  Lights cause engine cut-out?
Lights cause engine cut-out? by no2pencil
Started on: 10-25-2014 07:45 PM
Replies: 11 (364 views)
Last post by: no2pencil on 03-14-2015 03:53 PM
no2pencil
Report this Post10-25-2014 07:45 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
A couple of weeks ago I started up my car. It's been in storage for only a month or two. It started right up as it always does. How ever when I turned on the parking lights only the engine stumbled. When I turned the lights off it went back to normal. When I turned on the head lights, the car immediately turned off. With the car off, the lights did not flip up, though I could hear them try.
I then hand loosened the head light motors & the car ran with no issues.
Today when I tried to star it, it barely attempted to start, sounded like a dying battery. Even the fuel pump sounded slow. The car idled lower than normal & sounds like absolute garbage.
I'm hoping that my issue is that it simply needs a new battery. However the led indicator never lights up to agree with me. I'm really hoping that I don't have mice eating up my wires. Any suggestions on what to check first?
tebailey
Report this Post10-25-2014 08:29 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
check the alternator.
Ken_86gt
Report this Post10-25-2014 10:39 PM Click Here to See the Profile for Ken_86gtSend a Private Message to Ken_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clean the connection points for the batterry ground and see if that helps.
1fast2m4
Report this Post10-26-2014 12:10 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd do as he said check the ground cable at the battery and the engine.
Total ratings: 290
Report this Post10-26-2014 02:05 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Charge the battery
tebailey
Report this Post10-26-2014 06:55 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the battery had enough juice to start the car, then shut down when the lights were on, the alt is not charging. cables to the battery wouldn't make a difference once the car was running.
Report this Post10-26-2014 09:04 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Year and Engine?
Or does car have CS alt conversion?
Low battery can often start the car but too low battery then CS alt would turn on. This is safety item to save the CS alt from death. SI alts would try to change a low/dead battery. That damages the alt and can cause battery and/or wiring to fry off.
See my Cave, CS Alternator
"However the led indicator never lights up to agree with me. "
What LED?
Battery light is 194 Lamp and resistance of bulb is use to turn on most SI and some CS.
tebailey
Report this Post10-27-2014 06:25 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the indicator bulb is burned out the alt won't charge. Little catch 22 there, the bulb won't come on to tell you it's not charging, and it's not charging because the bulb is burned out. Does the light come on when you turn the ign without the car running? If not replace the bulb, charge the battery and try again.
no2pencil
Report this Post02-22-2015 04:52 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Digging this back up, as I just went & visited the car in storage. I was hoping to find the battery stone dead & add further reason to believe that the car ran the way it did because of the battery. However, this was not the case. The car fired right up & had the same symptoms, poor idle, & after 10 minutes of idle the engine bogged down when I turned on the lights.
Another strange anomaly was that the EGR (cap?) in the bottom of this photo, was loose. All 3 bolts (screws?) are missing & it spins around & around by hand.
The image is not of my car, as my phone died while taking the photo :/
no2pencil
Report this Post02-22-2015 04:53 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
no2pencil
Member since Oct 2009
It's been so long, I completely forgot. Will make a note & a to-do list, & follow up.
Total ratings: 290
Report this Post02-22-2015 05:08 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
First disconnect the battery
Then make sure the two nuts on the power distribution post are tight. The power distribution posts are located directly below C500, the large wire connector right next to the battery (assuming 85-88). Yes the two nuts are different sized (and SAE not Metric)
If 84, then check to make sure where the positive battery cable connects to the starter is tight. These nuts are hot electrically with the battery attached so DO NOT do this with the battery still connected. Then take a wire brush and clean the surfaces of both terminals of the battery and the surface of the battery cable that connects to the battery.
Reassemble and most likely your problems will be solved.
Under the EGR cap is a diaphragm. If the cap rotates most likely the diaphragm is crap. Test this by disconnecting the EGR vacuum line. Then reach under and with most EGR valves there are holes and you can push the EGR diaphragm up towards the cap. Then cover the vacuum port and release the diaphragm. It should hold until you release your finger off of the vacuum port. If the diaphragm returns and doesn't hold the vacuum it is bad.
The EGR valve will get HOT on the bottom with the engine running.
If it's good replace the screws. If it is bad of course replace the valve. Check the valve with it still on the engine. Do the vacuum test first with the engine cold. If you do have to replace the EGR valve get the gasket that also goes under the EGR valve block since you will also disturb it.
[This message has been edited by phonedawgz (edited 02-22-2015).]
no2pencil
Report this Post03-14-2015 03:53 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice! Just as you suggested!
As for the EGR, when I pulled the old one off I noticed that the pin was almost gone :
As compared to the new one.
These are the bolts that went missing, & allowed the EGR to spin around.
The new EGR doesn't have any of that.
& someone hit the ramp by the train stop.
With the EGR replaced, it fired right up & ran just like it used to.
