  Is there a trick to bending a Camaro EGR tube to fit the Fiero's 2.8?
Is there a trick to bending a Camaro EGR tube to fit the Fiero's 2.8? by Patrick
Started on: 05-20-2015 02:46 PM
Replies: 34 (2363 views)
Last post by: Patrick on 09-06-2017 02:45 PM
Total ratings: 465
Report this Post05-20-2015 02:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A short while ago I was was posting HERE inquiring about EGR tube alternatives for the Fiero's 2.8 engine. I was able to track down locally an EGR tube from a 2.8 Camaro. I like the fact that the tube appears to be made of heavier gauge metal. The necessary modification to the mounting holes on the one flange didn't take long at all.
However, unlike the flanges on the original Fiero EGR tube, the flanges on the Camaro EGR tube do not rotate. Bending the tube to get it to point in the right general direction is easy enough, but I'm not quite sure how to manipulate the tube to get the flanges themselves in the correct alignment. I don't wish to stress the metal tube any more than I need to... I don't want to crack it! Any tips?
Originally posted by scott0999:
Camaro EGR tube
got mine on ebay, search for camaro 2.8 EGR tube
stock fiero EGR tube on left (flange broke), Camaro 2.8 EGR tube on right. its quite a bit stronger
dobey
Total ratings: 371
Report this Post05-20-2015 03:48 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I can see in the picture, you don't.
Maybe you could grind them off and then modify them so that you can rotate the flanges, but that seems like it would be an awful lot of work.
JohnnyBones
Report this Post05-20-2015 04:09 PM Click Here to See the Profile for JohnnyBonesSend a Private Message to JohnnyBonesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pipe bending jig?
Total ratings: 465
Report this Post05-20-2015 04:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't what?
I've read many times that the Camaro tubes fit a Fiero (with the minor mod to the bolt holes). I'm just looking for the secret to actually lining up the flanges!
There's no way I'm doing all that.
Originally posted by JohnnyBones:
Pipe bending jig?
Well, the pipe itself actually bends easy enough... but I'm not sure how to "twist" it to line up the flanges.
[This message has been edited by Patrick (edited 05-20-2015).]
dobey
Total ratings: 371
Report this Post05-20-2015 05:17 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Don't what?
You don't rotate the flanges to match the Fiero, since you can't rotate them.
I expect given that the Camaro one looks longer, that it might possible to sort of force it into a close enough angle that it sort of lines up, using some creative bending. I'd be skeptical that people who have done that, haven't ended up with cracked EGR tubes again fairly soon though, given the additional stress placed on the material.
I found this post, which only mentions slotting the ends, and links to this picture:
The heat wrap hides how the bends are made, but you can make a pretty decent guess from the picture. I don't know if that actually lines up as is though.
Total ratings: 465
Report this Post05-20-2015 05:34 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect the way that tube is pictured is that it wouldn't line up properly the way it is. I'm also surprised that anyone would actually "slot" the holes to modify them. So little metal needs to be removed that slotting the holes (as pictured) appears to be overkill.
What I may end up doing is to simply attach the tube to both the EGR and to the upper plenum (while holding the plenum at a weird angle up above the engine), and then use the leverage of the attached plenum to bend the tube to fit. Not what I really want to do, but seeing as how there are reports that this EGR tube does fit, this appears to be the easiest way to bend the tube. I just need to make sure it clears the distributor cap and the wiring to the TB.
Dobey, thanks for looking into this further.
dobey
Total ratings: 371
Report this Post05-20-2015 05:44 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's basically how I installed the FS stainless EGR tube on my car. I didn't take the manifold off at all though. I just attached the manifold end first, and then tried to bend it to fit right. The stainless hose tube is flexible, but not terribly so. It can be a bit of a pain to get into the right position; especially if the intake is still on.
Oh, and I am happy to sell that braided stainless EGR tube. Since my 2.8 is seized up and I've already removed a large part of the parts on the top end of it, and I won't be needing it with the LS4, it's just sitting in my pile of Fiero parts that I need to get rid of right now. It's maybe had a few hundred miles put on it since I installed it, so I'd be looking to sell it for around half of what it cost new (so $50 US), shipping included.
[This message has been edited by dobey (edited 05-20-2015).]
Total ratings: 465
Report this Post05-20-2015 05:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
....especially if the intake is still on.
My upper plenum is currently off, so I'll try the method I posted. If I crack this Camaro EGR tube, I may be in touch (after I scream).
dobey
Total ratings: 371
Report this Post05-20-2015 06:36 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I hope you don't crack it and you get it to fit right.
tshark
Total ratings: 68
Report this Post05-20-2015 10:12 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 465
Report this Post05-21-2015 12:35 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, I've got the Camaro EGR tube on for a test fit. The upper plenum is just being held on with four barely-snugged bolts. In the picture you can see the contortions that the tube had to go through to angle up to the plenum. The white arrow indicates a stud that the tube temporarily was pressing on when I first re-bent the tube. I pulled the tube towards the back of the car to clear the stud.
So, this is what a 2.8 Camaro EGR tube looks like when it's been re-bent to fit the 2.8 in an '88 Fiero...
I'll be taking it apart again so that I can install an asbestos jacket from an '85-'87 2.8 Fiero EGR tube. I'll take a picture of that as well and post it. At some point I'll see if I can find something more closely resembling the metal insulation jacket that comes on the '88 2.8 engine.
tesmith66
Total ratings: 135
Report this Post05-21-2015 07:46 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I recall having to install mine like that, but it was over 15 years ago. I do remember never having trouble with it again. I ran it like that for several years, then sold off all of the V6 stuff when I swapped in the V8.
dobey
Total ratings: 371
Report this Post05-21-2015 10:15 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
Crack(ed) pipes not allowed.
I'm just curious how you got the other end of the tube without removing the plenum.
I removed the distributor cap/rotor and enough so I could get a wrench or small socket in there. I probably used my 1/4" drive socket set (I don't really recall what tool I used exactly). And I don't have fat hands, so was able to get in there enough to have the right amount of leverage to get the tube off/on. It certainly would have been easier by removing the top plenum, but I didn't want to deal with needing to replace gaskets for that, or the vacuum connections possibly breaking.
Total ratings: 465
Report this Post05-21-2015 12:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you insulate it, and if so, do you recall what you used to insulate it with?
I believe it's important to keep as much exhaust heat as possible within the EGR tube so as to reduce the heat added to the immediate area around the ignition components.
tesmith66
Total ratings: 135
Report this Post05-21-2015 12:35 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I stuffed it in the old, deteriorating blanket the original was in. It was on an 86.
Total ratings: 465
Report this Post05-21-2015 01:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, that's what I'll be doing for now as well. However...
I just placed a couple of my biggest eBay orders ever. Paid $1 for five(!) stainless steel ties from Thailand, and $2 for 39" of 2" wide header wrap from Hong Kong.
Ponnari
Report this Post05-21-2015 10:50 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recommend using Rodneys EGR Tubes, I bought several over a few years and they all are still in service and perfect working order today.
But I understand, you are looking for a cheap solution. Keep us posted after its run for awhile and let us know how it works.
"Because in a split second, It's gone"
Ayrton Senna
Shho13
Report this Post05-21-2015 11:14 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Big spender! Hopefully it doesn't take a month to show up though... I have had THE WORST luck with international orders recently.
Nice work getting the tube to fit by the way!
"Discord"
( ͡° ͜ʖ ͡°)
Total ratings: 465
Report this Post05-21-2015 11:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you suggesting I'm frugal?
To be honest, it was more of quick solution. I had considered getting Rodney's replacement EGR tube (I love Rodney's products), but keep in mind I'm in Canada and it simply takes longer to get stuff shipped up here.
Yes, the little do-dads I ordered from Thailand and Hong Kong will take awhile to get here as well, but I can still use my Formula in the meantime with the locally purchased Camaro EGR tube.
Yes, I'll post more pictures here of my progress, slow as it may be.
[This message has been edited by Patrick (edited 05-22-2015).]
Total ratings: 465
Report this Post05-21-2015 11:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Originally posted by Shho13:
Big spender!
Heh heh... I thought you guys would get a kick out of that.
I've ordered stuff from Hong Kong and mainland China previously, and the delivery times haven't been that bad. And the cost of shipping simply can't be beat. (It's basically free!)
Yeah, I was pleased that I was able to persuade the tube to orientate itself in that manner. The test will be when I start the engine and see if I've cracked the tube. I don't believe I have, but a 2000 RPM idle speed might tell me otherwise.
[This message has been edited by Patrick (edited 05-24-2015).]
Ponnari
Report this Post05-22-2015 12:08 AM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you suggesting I'm frugal.
Nothing wrong with that! I know I am, lol. And I totally understand "quick fix" when there isn't time to wait for parts.
I would be ashamed to admit what I've have to improvise on a weekend or if I'm broken down
and parts are not readily available.
I hope this works well so we all have another option that is quicker or easier to come by.
Thanks Patrick.
Total ratings: 465
Report this Post05-24-2015 01:24 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pictured here from left to right is... an '85-'87 Fiero EGR tube minus its jacket, the Camaro EGR tube mounted on the Fiero upper plenum, and the original '88 EGR tube showing the crack in the middle that was being hidden by its metal heat shield. (I cut the flange off the end of the tube to slide the metal heat shield off.)
This is the jacket I removed from the '85-'87 Fiero EGR tube and transplanted onto the Camaro tube. Because of the layout of the '88 EGR system, the tube used on the '88 system ends up being a little longer... which is why the '85-'87 jacket seems a bit short. But it's fine, especially considering it's only temporary until my high price header wrap arrives from Hong Kong.
And this is my assistant... the neighbor's cat. As soon as it hears me in my back yard, it comes running over. I wish I had this effect on women.
And oh yeah... one more thing to mention. I installed everything and... and... and...
Success !
No cracks after bending the tube, and a nice low idle.
E.Furgal
Total ratings: 278
Report this Post05-24-2015 05:28 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you got it in..
would it being a 1//2 inch 11-12mm shorter helped..?
might be time to hit swapmeets for a cheap wire feed mig..
has anyone tried copper.. it seems to not have issues with heat cycles, my compressor inlet to tank can get as hot if not hotter than an egr tube..
[This message has been edited by E.Furgal (edited 05-24-2015).]
Total ratings: 465
Report this Post05-24-2015 11:59 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, the extra length wasn't a problem at all. It was the non-rotating flanges that provided the challenge in regards to making the tube fit.
Total ratings: 465
Report this Post10-18-2015 03:25 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I should now add that five months of daily driving and about ten autocrosses later the replacement EGR tube is just fine.
1MohrFiero
Total ratings: 157
Report this Post10-18-2015 09:04 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you install the Hong Kong header wrap?
Ponnari
Report this Post10-18-2015 05:07 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the update Patrick. Too many people never post result how their project turns out
after testing.
I'll be doing a egr tube replacement soon and am going to follow
exactly what you ended up doin.
Ayrton Senna
Total ratings: 465
Report this Post10-18-2015 05:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I did. I was surprised though how little coverage there was on the EGR tube using the 39" of 2" wide header wrap. It certainly covered the whole tube, and I was able to overlap quite a bit, but the finished wrap didn't have a lot of thickness to it. I felt it wasn't enough insulation to contain all the heat. Two rolls of this stuff might've been better.
However... I then covered the wrapped EGR tube with several layers of heavy-duty aluminum foil. It was easy to do while the EGR tube was still off the engine, and I have to admit that I was quite happy with the results. It looks fine IMO, and it does the job well. I'll take a picture of the area on the next sunny day... although that might be by next June.
Thanks for the update Patrick. Too many people never post result how their project turns out after testing.
Lou, you're quite welcome. I normally follow up on something such as this, but without going into detail, this was a very different year for me and there were major "distractions". When I discovered yesterday that I had never posted the longer-term results, I was rather surprised. I'll get a picture posted in the near future so you can see what the finished project looks like, but keep in mind you'll not see the wrap as it's hidden by the foil.
[This message has been edited by Patrick (edited 10-18-2015).]
Total ratings: 465
Report this Post10-21-2015 04:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some images of the "finished" project. (None of my Fieros will ever be finished.)
These images show four things I've done to help reduce heat near the ICM. The coolant tubes to the TB have been eliminated, a heat sink is attached to the bottom of the distributor, an aluminum heat shield has been added to the factory heat shield by the coil and wraps around the distributor, and the replacement EGR tube (from a Camaro) has been heat wrapped and covered in several layers of foil.
I'll never get an award for having the prettiest engine bay , but the 2.8 in my daily-driver Formula is reliable and runs strong both on the street and at autocross.
[This message has been edited by Patrick (edited 10-22-2015).]
fierosound
Total ratings: 287
Report this Post09-05-2017 11:58 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fiberglass/foil insulating sleeves on everything are crap.
The foil just flakes off and makes such an ugly mess.
See the shift cable here in my Indy after only a few years.
I replaced the factory style crap on the shift cable with DEI Fire Wrap.
Has a velcro edge and will likely never need to be replaced.
I will be using this as needed on both my cars from this point on.
https://www.designengineeri...eving/fire-wrap-3000
This would be good on the EGR tube too...
[This message has been edited by fierosound (edited 09-05-2017).]
Total ratings: 465
Report this Post09-05-2017 02:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tony, it's not entirely clear to me the connection to the original topic. Is there perhaps a model/version of DEI Fire Wrap suitable for EGR tubes?
[This message has been edited by Patrick (edited 09-05-2017).]
Total ratings: 328
Report this Post09-05-2017 06:47 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use the torch. You'd be surprised what a bit of heat can do. If you cut off the tube at the flange you can braze weld it back in any position.
Total ratings: 465
Report this Post09-05-2017 08:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't source a perfectly good EGR tube to cut it apart and then braze back together again. Bending it worked just fine. It's been two years now with no issues.
Total ratings: 328
Report this Post09-06-2017 01:02 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've brazed a few of them together and they fit just like the original. Easier for me than trying to kink a tube and cause metal work hardening. I guess to each his own.
Total ratings: 465
Report this Post09-06-2017 02:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've brazed a few of them together...
Well that's great, but we don't all have equipment to do welding and/or brazing.
It's unfortunate you'd have that problem. I didn't.
