  Fog light hookup .. What fuse to use in fuse box?
Fog light hookup .. What fuse to use in fuse box? by FGT88
Started on: 04-07-2015 04:54 PM
Replies: 8 (2579 views)
Last post by: Blacktree on 04-08-2015 06:20 PM
FGT88
Report this Post04-07-2015 04:54 PM Click Here to See the Profile for FGT88Send a Private Message to FGT88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just hooked up my fog lights and ran the hot lead into the inside of the Fiero compartment... what would be a good fuse to use on the fuse box to work the fog lights the fog light system came with a (on /off switch /with an on led lamp 3 pins)...... pin3 of the switch goes to gnd there are no metal parts so I hooked the gnd wire to one of the screws that hold the fuse box in between the washer and the screw head will this work ? pin#2 hot lead that goes to the 2 fog lights up front pin #3 hot lead has its own fuse goes to the Battery or fuse box.
Thanks I am so so sorry to hear about the loss of a fellow Brother
Report this Post04-07-2015 08:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Type of lamp?
Halogen types need run wire to battery and a relay.
See my Cave, Fog/Driving lights
LED eats allot less power. Can likely just wire into LB HL w/o relay.
FGT88
Report this Post04-08-2015 01:05 AM Click Here to See the Profile for FGT88Send a Private Message to FGT88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
Type of lamp?
yes it is leds not halogen what fuse is the LB HL ? Thanks
Blacktree
Total ratings: 350
Report this Post04-08-2015 10:41 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
low beam headlights
Report this Post04-08-2015 11:13 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
HL have breaker inside HL switch.
Does have a relay or not?
yes... likely plug main into extra "port" in fuse box. https://www.fiero.nl/forum/F.../HTML/095327.html#p3
no... spice to Low Beam same as page link above.
Add a fuse between spice/port and LED because any Fog/Driving light can have problems. Blow at fuse w/o relay stops breaker to "flash" HL.
I believe some/all Ports have no fuse. Even if they do, can keep other things alive when fogs shorts out.
You need total amp used by fog light then fuse = 150% of amp used.
Example: If 18w (total 36w) fog "lamps" draws 3a at 14v then fuse = 5a. (You round up to next full integer.)
rogergarrison
Total ratings: 551
Report this Post04-08-2015 11:27 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
low beam headlights
This is what Ive always done too.
Blacktree
Total ratings: 350
Report this Post04-08-2015 12:24 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I personally prefer to use the parking light circuit to activate a relay which powers the fog lights. But that's because I like being able to use fog lights without turning on the headlights. Using the low-beam headlight circuit to activate the relay will work just as well.
But in either case, I'd suggest using battery power via a relay, rather than using an existing lighting circuit to power the fog lights... even if they're LEDs. You might get away with that, with LED lights. But I still wouldn't suggest it.
[This message has been edited by Blacktree (edited 04-08-2015).]
Report this Post04-08-2015 05:23 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doing this allows parking light and fog w/o low beam or w/ High beam on. Driving like this is illegal in many places.
LB HL circuit only activates fog/driving lights w/ LB is on.
While you can run a relay.... LED 18w (each) draws ~3a total @ 14v. (voltage w/ engine running) Is nothing to Many circuits including HL. You need to know your watts for whatever LED is used.
The small fuse stop HL breaker to trip and auto reset when LED or switch/wire to them have a short. The splice and fuse should be close to HL dimmer switch.
Bigger issue is many use 55w LB and 80w HB or more... ignore legal issue in many states that can cause electrical problems. Even just old switches and plug contacts can heat up with legal HL like H6054 55w/65w SilverStar. Is why Headlights page covers adding relays to HL circuit. Two relays need to be close to HL bulbs to eliminate HL load for switches, C100, etc. And new Fuse/breaker/link near the battery, same as Fuse Link B.
[This message has been edited by theogre (edited 04-08-2015).]
Blacktree
Total ratings: 350
Report this Post04-08-2015 06:20 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre: Driving like this is illegal in many places.
I hadn't considered that. I'm used to Florida's regulations regarding fog and driving lights, which are pretty lenient.
