| quote | Originally posted by thesameguy:
Dude, it's winter in BC, what do you expect? The same behavior as summer in Nairobi?
Check a map. I don't live north of the Arctic Circle. I dare say that the weather in Vancouver for a good part of the year is a lot warmer than in many parts of the States.
For you to imply that your "science" doesn't measure up with what I've observed with my own Fieros only because it's so
supposedly cold here is grasping at straws. If it was as cold here as you seem to suggest, I would never have had any impetus to investigate options in regards to fan switches.
Run an excessively cold fan switch because it helps you sleep at night.
What helps
you sleep at night... coming across as an arrogant ass?
[This message has been edited by Patrick (edited 03-24-2015).]
