  Body side molding clips??? Where to buy? How to remove?
Body side molding clips??? Where to buy? How to remove? by grkboy707
Started on: 09-29-2014 09:56 PM
Replies: 3 (1899 views)
Last post by: rogergarrison on 10-01-2014 04:37 PM
grkboy707
Report this Post09-29-2014 09:56 PM Click Here to See the Profile for grkboy707Send a Private Message to grkboy707Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure if this is really the right forum for this, but I can't seem to trace down any of those awful clips for the body side molding clips. And when I tried to remove them, it seemed like the hole was too small for the arch-looking part of the clip to get through. Is it just that the clip was too old and brittle to safely remove? Thanks
Greg
Report this Post09-30-2014 02:08 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
They usually break when removed from being old and brittle. Fierostore has them.
http://fierostore.com/Product/Detail.aspx?s=81003
If link doesnt take you there search these:
84-88 Door Molding Clip Kit
Part # 81003 8485GROOVE
84-88 Rear Quarter Molding Clip Kit
Part # 81007 8485GROOVE
[This message has been edited by 2.5 (edited 09-30-2014).]
Michiganman
Report this Post09-30-2014 09:03 PM Click Here to See the Profile for MichiganmanSend a Private Message to MichiganmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The big clips that look like a longhorn cow are a PITA. I bought a pack of 10 of the rectangle clips that are at the front of the door trim. Got them on eBay. 10$. Screw them next to the slot where the longhorns go. Just tight enough that they can still slide up & down. (Use short self tapping screws with shaft diameter smaller than clip hole) Snap your trim on & you're done. Easy to remove if necessary.
http://pages.ebay.com/motor...370675264296&alt=web
[This message has been edited by Michiganman (edited 09-30-2014).]
rogergarrison
Total ratings: 551
Report this Post10-01-2014 04:37 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
When newer, you pushed the molding upward (toward the 'horns') and just popped the molding off with a putty knife or flat screwdriver. Like already said, after 20 years there so brittle, your very likely to break every one of them. I just mask the moldings when repainting. Just takes a few minutes to be careful with the tape.
