  400whp
400whp by Nick8434
Started on: 05-17-2015 03:33 PM
Replies: 22 (896 views)
Last post by: RotrexFiero on 05-21-2015 10:50 AM
Nick8434
Report this Post05-17-2015 03:33 PM Click Here to See the Profile for Nick8434Send a Private Message to Nick8434Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know this stuff has been talked about multiple times but still wanna ask. Im looking to get 400whp out of the supercharged 3800 but I am just not decided on my cam choice yet and hoping i can get some input from you guys. My engine what will be done .30 over stage 3 heads ported LIM gen V small pulley of course either intercooler or e-85 northstar headers i know im missing stuff but pretty much everything i can do performance wise is getting done. But im looking at the xpz cam, s3x cam Nic cam i just need what you guys think would give me the most power and the closet to 400whp. I am using the getrag 282 for my transmission. Thank you
dobey
Total ratings: 371
Report this Post05-17-2015 05:53 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
N/A intake and a turbo.
Nick8434
Report this Post05-17-2015 06:56 PM Click Here to See the Profile for Nick8434Send a Private Message to Nick8434Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know it would be cheaper and easier to do but that's okay i'm going to run it with the supercharger for a year or two and then i plan on putting a holset hx40 on it and make 500whp.
Report this Post05-17-2015 09:03 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
With even the better flowing series V Eaton supercharger; 400HP crankshaft HP is about the upper limit of the power that can be produced from a 3800SC. If you want to make 400WHP, (and like superchargers) you will need to adapt a larger Eaton M112 or TVS model. In other words no matter what mods you make the 400 HP goal that you wish to reach cannot be reached without moving more air.
[This message has been edited by Dennis LaGrua (edited 05-18-2015).]
Nick8434
Report this Post05-17-2015 09:11 PM Click Here to See the Profile for Nick8434Send a Private Message to Nick8434Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply good to know well then if any of you had to choice a cam what would you recommend? Ill be drag racing once and a while and driving on the street
mitchjl22
Report this Post05-18-2015 12:06 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly that's a pretty generic statement... there's a lot of factors that can make you produce a lot more power... intercooler, tiny pulley, and e85 would probably get you above the 400hp at the crank mark... but I'm just speculating.
-Mitch
dobey
Total ratings: 371
Report this Post05-18-2015 09:45 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
To get 400WHP with the 282 trans, you'll need to be making about 450-460 at the crank. Even then, it's a pretty arbitrary number that doesn't really mean anything about how the car performs. If you want to drag race, you'll want a cam that pushes the powerband up more into the high end, and that will let you run higher RPM. That will let you spend more time in the acceleration gears. You might need to launch at a higher RPM then as well, which will increase the possibility of breaking something. You'll also need other mods to be able to rev the engine to a broader range, such as valve springs, flow capacity, etc…
Arns85GT
Total ratings: 202
Report this Post05-18-2015 03:12 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800sc can make up to 500 hp. We had one here in London. It took some internal work but it supported 36 lbs of turbocharged boost on high octane.
It was truly a scary ride. I believe the tanny was the 65e
I don't see why a turbo on it won't do 400
dobey
Total ratings: 371
Report this Post05-18-2015 04:49 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You were running 36 PSI on an L67 and only made 500 HP? Several people on this forum have shown the 3800 SC bottom end can make quite a bit more than 500, when converted to turbo. JustinBart's car is making ~900.
The right turbo on a 3800 can easily make 400 to the wheels. The problem is that it's pretty hard to make 400 WHP using the m90 blower. 400 BHP (at the crank) is pretty doable though.
Report this Post05-18-2015 08:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
To those that favor turbochargers...
This past weekend I had the opportunity to drive a friend's ultra-expensive track prepared turbocharged 1999 BMW Z3 M Coupe at an autocross event. The engine in this car is supposed to be putting out 500 HP or so.
When the turbo kicks in... it's exhilarating. However...
The car and engine have been set up for high speed track use. The huge turbo on this engine doesn't do anything until 4000 RPM. It was frustrating as hell at autocross this past weekend as I'd be putting the pedal to the floor and screaming at the engine to do something! I'd be waiting up to two seconds for the power to arrive. Simply wasn't suitable for autocross.
I'm just mentioning this as it was my first experience driving a turbo-equipped car, and it was a little disappointing. Turbo size is obviously critical for a car used on the street and/or at autocross.
[This message has been edited by Patrick (edited 05-18-2015).]
Total ratings: 236
Report this Post05-18-2015 08:58 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it's a '99, that's probably the S52 engine... the S54 wasn't used until build dates of 7/00 and later. I was going to chastise you for using an 8000 RPM engine at 4000 RPM, but that doesn't apply to the S52 as it only turns about 6500-7000 RPM stock.
Report this Post05-18-2015 09:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Will:
...but that doesn't apply to the S52 as it only turns about 6500-7000 RPM stock.
As it isn't my car (Saturday was the first time I'd even seen the car!), I don't know for sure what engine is still in there (as it's recently been all re-done)... but I do recall the red indication on the tach started at 6500 RPM.
RotrexFiero
Report this Post05-19-2015 08:58 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had experience with a turbo 3.1, 3.4, and now the supercharged 3800. The SC is much more drivable. Turbo cars, especially ones with great lag that are sized to spool up at higher RPMs, are just dangerous on the roads around here. We have lots of turns, snow, and slippery roads. A turbo can be like an on/off switch and easily spin out a car like the Fiero (with all that weight in the rear).
I like the idea of a turbo, but for drivability the SC is best. If you are drag racing though, who really cares.
dobey
Total ratings: 371
Report this Post05-19-2015 09:33 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's all in how you build it. The 3800 SC was built with the blower from the start, and was built for boost. The 3.1/3.4 were not (unless you are talking about the turbo 3.1 in the GP). Just with any modification to an engine, you need to tune it properly for the application. Even swapping in the wrong cam in a N/A engine will make drivability suck, but might get you more power in the top end.
The wrong size turbo, wrong compressor wheel, and no or improperly configured boost control, can make for annoying experiences exactly as you described. Go drive a stock OEM turbocharged car, and you'll see there's no lag, and no big "oh the turbo is working now" moment, for most factory installations. They're very drivable. It's all in the tune.
E.Furgal
Total ratings: 278
Report this Post05-19-2015 10:32 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
OEM turbo cars are set up to spool at low rpm.. they are junk over 4500rpm.. for the most part..
what the poster was saying, is to get the higher rpm hp out of a turbo engine you have to give up spool up on the lower end.. this is something you can not bypass.. oem's try and so do trucks with bi-turbo's
and racers with a shot of nos to get the turbo spooled up sooner..
the supercharger will give torque right here right now.. something a turbo engine can not do..
The oems' it's far far past the "tune" it's the gearing.. also.. and the "torque management" both things most can't afford to change..
RotrexFiero
Report this Post05-19-2015 04:53 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I've driven OEM turbo cars -- had a solstice and it was fun. But, like mentioned they are setup to spool at low RPM with no kick so as to make them safe.
My 3.1 and 3.4 were specially built, even had a Rotrex supercharger (centrifugal) at one time. Hence, my handle. Turbos are great for making high amounts of boost, and if you are after power they are the way to go. But, around here, with so many turns and road grades, that kick is dangerous and the rear end can get away from you. A front wheel drive turbo car is not a big deal, but the Fiero is a peculiar animal. You have to remember there is not too many people driving mid-engine machines out there. I wont even let friends drive my Fiero because it handles so different from ordinary every day cars. A high horsepower machine with such odd performance handling characteristics like the Fiero is not forgiving. No to mention my brakes suck!!!
Hey, ever seen a turbo motorcycle? I think Yamaha made one a while back. Crazy.
Report this Post05-19-2015 06:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turbos are great for making high amounts of boost, and if you are after power they are the way to go. But... that kick is dangerous and the rear end can get away from you.
That's exactly what I was thinking when I was driving the turbo BMW at autocross that I was describing earlier. I didn't want to put that expensive car through the fence!
Neils88
Total ratings: 56
Report this Post05-19-2015 06:23 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
My Triumph TR7 had a 15+ psi turbo (Toyota engine). It was dyno'd at 275hp. (Built by RaceTech Engineering in Calgary). The boost cut in around 3000rpm which made it great for driving normally, and still gave "holy crap" acceleration when you pushed the gas just a little bit harder. Absolutely no lag at all.
dratts
Total ratings: 118
Report this Post05-19-2015 09:38 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think that you can just bolt a turbo on and go. My ls4 has an intercooled car tuning turbo kit on it and it's pretty much bone stock. LS7 lifters and valve springs with dod eliminated. If there is any turbo lag I don't notice it.
Total ratings: 236
Report this Post05-20-2015 08:25 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, S52, then.
RotrexFiero
Report this Post05-21-2015 08:31 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
In Corky Bell's book on turbocharging he talks about how many of the Porsches came with undersized turbos. Again for drivability and safety, but after a while if you are looking for power an upgrade can bring about great gains. The 3800SC was made to lug around a 3500lb car, not a little Fiero.
dobey
Total ratings: 371
Report this Post05-21-2015 10:25 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't get why people say this about the 3800, N*, and other motors. The 2.5 and 2.8 both came in plenty of 3500lb cars and S-trucks. I guess they were made for that too, and not a little Fiero.
The turbo Porsches of today are also quite a bit different from the turbo Porsches of yesteryear. On modern engines with modern ECMs and electronic boost controllers, it's possible to have quite complex boost control, changing the boost curve for a wide range of variables, such as Ethanol content of fuel, atmospheric pressure, etc…
Yes, OEM installs are generally tuned for drivability and reliability, to avoid extraneous warranty claims and such, but you can do quite a bit with performance tuning on modern setups.
RotrexFiero
Report this Post05-21-2015 10:50 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, my 3800SC is mated to the Getrag 5 speed. So it is not exactly a good relationship. Yes, it is torquey to drive. But, I never wanted the auto. I mean a sports car is not a sports car without a five speed (or six), and that is definitely an over forty perspective.
I agree. The technologies have greatly changed, but when I did my garage turbo project I could not afford all that. I was just happy it worked!!
