  Clutch pedal fade
Clutch pedal fade by stevep914
Started on: 11-19-2014 12:55 PM
Replies: 2 (221 views)
Last post by: Gall757 on 11-20-2014 08:55 AM
stevep914
Report this Post11-19-2014 12:55 PM Click Here to See the Profile for stevep914Send a Private Message to stevep914Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had this problem a month ago, and thought I had it fixed; but apparently not. After about 1 hour of driving, my clutch pedal went to the floor without activating the clutch. ( 2.8 with 5 speed) There was no loss of fluid, no leaks evident, and the slave is a new Dickman 2 seal unit. I noticed on the F40 ( 86 Fiero kit car) the heat shield for the slave had been removed. I assume that this was done because the builder had installed two good sized cooling fans in the engine compartment blowing air forward, and venting the heat out the rear window louvers. I installed a heat shield between the slave cyl and the exhaust downpipe nearby, and had no trouble for a month. The shield was one off my 86 parts car. The issue resurfaced yesterday after a longer than normal spin around town. With no leaks, I am assuming heat is boiling my clutch hydraulic fluid, causing fade (let the car sit 10 minutes, and the pedal is normal and functional again) , and that the metal shield by itself is not adequate. I am now looking at insulating heat shield material. Has anyone experienced this, or have any suggestions? Thanks in advance.
Report this Post11-19-2014 01:30 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
If this is a stock 2.8 I would remove those fans the previous owner put in maybe they are causing issues. There shouldnt be engine bay heat issues.
Report this Post11-20-2014 08:55 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is your exhaust system stock? Make sure it does not touch the hydraulic line.....I doubt if the slave cylinder is the source of the problem.
