  Iron duke dripping oil on the exhaust mainifold
Iron duke dripping oil on the exhaust mainifold by superbub112
Started on: 05-20-2014 11:09 AM
Replies: 16 (452 views)
Last post by: 2.5 on 05-22-2014 08:55 AM
superbub112
Report this Post05-20-2014 11:09 AM Click Here to See the Profile for superbub112Send a Private Message to superbub112Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've just recently taken my '84 fiero with a 2.5L ironduke out for a quick spin. I maybe traveled half a mile before I decided to return home. That's when is notice a little bit of smoke escaping from the rear vent. It's normal for the motor to smoke a little bit. Not safe, but normal for my specific fiero. After this small cruise, however, there was a lot of smoke. I've replaced the gasket for the valve cover a while back, so why is this happening? Thanks in advance.
Sorry for the large image.
-Dr. superbub112
Csjag
Report this Post05-20-2014 12:37 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kind of valve cover gasket do you have on it, I was having trouble with mine leaking until I got the most expensive fel pro reinforced rubber gasket rubber gasket. That stopped my leaks.
Report this Post05-20-2014 12:41 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
What does that image show? If you have located the drip, then you know where the oil is. Over tightening the valve cover bolts will sometimes cause a leak.
jaskispyder
Total ratings: 205
Report this Post05-20-2014 01:00 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have battled this... I finally used a rubberized cork with metal insert as the gasket (Victor) and added high-tack sealant from permatex (if I remember correctly). That worked the best (and longest).
superbub112
Report this Post05-20-2014 01:00 PM Click Here to See the Profile for superbub112Send a Private Message to superbub112Edit/Delete MessageReply w/QuoteDirect Link to This Post
The gasket I used is part #52776 on the fierostore. It's made of cork.
That image shows the valve cover as well as where the exhaust manifold attaches to the motor. The side of the engine closest to the cabin. Also, how tight should the bolts be on the valve cover?
superbub112
Report this Post05-20-2014 01:02 PM Click Here to See the Profile for superbub112Send a Private Message to superbub112Edit/Delete MessageReply w/QuoteDirect Link to This Post
superbub112
Member since May 2014
Jaskispyder, that's pretty much what I did aside from the metal inserts. What are those?
jaskispyder
Total ratings: 205
Report this Post05-20-2014 01:07 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, I used metal spacers on top to spread the load. Now that I think of it... I also used studs instead of bolts and used loc-tite on the nuts, so I didn't have to torque them down much. Check the valve cover flange to see if it is bent. I also let it "cure" overnight before running it.
superbub112
Report this Post05-20-2014 01:46 PM Click Here to See the Profile for superbub112Send a Private Message to superbub112Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help, everyone! I'll try a few things and see if something works.
TopNotch
Total ratings: 60
Report this Post05-20-2014 02:09 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
The best gasket for stock duke valve covers is the Fel-Pro PermaDryPlus® type. It is made of blue silicone rubber molded onto a steel carrier. It works best when installed dry (surfaces cleaned of oil, and no sealer).
jaskispyder
Total ratings: 205
Report this Post05-20-2014 02:11 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! I wish this was around "back in the day"... Stamped valve covers = lame
Report this Post05-20-2014 02:39 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I dont use cork gaskets anymore they seem to leak most. Also pay attention as to not over torque the bolts when installing as gaskets can squish out of place and stamped cover can warp.
jaskispyder
Total ratings: 205
Report this Post05-20-2014 02:56 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, cork gaskets are the pits.... I know I tried rubber gaskets and cork and then then rubberized/cork/steel one and that worked for me. But Felpro has done a good job coming up with solution gaskets, so I don't see why it wouldn't work, if installed properly.
hercimer01
Report this Post05-21-2014 02:23 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a heck of a time getting my leaks all fixed.
My valve cover flange was bent on the ends, once I got that straight I used Permatex high tack w/cork too. And lots of Permatex Right Stuff Gasket maker.
12.840@104.8 MPH Intense-Racing 1.9 rockers, 3" exhaust, 3.4 pulley, ZZP tune and 18 year old tires.
88 Coupe under construction
88 formula 3.4L 4t60 swap SOLD
Csjag
Report this Post05-21-2014 06:55 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you haven't driven the car in awhile make sure you also check the blower housing for critter nests and leaves.
Total ratings: 154
Report this Post05-21-2014 12:34 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I used. This mess also contained a cork gasket.
You can see the puddle of oil at the center of the manifold where it was leaking. It was smoking enough that it might have had enough oil to catch fire.
If you can find a tube of PermaTex red Gasket Maker and apply it to both engine block and valve cover and let it dry after assembly, you can often get a cork gasket to work without leaking. Use the load spreaders on the bolts, whichever gasket you use.
jaskispyder
Total ratings: 205
Report this Post05-21-2014 12:39 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gasket Maker also works, as I have used that on a different engine. I let it cure overnight, just to be sure.
Report this Post05-22-2014 08:55 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The pain for me was removing the EGR, that one bolt seems to only have room for something like 1/8th of a turn or less at a time, and cant get a universal joint in there.
