  Adding Cruise Control
Adding Cruise Control by nosrac
Started on: 08-28-2014 06:07 PM
Replies: 16 (769 views)
Last post by: nosrac on 09-02-2014 02:22 PM
nosrac
Total ratings: 50
Report this Post08-28-2014 06:07 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone added CC into a NON optioned car?
What do I need to GIT ER DONE?
dobey
Total ratings: 371
Report this Post08-28-2014 06:35 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The easiest/best option for a non-DBW engine, would be to use the digital cruise, following the instructions in the 3rd link at http://www.gmtuners.com/files/index.htm .
You'll need the wiring, turn signal stalk with cruise, module, actuator, and cable, IIRC. But the full list should be in that document.
hnthomps
Total ratings: 50
Report this Post08-28-2014 08:42 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I added an electronic cruise control to an 88 Mera on a GT frame and it works well. I can look up the specific manufacturer (Rosta I think) if you are interested. I will also be adding the electronic cruise to another 88 Mera in the future. This vehicle has a 3800 SC Series III engine and a Northstar TV along with a few other goodies.
Nelson
[This message has been edited by hnthomps (edited 08-31-2014).]
Kevin-84SE
Report this Post08-28-2014 08:56 PM Click Here to See the Profile for Kevin-84SESend a Private Message to Kevin-84SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Rostra Electronic cruise control is a nice unit, I installed one on my motorcycle.
Kevin
nosrac
Total ratings: 50
Report this Post08-28-2014 09:10 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nelson
I googled them but don't see any pricing info. Any gotcha's when installing?
Kevin-84SE
Report this Post08-29-2014 12:33 AM Click Here to See the Profile for Kevin-84SESend a Private Message to Kevin-84SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Rostra 250-1223 is the main unit and I see Amazon has it for $172, the column controls will be another $30 to $60, I see they now have wireless control for about $90.
Kevin
PaulJK
Total ratings: 237
Report this Post08-29-2014 01:28 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, I added it to my 3800SC and love it. Have Stephen add the throttle control cable like he did with mine (88 4 cylinder cable ?) then use the electronic cruise setup (AR module and Darth's directions). There are only about a dozen connections to make; just go through it 1-at-a-time. Here's some good info:
https://www.fiero.nl/forum/A...110502-2-102406.html
https://www.fiero.nl/forum/Forum2/HTML/128382.html
nosrac
Total ratings: 50
Report this Post08-30-2014 02:30 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where did you get the AR module? What vehicle does it come out of? I searched on ebay but sis NOT see AR specific ones.
mike-ohio
Report this Post08-30-2014 12:53 PM Click Here to See the Profile for mike-ohioClick Here to visit mike-ohio's HomePageSend a Private Message to mike-ohioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I added an audiovox unit and put a magnet on the axel and bolted the pickup to the transmision. easy to do.
not fancy but reasonably priced, easy to install, and works well.
Total ratings: 290
Report this Post08-30-2014 02:37 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
ick ick ick.
Is your bell crank and throttle/cruise bracket the same as what it seems like all the other 3800s look like? You are going to mount the cruise in the stock location? I can pick up an AR along with the correct length and ended cable at the yard next time I am there.
nosrac
Total ratings: 50
Report this Post08-30-2014 02:58 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by phonedawgz:
ick ick ick.
I am using the N* bracket for ZZP.
http://shop.zzperformance.c...e-Cable-Bracket.aspx
Yes, Stock location is the plan.
Sure, plz pick me one up. PM me the details.
PaulJK
Total ratings: 237
Report this Post08-30-2014 04:20 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think it was a 1990's monte carlo. Here's a post where Darth talks about using one from 96-99 cadillac northstar:
https://www.fiero.nl/forum/Forum2/HTML/130118.html
[This message has been edited by PaulJK (edited 08-30-2014).]
Total ratings: 290
Report this Post08-30-2014 08:49 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
So you are running the Northstar throttle body then also? Please post a pic of the bell crank so I can make sure the end of the cable snaps on whatever post they provide for the cruise. Point out which one is for the cruise.
nosrac
Total ratings: 50
Report this Post08-30-2014 10:02 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes N* TB. I will get U a pic as soon as I can.
nosrac
Total ratings: 50
Report this Post09-01-2014 11:28 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
85LAMB
Report this Post09-02-2014 08:16 AM Click Here to See the Profile for 85LAMBSend a Private Message to 85LAMBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nosrac
Could you please measure the outer opening for the N* TB ? the part where the intake hose connects to.
I am wondering if is the same width as the L67 TB
Thanks in advance
nosrac
Total ratings: 50
Report this Post09-02-2014 02:22 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 85LAMB:
Nosrac
Thanks in advance
It is 4" on the intake side and 3" on the M90 side.
[This message has been edited by nosrac (edited 09-02-2014).]
