  are the manual transaxles from chevy citation or pontiac phoenix models an easy swap
are the manual transaxles from chevy citation or pontiac phoenix models an easy swap by Tracker
Started on: 11-07-2014 12:24 PM
Replies: 5 (648 views)
Last post by: 85 SE VIN 9 on 11-07-2014 07:32 PM
Tracker
Report this Post11-07-2014 12:24 PM Click Here to See the Profile for TrackerSend a Private Message to TrackerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 84 Fiero with the high performance 4 speed transaxle. Have had it since it was new. Also had an 80 Citation with a manual transaxle. With today's higher highway speeds, I find the Fiero engine is turning 3500 rpm and higher. I liked the ratios in the 80 citation I had. Would it be an easy swap? I put a lot of miles on the 80 citation and changed clutch at least once my self, so I know what is involved in doing that.
Tracker
85 SE VIN 9
Report this Post11-07-2014 12:38 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have two 85's with the 2.8. The SE revs much higher and doesn't like to drive at 35 because that speed is right between third and fourth. That's the M17. The GT has a different (four speed) transmission and is much more fun and practical to drive. I think it's the M6. The point being - wouldn't a different Fiero tranny be more practical? Isn't there a high mpg transmission for the Duke? That might be the best bet. I assume it cruises at a lower rpm and people say it allows you to get very good mileage.
Report this Post11-07-2014 01:00 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
There was only one 4 speed available in 1985.....the M17.
The Citation transmission will bolt up to a Fiero, but what gear ratios are inside is a mystery ( unless you can find the option sticker on the Citation). If you like how that transmission drove, it's probably worth the labor to put it in.
Total ratings: 154
Report this Post11-07-2014 01:16 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you look at your 84 transmission, you will see two castings that were for mounting the cables into the front wheel drive vehicles. It was a remnant transmission from the Citation and Phoenix. Since the cables come in from the opposite direction on the Fiero, a new bolt-on cable mount was designed. Not having a transmission to look at, I don't know if the mounting provisions are on the 83 and older transmissions. If they are, the transmission should work for you.
Total ratings: 154
Report this Post11-07-2014 01:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
I found this on the 83 X-11. Though it says it's a rear wheel drive car, I don't really know. The specs seem to cover all years from 83 to 85.
983 Chevrolet Citation Specifications
Engine Location Front
Drive Type Rear Wheel
Body / Chassis Unit-Body
Production Years for Series 1980 - 1985
Price $6,300-$7,000
Weight 2400 lbs | 1088.622 kg
Engine Type : I4 2474 cc | 151.0 cu in. | 2.5 L.
92 BHP (67.712 KW) @ 4000 RPM
134 Ft-Lbs (182 NM) @ 2800 RPM
Bore : 4.0 in | 102 mm.
Stroke : 3.0 in | 76 mm.
2 Barrel Rochester E2SE carburetor
Engine Type : V6 2835 cc | 173.0 cu in. | 2.8 L.
112 BHP (82.432 KW) @ 4800 RPM
145 Ft-Lbs (197 NM) @ 2100 RPM
Bore : 3.5 in | 89 mm.
V6 173 V6 173
Transmission:
4 Manual Floor shift controls , 4 Manual
Gear Ratios
1st Gear 3.53:1
2nd Gear 1.95:1
3rd Gear 1.24:1
4th Gear 0.81:1
Production Figures
Total Chevrolet Production for 1983 1,012,649
Total production of Citation for 1983 92,184
Coupe - 4 Cyls 6,456
Coupe - V-6s 8,946
Hatchback 4 Cyls 14,323
Hatchback 4 Cyls 40,667
Hatchback 6 Cyls 14,323
Hatchback 6 Cyls 30,765
85 SE VIN 9
Report this Post11-07-2014 07:32 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
