  1988 Fiero rear wheel bearing upgrade for durability (Page 2)
1988 Fiero rear wheel bearing upgrade for durability by Steven Snyder
Started on: 01-22-2015 04:22 PM
Replies: 54 (5780 views)
Last post by: fierogt28 on 12-18-2020 02:51 AM
Steven Snyder
Total ratings: 106
Report this Post03-30-2015 02:12 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed my modified knuckles and hubs over the weekend.
Modified knuckle and axle spacer installed:
I had to modify the axle spacers because the fillets on the axles on my car were larger than the fillet on the axle I used as a template. I'll update the drawing when I get a chance, but make sure you confirm fitment by checking for a gap between the spacer and spindle. The gap will be only a thou or two, so use a light to inspect. Enlarge the chamfer if needed.
J-body hub bearing installed (with ARP 100-7708 studs):
I used a new axle nut and axle nut washer from a J-body (not shown). I'm not sure if they're the same as the Fiero parts.
There are three torque specs listed for these hubs, despite the hubs being the same for all years:
1984-1997: 184 ft-lbs (260 N*m)
1998-2001: 144 ft-lbs (195 N*m)
2002-2003: 148 ft-lbs (200 N*m)
from: http://www.speedwayautopart...m/Torque%20Specs.pdf
I do not know the reason for the different torque specs. I used 184 ft-lbs.
[This message has been edited by Steven Snyder (edited 03-30-2015).]
dobey
Total ratings: 371
Report this Post05-20-2015 10:00 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is is still in the prototype stages, but hopefully if it works well under the stress loads of wheel bearings on cars/trucks, there will be some available that would fit the Fiero, at some point.
http://www.popularmechanics...greaseless-bearings/
Just saw this today, and thought I'd share it here.
Bridgetown
Report this Post02-07-2016 10:34 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was browsing the web and found that early wrx sti rear suspension is virtually the same as the 88 rear. What about using the wrx uprights to gain better bearings in the rear? I'm not sure what the wrx axel spline count is, but I'm sure you could mod the fiero axels to work. Other things that would need to be worked out are strut length, swaybar mount, and possibly modifying the trailing link mount. The lateral links look pretty close. Of coarse the bolt pattern would change, but could possibly redrill the hubs back to 5x100. The wheel offset may also change.
If I run across one in the junkyard I may grab it too see if this is feasible.
Here are some pics of the wrx stuff.
Total ratings: 461
Report this Post02-08-2016 12:03 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the Subaru Impreza/WRX/STI wheel bolt patterns are the same as the Fiero... in which case that's a bonus!
[This message has been edited by Patrick (edited 02-08-2016).]
Bridgetown
Report this Post02-08-2016 12:26 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
After further reading I have found that the wrx rear bearings are no better then the 88 fiero's. However, 2005 STI's use basically the same upright, but have an upgraded bearing. The WRX has 5x100 pattern hubs, the STI has 5x114.3 pattern.
Some discussion here:
http://forums.nasioc.com/fo...thread.php?t=1591652
Total ratings: 461
Report this Post02-08-2016 12:46 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
... the STI has 5x114.3 pattern.
That appears to apply only to 2007 and up.
Bridgetown
Report this Post02-08-2016 01:00 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have also realized that the STI has a small drum brake inside the hat of the rotor and serves as the parking brake. This could be a problem to overcome. Perhaps the whole assembled could be eliminated by using the fiero calipers?
[This message has been edited by Bridgetown (edited 02-08-2016).]
Total ratings: 461
Report this Post02-08-2016 02:20 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the drum parking brake necessarily a bad thing?
4thfiero
Report this Post02-08-2016 10:56 AM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dont know if im fully understanding this mod...basically u can install an F body hub onto the rear of the Fiero?? (What car is that off of and what year?)
also, (and there is a reason im asking this) with this mod, could one install a FRONT Fiero hub onto the rear of the Fiero? or no...
Bridgetown
Report this Post02-08-2016 01:35 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
This thread is about installing J body (late 90's cavalier etc.) front bearings into the rear of 88 fieros to get a more durable bearing for racing.
I'm hijacking with talk of using modified Subaru STI uprights to again, get better bearings in the rear.
Bridgetown
Report this Post02-08-2016 01:40 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bridgetown
Member since Feb 2007
Well, maybe not. You would need to try to make the cables work somehow, which could be tricky. The real downside imo is the extra unsprung weight having a drum and rotor brake.
4thfiero
Report this Post02-08-2016 08:11 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting, has anyone tried that?? This upgrade? or is it just a theory at this point??
revson1
Report this Post03-09-2017 12:03 AM Click Here to See the Profile for revson1Send a Private Message to revson1Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I'm building a 88 for Lemons and have begun machining the rear knuckles. What I don't understand is why you need the spacer and where it goes. I know I'm missing something. BTW, great write up in the original post.
pop
Report this Post09-17-2017 05:43 PM Click Here to See the Profile for popSend a Private Message to popEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you saying that improving the wheel bearings will prevent hubs from breaking ??
fierogt28
Report this Post12-18-2020 02:51 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by IXSLR8:
Cadillac Rear wheel/hub update to be used on the front of 88's: I decided to look into this. I've been to wrecking yards and the bearings I have found are all aftermarket. I took them apart and the reason you can not use them is that they all have a crush collar compressed around a lip at the end of an unthreaded shaft. You'd have to take a die grinder and cut parts off until the cap can be removed. The collar is on a lip instead of a threaded shaft. Hence the aftermarket unusability as previously stated. However, I did find one new bearing, made in the USA, that had been sitting on a shelf for a long, long time. It has the nut on the end of the shaft with a cotter pin, under the seal cap. The problem is its only ONE and they are all gone.
I eventually did find two US made New Old Stock Green RW402's. These are the specified 513009 bearing hubs made by Green in the USA. They disassemble and have the large castle nut. BUT, they will not work because the spindle is manufactured from the opposite side of the bearing. The spindle is made on the mount to the cadillac side not the hub side. Total bummer.
Additional note: 1984-1985 (non ABS) Corvette front wheel hubs are a direct bolt in for the Cadillac Seville. But I have not taken them apart to see if they have the same bearing dimensions as the rear Cadillac bearing/hubs. They are more readily available but the nonABS ones are hard to find.
Pretty close to a dead end.
Are the NOS Green RW-405 made in the USA a good bearings?
fierogt28
88 GT, Loaded, 5-speed.
