  Bleeding air from the thermostat housing
Bleeding air from the thermostat housing by Zeak
Started on: 12-16-2014 11:20 AM
Replies: 6 (601 views)
Last post by: fierosound on 12-20-2014 07:38 AM
Zeak
Report this Post12-16-2014 11:20 AM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was poking around the Cave to see how to burp air from my system.
Wanted to ask for thoughts on a coolant drain valve that would be mounted to the side of the thermostat housing.
My thinking is to braze or weld a small tube to the outside of the neck as to not interfere with thermostat itself.
Just run the engine and slowly crack the a little at a time to release the air. (high point in the system)
Thanks!
-Photo belongs to polaris_5256
1988 Fiero 2.5
Total ratings: 206
Report this Post12-16-2014 11:42 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The system bleeds air into the overflow tank in front. Just keep the overflow tank at the proper level.
Coolant enters the radiator at the top and exits from the bottom, trapping any air in the system. The air is forced into the overflow tank when system pressure due to heat exceeds the pressure rating of the cap. As the system cools, vacuum pulls coolant from the overflow tank into the radiator.
You are fixing something that is not broken.
Zeak
Report this Post12-16-2014 11:46 AM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, Good to know. Thank you.
It scares me to death that I'll mess this up and crack/ warp something.
It makes me feel better knowing it's not as troublesome as I thought.
Total ratings: 206
Report this Post12-16-2014 12:15 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you get ready to add coolant, follow this procedure.....
With car level, and the front cap off, add coolant via the engine thermostat housing (thermostat removed) until the radiator is full.
Install the radiator cap.
Continue filling the system thru the engine thermostat housing until the engine is full.
Fill the driver side coolant tube by pouring coolant down the coolant hose attached to the thermostat housing until the system is full. Fill the front overflow tank with coolant.
Replace thermostat housing cap, start engine and run for a few minutes while checking for leaks.
Remove thermostat housing cap and top off coolant. Repeat until no coolant needs to be replenished. Reinstall thermostat.
Monitor level in front overflow tank to prevent it from emptying.
Report this Post12-16-2014 04:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've just making a update to filling/burping page...
(Coolant Fill)
Tstant housing Does Not need air bleed.
When all seals caps etc are good, air bubbles Will move to radiator when engine is running.
Bad cap or housing are problems But Good parts can fake problems because can take 1 to several heat cycles to purge air out of system.
Formula88
Total ratings: 554
Report this Post12-18-2014 11:39 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
(Coolant Fill)
This.
fierosound
Total ratings: 286
Report this Post12-20-2014 07:38 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tstat housing Does Not need air bleed.
Agreed! All I've ever done is "2 steps" below...
Step 1
Step 2
I then monitor the coolant level in the overflow tank.
Calgary time/temp
