  Differences in Duke cylinder heads
Differences in Duke cylinder heads by Slammed
Started on: 04-01-2015 12:22 AM
Replies: 20 (696 views)
Last post by: Slammed on 04-10-2015 07:57 PM
Slammed
Total ratings: 79
Report this Post04-01-2015 12:22 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is actually for an S10. I've decided to forgo a swap and settle for a measly 120ish HP I can squeeze out of the duke. MPG, cost and all that. I figured I could hog out the intake mani/head, bore the TB, build a header and a mandrel 2.25" exhaust. I've got a flow bench and have ported dozens of cylinder heads so this is something I'm very comfortable with
Any good cam profiles? I think after 86? they were all roller cams
Last iteration of the duke '91-93 S10s had 105hp. I know that head is not a swirl like the Fiero duke, but I don't know what else. As far I've learned 89-90 didn't have swirl but the bowls weren't as deep, and they didn't have the exhaust ports with the raised floors,
Is the tune significantly different for the S10 in those years? New PCM? They weren't DIS so hopefully the wiring isn't too different. Aside from a cam and gaskets, it shouldn't cost me a dime so I'm gonna have some real fun with this
Total ratings: 463
Report this Post04-01-2015 06:33 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
TopNotch, on this forum, did some interesting things with the Duke in his car.
He'll probably pop in at some point. If not, run a search on his name. He posted a fairly detailed thread.
Praise the Lowered!
Slammed
Total ratings: 79
Report this Post04-01-2015 06:57 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I read through his thread. It's too bad there aren't more people doing the simple stuff to dukes. I've read A LOT of "just swap it" and "it isn't worth it"
Head swap and a prom change and you're looking at 20hp right there. What? $100? Worth it.
I'll have before and after dyno sheets
Slammed
Total ratings: 79
Report this Post04-01-2015 11:36 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Slammed
Member since Mar 2015
Finished with the raw material removal on the intake. Thinking about cutting out the dips on the top and welding in some flat plate
This is an '89 head. Bowls look like this
Sonic shows the right side of the intake pocket is only about 5mm thick. Gotta be careful
DisplacementIsKing
Report this Post04-02-2015 06:17 PM Click Here to See the Profile for DisplacementIsKingSend a Private Message to DisplacementIsKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in the middle of the same project, I have an older gm reman 2.5 with ~100,000km's.
I have a holley TBI, will bore the hole to 2" then port match the head and intake manifold and modify a set of shorty SBC headers.
That 89 head looks to have more bowl volume then the swirl port head, if so you will drop your compression ratio.
Slammed
Total ratings: 79
Report this Post04-02-2015 07:31 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're confusing bowl and combustion chamber. And this isn't a swapped head, this is the factory head on the S-10. The chamber volume is the same as the 87-88 Fiero head. There isn't much material for "port match" and you will see very little if any gains without a real porting job
DisplacementIsKing
Report this Post04-02-2015 08:11 PM Click Here to See the Profile for DisplacementIsKingSend a Private Message to DisplacementIsKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok yeah that's what I meant, I have a swirl port head which was on the 82-86 I believe which are junk for flow. I read that the later year heads were better like yours. The problem with porting work is that the head is so thin you need to be careful.
Back to your post, if your looking for a mild cam for a roller lifter set-up, the fierostore sells one, If you want to switch to a flat lifter set up there are more choices, found a few on summitracing.
Slammed
Total ratings: 79
Report this Post04-02-2015 09:35 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Custom cam grinds can be had from Delta for $85. I'm going to tune this best I can before changing the cam so I can choose the best profile
[This message has been edited by Slammed (edited 04-02-2015).]
Slammed
Total ratings: 79
Report this Post04-03-2015 12:50 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I soniced the intake ports tonight and all the bowls. I won't be touching the exhaust aside from bullet nosing the guides and a polish. There is plenty of meat everywhere aside from the high side of the intake bowl and the pushrod pinch point (obviously)
Should have some flow numbers following this weekend
sardonyx247
Total ratings: 219
Report this Post04-04-2015 02:03 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
The most aftermarket I have seen for the dukes come from midget class racing suppliers. as they used 2.5s
Maybe something to look into.
Slammed
Total ratings: 79
Report this Post04-06-2015 07:40 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got most of the roughing in on the heads. Still have to smooth out the chambers and exhaust bowls/ports.
TopNotch
Total ratings: 60
Report this Post04-07-2015 06:11 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you had your head checked for cracks before you put all that work into it. Duke heads are prone to crack, and there can be micro-cracks you can't see.
Anyhow, here are some links on my duke rebuild threads:
Head thread
Rebuild thread
Slammed
Total ratings: 79
Report this Post04-07-2015 09:06 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
It only has 68k on it and I magnafluxed it when I pulled it
I've been an automotive machinist for 12 years now. I've got everything at my disposal for this build
Excellent job btw.
[This message has been edited by Slammed (edited 04-07-2015).]
DisplacementIsKing
Report this Post04-07-2015 09:56 PM Click Here to See the Profile for DisplacementIsKingSend a Private Message to DisplacementIsKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was also thinking about taking material off the guides to better the flow but aside from the amount of work, would it compromise the strength?
Also, did the port match last weekend and your right, there was not much material removal...
Head thread
Rebuild thread
Nice build, I like your roller rocker set up!
Slammed
Total ratings: 79
Report this Post04-07-2015 10:09 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
The guides and the short turn are the most crucial part to the port. You will not compromise the integrity doing the guides. We have taken crummy 882 smog heads, done nothing but bowl work, and made +20hp with no other mods
The bowls will only take a couple hours. Do it.
DisplacementIsKing
Report this Post04-07-2015 10:50 PM Click Here to See the Profile for DisplacementIsKingSend a Private Message to DisplacementIsKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's impressive looking to implement this on my even worst swirl port head, what did you use to remove the material from the guides?
How much did you enlarge the intake ports of the head and manifold?
Slammed
Total ratings: 79
Report this Post04-07-2015 11:11 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Single cut carbide burrs for the intake(aluminum) and double cut for the head(cast iron)
When you do the swirl, don't try and eliminate it. The roof and back of the bowl is not that thick, so you want to just widen the ramp slightly into the sides of the bowl and bullet nose the guide. I took about 8.5mm vertically and 3mm horizontally all the way down. I also tubed the pushrod holes and straightened out the pinch until I broke through. Give the short side as smooth of a radius as you can
Do not touch the floor of the exhaust port aside from polishing. You want that as high as possible
Report this Post04-08-2015 01:49 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Liking the thread
Slammed
Total ratings: 79
Report this Post04-08-2015 09:32 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is as far as I'm going to take it. Polishing the chambers past this point would just be for pictures and I really don't care. Customers get bling, not me. The places that look untouched in the chambers are just powder I didn't blow out before the pic
I'll be doing the valve job tomorrow. I'm going to try and fit 1.94s in the intake. If they do, I will enlarge the throat more
[This message has been edited by Slammed (edited 04-08-2015).]
DisplacementIsKing
Report this Post04-08-2015 11:05 PM Click Here to See the Profile for DisplacementIsKingSend a Private Message to DisplacementIsKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks.
Slammed
Total ratings: 79
Report this Post04-10-2015 07:57 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Think I've found some bigger valves that will fit, gonna do some machining this weekend and see what I come out with
