  Tips for making the sunroof water tight
Tips for making the sunroof water tight by lorennerol
Started on: 04-24-2015 09:14 PM
Replies: 7 (1358 views)
Last post by: Ponnari on 04-28-2015 04:54 PM
lorennerol
Report this Post04-24-2015 09:14 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now that I'm happily living in the world of functional (not caulked shut), OEM sunroofs, I've been noticing some puddles on the seats.
It seems to be dripping from the front corner on the driver's side, and also along the passenger side.
I'm waiting until I have these addressed to put the headliner back in.
So any tips on how best to get the seal between the glass and the weatherstrip water tight greatly appreciated. Also, should the weatherstrip be tight against the roof panel, or is it typical for there to be a small gap here and there?
I'll get some pics tomorrow to post.
Total ratings: 463
Report this Post04-24-2015 09:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by lorennerol:
So any tips on how best to get the seal between the glass and the weatherstrip water tight greatly appreciated. Also, should the weatherstrip be tight against the roof panel...
Water penetration into the cabin when the sunroof is closed has basically nothing to do with the glass panel not being tightly pressed against the rubber seal.
If the four drain holes (one in each corner) are not plugged up with debris (and/or caulking), the sunroof can even be in the popped up position and not leak water into the cabin while driving in the rain.
I've had four Fieros with factory sunroofs ('84, '86, '87, '88) and none of them have leaked water into the cabin... and I live smack dab in the middle of a temperate rainforest, with no garage!
[This message has been edited by Patrick (edited 04-25-2015).]
busa_powered
Report this Post04-25-2015 12:25 AM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
my interior is done minus headliner and carpet so I'm right with you.
My headliner seems to get moist around the sunroof during rain but doesn't drip, I am looking to get mine sealed tight too, just not sure where to begin.
I'm assuming I should my all new gaskets to make sure.
I'll follow this thread
jmbishop
Total ratings: 169
Report this Post04-25-2015 06:32 AM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start with checking the drains as sugested then use a conditioner on the rubber.
ltlfrari
Total ratings: 127
Report this Post04-25-2015 08:31 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can adjust the tabs on the front of the glass by bending them a little to help pull the glass down onto the rubber at the front.
I've also tried various shims behind the catch to give it bit more pull although because of the way it mounts, it ends to 'rock' so the effectiveness of such shims is limited unless you put a 'leg' on the shim that presses against the roof to help stopp it rocking but then you risk pulling the glass too tight and breaking it.
I think part of the reason roofs leak is that the roof itself flattens out over time so that it does not follow the curve of the glass any more. The result is that you end up with gaps that you really cannot do much about. I'm going to paint my car 'son' so at some point I'll have the roof off and I think I'll look at experimenting with supporting the roof from the underside somehow, block of something or other maybe, to try to get a curve back into it.
I got mine to seal after a LOT of work and adjusting while using a hose to check for leaks (plenty of towels inside the car to catch the drips!) but the rule now s "don't open it"!
Dave
www.ltlfrari.com
Report this Post04-25-2015 10:58 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
vista vent type roof leaks often cause by latch holes in the frame are bent.
Remove latch and "studs."
Fix bent holes.
them try adjusting the latch. forward to tighten, back to loosen. Or maybe other way around? Can't remember right now.
84-86 may need drain holes drilled... use search.
[This message has been edited by theogre (edited 04-25-2015).]
lorennerol
Report this Post04-25-2015 11:42 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fix bent holes.
Good info in the thread, thanks all. Interesting that some people can drive with the roof tipped up in the rain and no leaks, and others have struggled to get it water tight at all.
This is a donor roof that I bought removed, so I'm not sure what year car it came from and since the paint shop installed it, I don't know if the holes are there.
Will get and post some pics later today.
Ponnari
Report this Post04-28-2015 04:54 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well this might help, I did it on two of mine and it worked great!
Buy some round shoe laces, the kind that are for work boots / hiking boots.
Pry up the seal and install the laces under the seal on the outer side of the seal, all the way around the seal.
Should raise & thicken the seal so the glass gets pressed firmer into it when closed.
Good Luck!
"Because in a split second, It's gone"
Ayrton Senna
