  battery leaking around sides and caps
battery leaking around sides and caps by petehiggins75
Started on: 01-18-2015 09:03 PM
Replies: 8 (278 views)
Last post by: theogre on 01-22-2015 12:29 AM
petehiggins75
Report this Post01-18-2015 09:03 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
First off,thanks to each and everyone who has helped answer my questions and help and on the starter issue,it is dragging due to not being shimmed,now,ive replaced my battery twice,brand fn new and noticed that thesides are wet as well as around the caps when i go to pull it out at night,bc we all now cold will zapem quick,especially with the starter any ideas?!
Report this Post01-18-2015 11:06 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Acid Wet? or just water?
Acid wet is a big problem.
Battery "boiling" cause acid leaks from over charge can kill them fast.
new Battery is bad from store
Check volts at battery
when engine runs.
battery disconnected 1-4 hours
Dieing/dead battery can be cause other things on... See my Cave, Battery Leaches
Report this Post01-19-2015 10:16 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
To determine if it is water or not, sprinkle some baking soda on the liquid and see if it bubbles.....battery acid will bubble. Rinse the surrounding metal with lots of water or you will have corrosion problems.
fastblack
Total ratings: 50
Report this Post01-19-2015 05:14 PM Click Here to See the Profile for fastblackSend a Private Message to fastblackEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are needing to pull the battery every night to keep it from draining then you have other problems. While cold is not exactly great for car batteries it won't "zapem". I don't drive my Fiero in the winter but my truck's battery and my wife's Jeep's battery do just fine all winter long. Lowest temps they'll see all year are probably around -15ish (Fahrenheit), maybe lower, maybe higher.
Report this Post01-19-2015 07:44 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1 Cold temperatures don't kill a battery.
The biggest reason for acid leakage on a new battery is overcharging. That could be caused by a bad alternator...which in turn may be the source of your current draw (which forces you to take the battery out.....)
so If you determine that the battery leaks, suspect your alternator.
Report this Post01-20-2015 01:45 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shouldn't If you drive every day or three and weather < 0°F.
Don't drive enough or have float charger connected and load for ECM and Radio standby power can drain a cold battery enough to allow it to freeze. Most times, Frozen battery is junk even then thawed.
see http://blogs.cars.com/kicki...-battery-freeze.html
petehiggins75
Report this Post01-21-2015 02:14 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks again everyone 😃my mechanic saidit could just have been overfilled when manufactured being a sealed battery and moving it around can possibly cause some minor leaking
fierosound
Total ratings: 286
Report this Post01-21-2015 02:17 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed. The alternator may be overcharging OR you're boiling the battery. Do you have the heat shield in place?
Report this Post01-22-2015 12:29 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most times... Over charging and/or dead cell cause battery boil.
Missing heat shield won't. Can shorten battery life etc but not boil.
