  Installation of a Turbocharged 3.4L 60 Degree V6
Installation of a Turbocharged 3.4L 60 Degree V6 by oldindian46
Started on: 01-23-2015 11:39 AM
Replies: 16 (757 views)
Last post by: ericjon262 on 01-26-2015 08:12 PM
oldindian46
Report this Post01-23-2015 11:39 AM Click Here to See the Profile for oldindian46Send a Private Message to oldindian46Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm planning on installing a 3.4L with turbocharging from a 1990 Turbo Grand Prix 3.1L. Has anyone attempted this before? Looking for do's and don't.
hnthomps
Total ratings: 50
Report this Post01-23-2015 12:08 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The closest that I can come is using a Mitsubishi turbo on a push rod 3.4 turbo installation. My side scoop is now functional as a cold air intake that will hopefully somewhat improve performance. I used the 19 pound Ford injectors and a customized fuel table to handle a very rich fuel burn issue and have limited the boost to around 7 psi for long term reliability. An intercooler would also be useful but I do not have one on this vehicle.
Nelson
ericjon262
Report this Post01-23-2015 12:36 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
the TGP stuff would probably work, but be far from ideal, that turbo is small on a 3.1l....
"The day I tried to live, I stole a thousand beggars' change and gave it to the rich."
oldindian46
Report this Post01-23-2015 12:58 PM Click Here to See the Profile for oldindian46Send a Private Message to oldindian46Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know turbocharger is small. Budget build. Already have all these parts. Just looking for history at this point
ericjon262
Report this Post01-23-2015 01:24 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
the TGP 3.1 swap has been done before, but not a 3.4 with the tgp hardware that I am aware of.
well, here are my thoughts:
power output will probably be about the same as a tgp, you're taking a downgrade with the 3.4 heads and Fiero intake, and the turbo will max out quickly.
you mention budget, you could probably make more power with a stock 3400 or 3500, for a comparable amount of work.
all that being said, I'm pretty sure the 3.1 uses a slightly different exhaust manifold flange than the 3.4, so the manifolds might not even work at all.
fierosound
Total ratings: 286
Report this Post01-23-2015 01:29 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ericjon262:
the TGP 3.1 swap has been done before...
See here: https://www.fiero.nl/forum/A...130314-2-102091.html
Calgary time/temp
Total ratings: 236
Report this Post01-23-2015 08:34 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The TGP manifolds won't even bolt up to iron heads, will they?
ericjon262
Report this Post01-23-2015 08:51 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think so.
RotrexFiero
Report this Post01-24-2015 09:14 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I turbo'ed a 3.4 to about ten psi. Was fun to drive, spooled up around 3k and could be a problem going around a turn. I had a heck of time getting the idle right. That was the problem, tuning it all. 80's technology was just new to fuel injection.
lou_dias
Report this Post01-24-2015 12:52 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
my experiences with a turbo 3.1 were with a KKK K3 turbo from an 80's Volvo which is about equivalent to a T3.
I had lots of torque from 1800 rpm on but I believe I ran out of fuel at 4500 rpm. I was at 8 pounds of boost. It was a member's car which I bought. Adjustable FPR with fuel pressure dialed up.
It was using a Buick ESC control module. A knock sensor was added to the block and running an expensive MSD ignition. Not the stock looking coil most people swap out.
Running a stock 87ECM but I can't recall if it was chipped... The Buick ESC module dialed back the timing on the ignition from knock sensor input. I forget what injectors were being used.
I had various issues with it all within a year and eventually replaced it with a Fiero Factory 4.9 installation and sold most of the turbo specific hardware to another forum member.
I of course regret that now. The 4.9 swap was it's own nightmare. The turbo 3.1 made more power...just not as reliably/consistently...
For a 3.4 - get a T3/T4 hybrid or go full T4 or equivalent...and a proper ECM to control it and do your homework on fueling.
[This message has been edited by lou_dias (edited 01-24-2015).]
lou_dias
Report this Post01-25-2015 04:23 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since it is coming from a GEN2 3.1, the exhaust ports are probably round (someone please check). However, the manifolds may still not line up when re-connecting to the cross-over after mounting them on iron heads, if that's your intention. If they do, please let us know...if that's your plan. That setup could form the basis of future kits if it does.
Erickson307
Report this Post01-26-2015 10:22 AM Click Here to See the Profile for Erickson307Send a Private Message to Erickson307Edit/Delete MessageReply w/QuoteDirect Link to This Post
also interested in the findings on this i have a 3.4 and well a turbo couldn't hurt
hnthomps
Total ratings: 50
Report this Post01-26-2015 01:21 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the turbo that I am using on a push rod 3.4 engine:
Mitsubishi GSP T3 KKR480 T480 Turbo RB25dt SKYLINE SILVIA
Nelson
Slowbuild
Report this Post01-26-2015 03:56 PM Click Here to See the Profile for SlowbuildSend a Private Message to SlowbuildEdit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Report this Post01-26-2015 07:14 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
they are round, but the bolt pattern for the gen2/3 exhaust flange is taller than the gen1, so they won't bolt on.
lou_dias
Report this Post01-26-2015 07:47 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
The flange holes can always be slotted...no?
[This message has been edited by lou_dias (edited 01-26-2015).]
ericjon262
Report this Post01-26-2015 08:12 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
it's not impossible, but they are beefy cast iron, machine shop job for sure.
