  3800sc swap Flywheel info
3800sc swap Flywheel info by Kfa171
Started on: 12-08-2014 03:33 PM
Replies: 21 (3845 views)
Last post by: Dennis LaGrua on 05-02-2018 10:16 AM
Kfa171
Report this Post12-08-2014 03:33 PM Click Here to See the Profile for Kfa171Send a Private Message to Kfa171Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was wondering for the swap what needs to be done to the flywheel, does it need to be machined in anyway or what?.... (i am using the 5spd getrag) also if it does need to be modified does anyone have the exact measurements for what needs to be done.
Kfa171
Report this Post12-08-2014 03:37 PM Click Here to See the Profile for Kfa171Send a Private Message to Kfa171Edit/Delete MessageReply w/QuoteDirect Link to This Post
^ i am talking about if im using the flywheel out of a series 2 3800sc
Darth Fiero
Total ratings: 361
Report this Post12-08-2014 05:36 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need a manual transmission flywheel from a 1996-02 Camaro/Firebird 3800 Series 2 N/A 5-speed application to start.
You can buy new replacement flywheels for this application from almost any auto parts store but I have encountered issues with several aftermarket brands. Specifically: casting voids that appear during the machining process that must be done before you can use it in a Fiero swap (the casting voids are the result of poor casting quality). I haven't had this issue with any GM-made flywheel, but the only place you are going to find one of these today is a junkyard.
Whichever flywheel you end up with needs to be machined down to 0.810-0.840" overall thickness to work with the Fiero manual transmissions.
After you have it machined down, it really should be balance-matched to the specs of the stock 3800 Series 2 SC auto trans flexplate you took off the engine because the N/A flywheel is balanced to a different external weight spec than the SC engine requires. Failure to do this could result in a vibration problem which can shorten the life of the engine's main bearings, depending on how bad the imbalance is. A good machine shop should be able to mount the flywheel and flexplate you give them on their machine without your crankshaft. But not all machine shops will have the ability to do this. There used to be a guy on this forum who said he could do it for people but I don't know if he is still offering this service.
A good machine shop can mount the flexplate and spin it up on their crank balancing machine to get a reading of the amount of imbalance there is in it and where that imbalance is in relation to how it mounts on the crank; and then they should be able to match the flywheel's balance to that spec by drilling new holes in it.
You will need 8 new GM flywheel to crankshaft mounting bolts, p/n: 24505092. Torque to 11 ft/lbs + 50 deg turn. If you buy bolts other than these to use to mount your flywheel to the crankshaft, DO NOT use these torque specs because these torque specs are only valid for the GM bolts. To my knowledge, ARP does NOT and NEVER HAS made 3800 flywheel to crankshaft mounting bolts. They do make a generic bolt that some people have used for this purpose, but you cannot use the GM torque specs when installing them. I do NOT recommend using anything other than the genuine GM bolts for this application.
The bolt pattern on the crankshaft where the flywheel/flexplate mounts is an irregularly spaced bolt pattern - which means all 8 holes will only line up when the flywheel/flexplate is installed in the properly clocked position. Start all 8 bolts by hand and insure you can install and turn all of them in (at least a couple of turns) BY HAND without any binding up due to some holes being misaligned.
-ryan
OVERKILL IS UNDERRATED
[This message has been edited by Darth Fiero (edited 12-08-2014).]
Kfa171
Report this Post12-08-2014 06:06 PM Click Here to See the Profile for Kfa171Send a Private Message to Kfa171Edit/Delete MessageReply w/QuoteDirect Link to This Post
So im getting my engine outta a 2003 grand prix so the flex plate on that will be not use to me.... is there any way i can make the 2.8L flywheel work in my swap... im trying to do the most cost affective solution.
Kfa171
Report this Post12-08-2014 06:30 PM Click Here to See the Profile for Kfa171Send a Private Message to Kfa171Edit/Delete MessageReply w/QuoteDirect Link to This Post
Kfa171
Member since Oct 2013
so im getting a 3800sc so i probably should get a 3800sc flywheel right, or is there no difference.
Darth Fiero
Total ratings: 361
Report this Post12-08-2014 07:36 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock 2.8L Flywheel will NOT work on a 3800 engine, period.
The 3800 SC engine was NEVER used with a manual transmission in a factory application. The only manual transmission ever put on a 3800 engine from the factory was the 3800 Series 2 N/A engine in the 1996-02 Camaro and Firebird. That's it.
These engines are externally balanced which means there is a counterweight cast into the harmonic balancer and into the flywheel (auto transmission flexplates have weights welded to them). The amount of counterweight is different from SC to N/A versions of these engines, hence the requirement for the balance-match.
mkman
Report this Post12-08-2014 08:33 PM Click Here to See the Profile for mkmanSend a Private Message to mkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try contacting forum member fierorog
He sells machined and balanced flywheels for the 3800sc for use in fiero swaps. I got mine from him and it has been working fine.
Fierorog
Report this Post12-08-2014 09:43 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have more than 40 flywheels out there. Give me a call and I can help you out with all your questions.
Thanks, Roger
cell 319-939-1285
Darth Fiero
Total ratings: 361
Report this Post12-09-2014 09:10 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Roger
cell 319-939-1285
Thanks, Roger. I hoped there was still someone on here who was machining down and rebalancing these flywheels.
Tuna Helper
Report this Post12-10-2014 07:30 AM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Ryan, I bought flywheel bolts, p/n 24501365, came in a bag of 8, supposed to be for a '00 Pontiac model H, I told the parts guy it was for a SC engine. Are these the same bolts, just a different quantity?
Darth Fiero
Total ratings: 361
Report this Post12-10-2014 06:34 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM P/N 24501365 bolts are automatic transmission flexplate bolts for the 3800 Series 2 and 3 engines. These bolts will be TOO SHORT for a manual transmission flywheel, which is much thicker than an automatic transmission flexplate.
Tuna Helper
Report this Post12-10-2014 09:42 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, thanks. I'll pop into the dealer and try to exchange them.
Darth Fiero
Total ratings: 361
Report this Post12-11-2014 10:55 AM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a 3800 manual transmission flywheel, you need 8x GM P/N: 24505092.
AutoMarshal
Report this Post12-11-2014 10:42 PM Click Here to See the Profile for AutoMarshalClick Here to visit AutoMarshal's HomePageSend a Private Message to AutoMarshalEdit/Delete MessageReply w/QuoteDirect Link to This Post
.....and 6 of GM part# 24571667 for the clutch to the flywheel bolts. Use red thread lock on these bolts as well as the 8 flywheel to crank bolts.
Torque specs:
flywheel: 11 lb/ft + 50*
clutch: 15 lb/ft + 45*
https://www.fiero.nl/forum/F...2/HTML/000156-4.html
Steepdiver
Report this Post03-05-2017 01:18 AM Click Here to See the Profile for SteepdiverSend a Private Message to SteepdiverEdit/Delete MessageReply w/QuoteDirect Link to This Post
I lnow this is an old thread amd i hate to bring it back from so long dead... but here I go.
So if i get the correct flywheel and have it machined down to the .840 size, and i also have the engine balanced. Will I still meed to have the fly wheel balanced? Or do i send it in with the engine internals and have it all balanced at the same time? I have been told the engine balence spec is 50%.
If there is someone that can help me clear this in my head please do so. I have been beatting my head aginst a wall for awhile now and not able to find a clear answer on what and how to balance all this when having the engine balanced.
paulsobj
Report this Post03-05-2017 09:06 PM Click Here to See the Profile for paulsobjSend a Private Message to paulsobjEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to say a little different then most people. I am not saying they are wrong or that my way is better but budget and other factors will make each build unique.
There is two variables to consider. One if the thickness and the other is the balancing.
The most prevalent way is what is talked about in this thread. Most don't tear the block down and when you don't the best way to get the FW balanced would be to use the flexplate to replicate the balance to the FW. Some things that I noticed is the stock balancing in these was sub par to say the least. So replicating the flexplate will still give you a poor balance. Now lets say that something happens to the FW down the road and you cant use it to balance another one. You will need to get a stock flexplate again or save your original one. Lets say you need to get it resurfaced. I see many people balance the FW by drilling holes on the face side. Now when you resurface it the balance will be off. One way to get around that is drilling on the back side. BUT if you are not taking the block down or not balancing the rotating assembly this is probably the best option.
The other popular way in this swap is to machine it down to .840 or less. The thickness of the FW after machining it down is a fraction of the stock thickness. It is required to machine it down to clear the bell housing. It's like taking off 1/4" or IIRC 40%. Now when you start getting a FW that thin you can start to have problems with warping.
The way I did it is leave the FW stock thickness which can be done with a 1/4" spacer between the bell housing and the block. I can make one for you if need be. This will let you keep the stock thickness to have less of a chance of warping, don't have to find a machine shop and pay to get it machined. And as mentioned run the risk of finding voids in the casting for after market FW.
For balancing the FW. Take the whole rotating assembly to a shop specializing in balancing engines. This is to include the crank, connecting rods, rings, pistons, wrist pins, harmonic balancer, FW, and bearings. Note you may want them to check out the crank prior to purchasing bearings as it may need to be ground down. Regardless make sure they give it a high polish. They should, but ask, balance the crank to the FW. The FW is weighted stock. Now when you may ever need to replace the FW or get it resurfaced for that mater. You will have to do no machining or balancing at all but resurface (if it needs it) it and pop it on.
If you would like more information check out my build where I have plenty of pics and more information about rebuilding the block. I have noticed that many people seem to not want to do a full engine rebuild but budgets and experience sometimes make decisions for us. 88 3800SC F23 Build
[This message has been edited by paulsobj (edited 03-05-2017).]
Steepdiver
Report this Post03-05-2017 10:47 PM Click Here to See the Profile for SteepdiverSend a Private Message to SteepdiverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the info, and i have been watching you build very closly. I was just having a problem understanding the FW balance when you were doing a complete rebuild, and balancing the rotating assembly.
If someone else has some input as i know there are many schools of thought on this, I would love to hear them. You know how it is, informed decisions and all. I am only going to get one shot at the engine this deep. The wife would kill me if I have to go back in and do it a second time.
larafan
Report this Post03-06-2017 09:06 PM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
My flywheel from Fierorog is great!
Jkoze1
Report this Post03-20-2017 08:29 PM Click Here to See the Profile for Jkoze1Send a Private Message to Jkoze1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if fierorog is still doing the flywheels?
TCATTC
Report this Post04-18-2017 04:22 PM Click Here to See the Profile for TCATTCSend a Private Message to TCATTCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I probably missed this somewhere but when you get your flywheel milled and balanced, what clutch fits?
GodSend
Report this Post05-01-2018 03:47 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry to drag this old post out, but a quick question.
If I am mating my 88 getrag 5spd up to a 3800sc from a 98 buick that had an 4T65HD auto attached to it, can I use the flexplate that was attached to the auto flywheel with my new (machined down) Camero manual flywheel?
Report this Post05-02-2018 10:16 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A flexplate is only used with an automatic transmission. A flywheel is used with a manual application. Yo can't use both of these together. For the manual all you need is the machined 3800 flywheel and a stronger clutch. For stick applications, the flexplate that came with the 3800 is discarded.
