  Suspension differences (Page 2)
Suspension differences by xaver
Started on: 01-05-2015 01:10 PM
Replies: 71 (3401 views)
Last post by: Yellow-88 on 04-05-2016 10:18 PM
Neils88
Total ratings: 56
Report this Post01-06-2015 08:18 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:
I guess my Cruze Eco was a sports car too then. It has more power and better handling than a Fiero. It also has 4 doors, car seat anchor rings, ample trunk space, lots of air bags, anti-lock brakes, traction control, and I got up to 48 MPG on the highway with it.
Just wanted to weigh-in on this little argument that you two were having. (Sorry to take the thread back off topic again )
I've always viewed the term "sports car" really to have very little to do with specific performance numbers. To me, the term refers to the feel or "spirit" of a car. Think back to the old European sports cars (MGB, Triumph, Austin-Healey, Jag, etc). There are many "family" cars that will blow away these sports cars, but the inner essence of a true sports car will always shine. I will happily say that the GM engineers had always intended the Fiero to be a sports car, it was only because of management that it's performance was toned down so it could be considered a daily commuter.
Larry Nakamura
Report this Post01-07-2015 12:50 AM Click Here to See the Profile for Larry NakamuraSend a Private Message to Larry NakamuraEdit/Delete MessageReply w/QuoteDirect Link to This Post
From Automotive Engineering Mag (Oct 1987);
Both the front and rear suspensions of the Fiero have been enhanced. Front
suspension changes include:
* Elimination of the front steering damper assembly
* 30% shorter spindle length (90 vs 64 mm)
* 30% shorter scrub radius (49 to 35 mm)
* 20% reduction in king pin angel (7.5 to 6 degrees)
* 20% longer upper control arm length (177 to 214.2 mm)
* 25% longer lower control arm length (280 to 350 mm)
* Larger stabilizer bar (22 mm to 28 mm)
* 12% shorter turning radius (11.4 to 10.2 m)
Rear suspension changes include:
* Revised chasis cradle design for suspension attachments
* New tri-link design allowing for specific tuning of each component
* Increased rearward rear wheel motion with jounce for reducted impact harshness
* Lower spring rates (44 to 25 N/mm)
* Inclusion of 22 mm stabilizer bar with WS6 suspension package
This is the changes from the 87 to 88 suspension. As I recall GM told the engineers to
use off the shelf parts for the 84-87 suspension (Chevet suspension parts). In 88 they
spent 30 million dollars to develope the suspension for the 88 and was said the be
comparable to the corvette suspension (back then). Prior to 88 the rear springs would
clank together when you went over a speed bump. The fix they suggested for this was
to take a garden hose the cut it to wrap it around the springs.
I had an 86 SE originally and whan I test drove the 88, the difference was night and day.
I traded in the 86 to get the 88GT which I still own (original owner all these years). Hope
this helps you.
[This message has been edited by Larry Nakamura (edited 01-07-2015).]
zzzhuh
Report this Post01-07-2015 02:32 AM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
this helps you.
88GT also has more options and includes a WS6 package from what I can gather. 86SE didn't come with WS6. Im sure it was in fact a difference but "night and day?" Guess everyone has their own opinion.
tshark
Total ratings: 68
Report this Post01-07-2015 07:57 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm. I thought my '86SE had WS6. Anyone who can check their RPO codes & verify?
I certainly notice the steering & bump steer improvements in my '88.
Bloozberry
Total ratings: 311
Report this Post01-07-2015 08:10 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
According to Gary Witzenburg's book (page 76), the '86 SE's came standard with Y99, but then the standard engine for the SE was the four cylinder. If you opted for the available V6 in an SE, then it automatically came with the WS6 suspension.
Formula88
Total ratings: 554
Report this Post01-07-2015 08:19 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by xaver:
I am just checking as my friend told me there is a difference and I am preparing myself and getting parts ready for restoring my Fiero.
Thanks!
With regards to this question, essentially 84-87 are interchangeable and 88 is unique. There are exceptions, but if you follow that rule of thumb that should cover most bases.
WS6 vs Y99 or base suspension did have different springs or maybe shocks, etc., but when buying rebuild parts you're not going to be buying OEM WS6 shocks, so the difference is lost. New technology parts are going to be better anyway. (KYB or Koni over OEM AC Delco shocks, etc.)
Brakes are also different on 88. Your safest bet is to consider everything 88 unique, and all other years share a common design.
masospaghetti
Report this Post01-07-2015 08:27 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never driven a 88, but I can say that the bump steer characteristic of my 86 was fairly severe when I got it - However - replacing the control arm bushings and mounting the cradle in with poly bushings made a huge difference.
xaver
Report this Post01-07-2015 08:41 AM Click Here to See the Profile for xaverSend a Private Message to xaverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! :-)
So according to what I have read here, I am considering putting GT or GT-like suspension in my SE Fiero as the chassis is in best condition on that one. I suppose there are also different mounts on 88 GT, am I right? I mean, I cant put 88 control arm to 84 without replacing the whole thing it is mounted to (sorry, I cannot explain myself well in english).
I have decided which chassis will be restored, but I havent made a decision on the suspension, yet, as I havent got enough of information..
Report this Post01-07-2015 08:49 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 85 GT had the WS6. Pushed under power in turns, rattled teeth over bumps.
My 86 SE had the heavy duty and ralley sport suspension options. Better handling and ride under all circumstances than the 85 GT.
My Formula also has the WS6. Entirely different animal than either of the earlier cars. Excellent ride quality and the handling is in an entirely different universe.
Report this Post01-07-2015 08:51 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
Both cars were V6/4 speeds.
My Formula also has the WS6. Entirely different animal than either of the earlier cars. Excellent ride quality and the handling is in an entirely different universe. Formula has 4.9/4T60E.
Oops! Wrong button.
Edited for drivetrain information.
[This message has been edited by olejoedad (edited 01-07-2015).]
Report this Post01-07-2015 08:55 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That does not match up with my observations on my car, or several of the cars I have worked on.
Perhaps it was only available as an option if the V6 was ordered.
jmbishop
Total ratings: 169
Report this Post01-07-2015 09:23 AM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can verify it on my 84
tshark
Total ratings: 68
Report this Post01-07-2015 09:57 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting. And no '84 came with the V6, AFAIK. My '86 SE had the V6. So, it was probably just an option. Unless that '84 is an Indy.
Oddly, I don't recall seeing the WS6 on my '88 GT, but then it has a lot of group codes.
jmbishop
Total ratings: 169
Report this Post01-07-2015 10:02 AM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a indy, just a 84 with the rpo code pictured, it even had the 3 spoke steering wheel.
dobey
Total ratings: 371
Report this Post01-07-2015 10:18 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
WS6 was a suspension option on all years of Fiero. Every Fiero I've ever owned has had it. They were all GTs, and all 85-87 cars. There are very few options that were 88 only, but WS6 isn't one of them.
Report this Post01-07-2015 10:55 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
WS6 was standard equipment on all year GTs.
zzzhuh
Report this Post01-07-2015 03:20 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
So all GT's came standard with WS6, but the other's had the option? I never knew. Is it rare for an 84' to have the WS6?
dobey
Total ratings: 371
Report this Post01-07-2015 03:27 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know how rare it is. I'd have to know the production count for total 84s and how many shipped with that option.
edfiero
Report this Post01-07-2015 03:28 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im not positive but in 84, I thought WS6 was standard on the SE, and not available on the lower trim levels.
Formula88
Total ratings: 554
Report this Post01-07-2015 03:31 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know about all years but in 88 you got WS6 standard on GT and Formula and it was not available on the coupe.
There are many options that are tied together. WS6 may have it's own RPO code, but that doesn't necessarily mean it could be selected on a non-GT. (maybe, I don't know)
Formula88
Total ratings: 554
Report this Post01-07-2015 03:34 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Formula88
Member since Jan 2001
Thank you! :-)
What do you mean by "chassis?" If you're rebuilding the suspension, much of what you have will be replaced anyway. No, you can't easily put 88 parts on a non 88. It can be done with fabrication but things mount differently, dimensions are different. Even the engine cradle is different. The struts in the rear mount in a different location. They can be overcome. Some people have put an entire 88 rear cradle with 88 suspension in pre-88 cars. If you have an 88 to rebuild and want the 88 suspension, that would be FAR easier than trying to retrofit stuff onto an earlier year.
What cars do you have to work with and what condition are they in?
xaver
Report this Post01-07-2015 04:23 PM Click Here to See the Profile for xaverSend a Private Message to xaverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, so I will build that 84 SE. That one is in best condition, considering the others. Is not after an accident nor has been used for parts previously, which both of my GTs, 86 and 88, has. All it needs to run is engine replacement, which I believe I have one functional (or should be able to build one from three 2,8 engines I have). If driveable, I will begin to replace suspension parts with new ones. I just needed to know whether I could put in GT parts. If you say I cannot put GT parts in non-GT vehicle without a lot of useless work done, I will consider it as a final decision :-)
Thank you all for help
dobey
Total ratings: 371
Report this Post01-07-2015 05:06 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 84 has no provisions for the V6, so it will be a lot more work to swap in the GT parts to the 84 chassis. You'll want to use the cradle from the 86. You'll probably want to swap the headlights from the 88, to get the second generation motors, if you still have them. Most of the parts from the 86 should be boltable to the 84 with little problem. The suspension on the 88, including the cradle, is a fair bit different, so if you want to use those parts it will be a lot more work.
Also, the 86 and 88 engines are a bit different. The 88 is a bit better, so I'd suggest using as much from it as possible. You'll also want to change the wiring to the wiring from the newer car as well, and probably swap in the GT gauge cluster and center dash pieces, to get all the GT gauges.
jmbishop
Total ratings: 169
Report this Post01-07-2015 05:08 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use the 86gt parts as bolt in parts on a 84. The 88 cradle can be used in a 84 if you modify the strut towers and use coil overs. The rest of the cradle bolts in.
The 88 front suspension can be used with much more cutting and welding.
Report this Post01-07-2015 05:12 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
For clarification.......
Any pre-88 GT suspension part can be installed on any pre-88, and any 88 GT part can be installed on any 88.
Installing 88 rear suspension parts on a pre-88 requires installing an 88 rear cradle in the pre-88. It is not a hard or complicated project.
Installing 88 front suspension parts on a pre-88 requires installing the 88 front cross member into the pre-88. It is a difficult project.
Report this Post03-25-2016 01:26 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
An old thread but it's the closest I could find for my question.
What is the difference in the 84 cradle, compared to 85-87 cradles? Any mods like motor mount holes needed to mount a V6 ?
Participating in a gun buy-back program because you think that criminals have too many guns is like having yourself castrated because you think your neighbors have too many kids. Unknown
The preceding was sent on my 6 year old Dell Dimension 2350 desk top with CRT monitor and dot matrix printer.
Report this Post03-26-2016 07:28 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, the transmission mounting holes are in the same location. You may need to do some work on the passenger side engine mount. The damper used on the V-6 (85-87) on the passenger front should be easily mounted by drilling and tapping holes in the cradle front cross member.
The 84 wiring harness doesn't support the V-6, and the wiring bundle below the rear window is not in a good place when using a V-6.
Report this Post03-26-2016 10:18 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Joe. We have an 84 cradle that had a V6 on it. Didn't know if other mods were needed to fit it into a later year car.
Report this Post03-26-2016 02:16 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 toe link anchor location is slightly different, all cradle to chassis mounting points are the same.
Report this Post03-26-2016 06:03 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Again, thank you. Doesn't seem like that would be a problem.
Yellow-88
Report this Post04-05-2016 10:02 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The over all differences of an 84-87 vs. an 88 isn't a HUGE difference, how ever the one I drove seemed to turn easier and didn't pull my arm out of socket when I went on awful roads, that tend to make my 86GT swerve into the crevices of the road.
My 86 Fiero seemed to have a better ride than the 88 Formula I drove but comparing 25+ year old car's are irrelevant. The 88's do handle better but if you swap in some Koni shocks and struts, they will come close.
The difference is pretty close to night and day if both have been properly aligned.
From what I’ve seen, many chassis are very poorly aligned. The 88 is much easier to drive confidently.
Yellow
Yellow-88
Report this Post04-05-2016 10:18 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow-88
Member since Feb 2005
The 88 suspension was not designed by Lotus, despite whatever BS you have been told to that effect. It was designed by GM. If you want to look for Lotus involvement in domestic GM products, then the 89 Corvette ZR1 is where that development happened, resulting in the release of the production ZR1 in 1990.
I said it was far better. I didn't say it was perfect, or a sports car. I said it was closer to being a sports car.
And just because the 88 suspension is better, doesn't mean you will necessarily be able to tell the difference in the driver seat. A simple drive doesn't show you the engineering changes that were made. The suspension is far better, but the geometry is still almost exactly the same as previous years.
That's a common story about the 88 suspension. I won't vote ether way but look closely at the geometry of the front end and you'll see that it has Chapman written all over it. I'm not so sure about the rear. It's very nice but not really him.
Yellow
