  Question for the 3800 into an 84 swappers
Question for the 3800 into an 84 swappers by Dave E Bouy
Started on: 07-07-2015 10:38 AM
Replies: 13 (292 views)
Last post by: longjonsilver on 03-20-2024 04:13 PM
Dave E Bouy
Report this Post07-07-2015 10:38 AM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapping a Series II into an 84. I can manage the different wiring but I do not know what to do with pin R on the C203 connector. Can anyone help me out?
Thanks DF
Lou and Blue
Report this Post07-07-2015 11:37 AM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Scott2scott, he just finished a swap in his 84.
Louis Duet
Baldwin, Long Island, NY
"My mind spins like helicopter blades." -G. Rossdale
"Blue" <= '85 Fiero GT
3800sc series 2 swap in progress--IT'S ALIVE !!!!!
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Peugot 604 Intake manifold
Exhaust headers
Anti-3rd brake light
Slammed
Total ratings: 79
Report this Post07-07-2015 12:02 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing. Delete it.
Dave E Bouy
Report this Post07-07-2015 12:13 PM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will. Thanks
DF
Slammed
Total ratings: 79
Report this Post07-07-2015 03:11 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
You've got a PM
Scott2scott
Report this Post07-07-2015 03:50 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
R is nothing . I sent u a pm. Iv got pics of my 84 as i was goin along.
Scott2scott
Report this Post07-07-2015 03:55 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scott2scott
Member since Jun 2014
The 84 fiero doesnt have engiugh power to run the 3800 from just c203 . U will need to run 3 extra wire from the c203 upto the fuse box and put them into open spots in the back of it. And crip them down. One wire needs always 12v power for an other 2 only when key comes ON . They will come out of pins J ,L, G and go to fuse box
Total ratings: 290
Report this Post07-07-2015 08:55 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I build an 84 harness I use a power relay and extra fuses in the engine bay. This keeps the harness plug and play.
E.Furgal
Total ratings: 278
Report this Post07-08-2015 01:44 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
WHY?
is it the 6 injectors or the 3 coils,
The injectors I'd think be driven by drivers in the ecu..
can't see the coil pack adding that much more draw..
Scott2scott
Report this Post07-08-2015 02:49 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wiring wise it is just a matter of making the harness for an 84 and moving the C500 towards the driver's side so it clears the exhaust of a V6 engine and you need to run a few extra wires from the fuse box to power the extra needed ignition requirements of the newer engines.
That's it for differences in the 84 to other years swap wise ,
Scott2scott
Report this Post07-08-2015 03:35 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scott2scott
the 3 wires added to the c203 in the 84 because the 84 wireing id diff than other years.one of the wires with the key ON supply six injectors with one wire. the second wire power for the maf,bbv,o2 sensor, and the 3rd wire is for battery power all the time for pcm c1, pin 20 and pin 19.
Scott2scott
Report this Post07-08-2015 03:37 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scott2scott
all this came from fieroflyer when he build my harness.
longjonsilver
Report this Post03-20-2024 04:10 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i sent you a PM
longjonsilver
Report this Post03-20-2024 04:13 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
longjonsilver
Member since Nov 2001
PM sent
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 3800SC, 4-wheel drifts are fun!
