo to the pedal? by FieroCat
Started on: 05-08-2014 12:49 PM
Replies: 26 (1046 views)
Last post by: 1985 Fiero GT on 09-11-2024 09:31 PM
FieroCat
Report this Post05-08-2014 12:49 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I just replaced my master clutch cylinder and I can not, to save my life, get the banjo to snap onto the clutch pedal pin to connect it. The bushing seems to be too tight. Is there a special way to slip it on? Or just more brute force needed?
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
Bloozberry
Total ratings: 311
Report this Post05-08-2014 12:58 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I recall, some of the aftermarket pedals may have a larger diameter pin. You might need to file the pin to a smaller size.
dobey
Total ratings: 371
Report this Post05-08-2014 01:33 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you get the right master cylinder?
http://rodneydickman.com/ca...h=61&products_id=280
Or do you have an 87 or 88, but have an 84-86 clutch pedal? It looks like the earlier version had a larger bushing/pin than the later version.
FieroCat
Report this Post05-08-2014 02:14 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should be the right one for 86. The old one I replaced looks like the 87-88 version as shown on rodney's site... so I got the same style. Rockauto showed that style for 86 I believe? But confused as to why an 87-88 style one would be in an 86 model, given that it looks very much like the original cast iron one.
Report this Post05-08-2014 02:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just use your old one. They're the same except for the hole size.
FieroCat
Report this Post05-08-2014 02:27 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Old master cylinder was leaking, that's why I replaced it.
Report this Post05-08-2014 02:36 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
old banjo
FieroCat
Report this Post05-08-2014 02:39 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, is it possible to swap out the banjos? I actually tried pulling the old one out of the cylinder but couldn't seem to remove it.
dobey
Total ratings: 371
Report this Post05-08-2014 02:56 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can wait a couple days, you should contact Rodney and see if he'll swap an early style banjo for the one on yours (which you should send back to him), so that you can keep the adjustable banjo (it's worth it), and have it fit correctly in your car.
And offer to pay the small amount in shipping to send the new one, and to send the one off your new master back.
Report this Post05-08-2014 06:46 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You'll have to remove the master cylinder again. Remove the Circlip that holds the banjo in the back of the MC. Experiment with your old MC to see how it's done.
FieroCat
Report this Post05-08-2014 08:40 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take a look again, but I couldn't find any kind of clip holding the banjo in.
The new banjo eyelet hole was plenty big to fit over the pin, but the plastic bushing was just slightly too small to fit over it... can I get a bushing that will fit on its own?
fireboss
Total ratings: 58
Report this Post05-08-2014 09:49 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodneys the Man!
dobey
Total ratings: 371
Report this Post05-08-2014 10:21 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plastic? Rodney's adjustable banjo (and the new master) comes with a brass bushing.
FieroCat
Report this Post05-08-2014 11:56 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, the new one I got came from O'Reilly's... probably not the best source. Sounds like I need to give Rodney a call!
fireboss
Total ratings: 58
Report this Post05-09-2014 01:12 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are two theories that come into play when dealing with Rodney:
1.People will buy parts he carry from other vendors and then complain cause they didn't purchase from him.
2.People will buy from Rodney and be happy as hell and will post how there parts are better than expected.
p.s. you then become a R/D cheerleader
dobey
Total ratings: 371
Report this Post05-09-2014 11:34 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, I thought you'd gotten the one from Rodney. Don't know about quality of the ones from O'Reilly's, but have heard generally bad things about the ~$20-30 cast iron ones from parts stores going bad and rusting early. The aluminum master from Rodney though is great though, and the adjustable banjo makes installing and bleeding much easier to do.
Report this Post05-09-2014 11:50 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah there was a clip on my 86 to hold the banjo in place.
http://www.v8archie.com/arch6.htm
"1) Remove retaining clip holding banjo to the pedal and slide banjo off pedal."
[This message has been edited by 2.5 (edited 05-09-2014).]
FieroCat
Report this Post05-09-2014 01:33 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's odd is that the pin on my clutch pedal has a lip on it and looks different from the ones pictured on rodney's site. There isn't a hole for a retaining pin or cotter pin. I'm not sure what the correct bushing for it is, but the one that was on there already was plastic with 4 little tabs sticking out.
FieroCat
Report this Post05-09-2014 07:07 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroCat
Member since Feb 2014
Here's a pic of what the pin on my clutch looks like, and the plastic bushings. One slightly smaller than the other, though only slightly:
fierosound
Total ratings: 286
Report this Post08-29-2015 01:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was having a similar problem. The brass bushing fits the stud fine, and it fits in the banjo fine.
But trying to get all three parts together hasn't worked so far because of the offset - they will line up when it's together.
Even light tapping didn't help. The bushing is too precise - an extra 1/1000th of an inch clearance on ID and OD may help.
I took off the nuts securing the Master Cylinder. Once clear of the studs, it can shift 1/2" toward the fender.
The the banjo and pedal line up enough to go together and you can shift the Master Cylinder back onto the studs afterwards.
(should have thought of this earlier)
Calgary time/temp
[This message has been edited by fierosound (edited 08-29-2015).]
Total ratings: 463
Report this Post08-29-2015 04:05 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same problem when I converted my car to a manual.
The fit is so precise that the pieces will not slide together if they are not aligned perfectly.
This with Rodney's master and bushing. Once I had the alignment correct, it was no longer a problem.
fierosound
Total ratings: 286
Report this Post08-29-2015 07:49 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had no movement in the pedal either to get things lined up.
I DID try every-which-way before loosening the master cylinder.
pmbrunelle
Total ratings: 63
Report this Post09-11-2024 06:04 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you mean that the early "large hole" banjo rods are the same as the later "small hole" banjo rods, except for hole size?
I'm wondering if I can install a later master cylinder and later hydraulic line, with an early banjo rod and early pedal.
Report this Post09-11-2024 06:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make an adjustable banjo and you can mix and match to your heart's delight.
pmbrunelle
Total ratings: 63
Report this Post09-11-2024 06:50 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to know if I can mix and match with unmodified parts!
Report this Post09-11-2024 07:40 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're mixing and matching, you're already modifying.
1985 Fiero GT
Report this Post09-11-2024 09:31 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The slave cylinders are the unreliable cast iron ones, the master cylinders are cast aluminum, and some people say they work fine, haven't heard to many complaints, mine hasn't lasted but neither did my Rodney unit, sooooo yeah.
