  Here's a fix for those floppy sun visors
Here's a fix for those floppy sun visors by JohnnyBones
Started on: 10-08-2014 04:39 PM
Replies: 2 (541 views)
Last post by: theogre on 10-08-2014 10:28 PM
JohnnyBones
Report this Post10-08-2014 04:39 PM Click Here to See the Profile for JohnnyBonesSend a Private Message to JohnnyBonesEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your visors keep falling down even though you have tightened the tension screw, then the shaft on your visor mount has come loose. You don't need to buy a new one!!!
Here's how I fixed mine.
Just drill near the edge of the shaft housing all the way through the shaft and install a small roll pin. SIMPLE AND EFFECTIVE.
Just like it should have been done to begin with.
86 Fiero GT
mental floss
Report this Post10-08-2014 09:34 PM Click Here to See the Profile for mental flossSend a Private Message to mental flossEdit/Delete MessageReply w/QuoteDirect Link to This Post
That could be taken to the next step by inserting one of the newer model visor posts from a different car; the kind that slide back and forth in addition to flipping up and down.
Report this Post10-08-2014 10:28 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
or try Green formula Locktite.
Green wicks into parts already assemble.
example Loctite 37423 290 Green Penetrating... amazon
