  Torque specs for 4T60 transmission pan bolts
Torque specs for 4T60 transmission pan bolts by jimbolaya
Started on: 10-24-2014 10:50 AM
Replies: 3 (1837 views)
Last post by: jimbolaya on 10-24-2014 02:29 PM
jimbolaya
Total ratings: 114
Report this Post10-24-2014 10:50 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried googling and have not had success finding torque specs for the pan bolts on the 4T60. How many inch lbs, or feet lbs is it?
Jim
Grantman
Report this Post10-24-2014 11:11 AM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
trans oil pan to case I assume? 10 lbs/ft
https://www.fiero.nl/forum/Forum2/HTML/126987.html
Report this Post10-24-2014 11:53 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
TH125 and others Should be 8 ft/lb but 8-10ft/lb require clean and dry holes and bolts. Any lube, including anti seize, void the spec and using that most likely will strip the holes.
Also need a good pan. Most are damage by people doing oil changes etc.
Use fiber casket is better. Cork works but OE bolt torque spec will crush them and then leaks soon after.
With cork caskets, I have better luck wrapping bolts w/ Teflon tape (plumbing tape) then tight enough just for gasket to show the pressure.
use High Tack or Super "300" sealant on both sides of gasket.
I work around the bolts so all gets even pressure on the casket.
Teflon mainly act like tread lock here. Some bolts often have open threads on back of Al shell and helps keeping water etc out.
wrap so bolt tips will easy start in the holes. I think take 3-4 turns of tape to do the job.
Any Loctite often causes problems used on steel bolts in aluminum parts.
[This message has been edited by theogre (edited 10-24-2014).]
jimbolaya
Total ratings: 114
Report this Post10-24-2014 02:29 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct, thanks brother. I have everything back together, and will be putting the cradle back in tomorrow. I have an out of town guest tonight so I had to wait. Hopefully I will be starting this baby tomorrow night and taking it for a test run, Sunday at the latest.
Jim
