Update System
  Heads up - 4.9/manual with LSC flywheel
by Raydar
Started on: 08-07-2015 07:33 PM
Replies: 21 (1077 views)
Last post by: Raydar on 01-11-2016 12:53 PM
Total ratings: 465
Report this Post Click Here to See the Profile for RaydarClick Here to Email RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some of you may remember me posting a few weeks ago about needing to replace the clutch in my 4.9/Getrag car.
It still grabs okay in the lower gears, but in 5th, at 3000 RPM, I can stomp the gas and make it slip.
I dropped the tranny and clutch out today, and found that the clutch was not even half worn.
What I also found is that the rivets in the hub, at the edges nearest the clutch lining, were hitting the flywheel.
You can see this in the second and third picture above.
You can also see it in the pics below, if you look around the edges of the "depression" in the center.
It appears to me that they were holding the flywheel side of the disk away from full contact with the flywheel. Or at least interfering with the clamping.
So... what to do?
This renews my faith in the Ram HD clutch, but I'm already this far into it.
(I should mention that this is the only issue I've had with the LSC flywheel - or the whole installation, for that matter.)
I'm inclined to have the center depression machined out a bit (if they can do it) have the friction surface re-faced, and take a scotchbrite to the pressure plate and put everything back together. (I'd thought about doing the machining myself, but I really don't have the tools to do it.)
If I replace anything, I'm tempted to just buy a new disk, if it's available.
Thoughts?
Edit - I finally got around to emailing LSC. They want to fix this, going forward.
Please see my post on 1/9, farther towards the bottom...
[This message has been edited by Raydar (edited 01-09-2016).]
2tone86gt
Report this Post Click Here to See the Profile for 2tone86gtClick Here to Email 2tone86gtSend a Private Message to 2tone86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
A friend of mine who is doing my wiring on my jeep engine swap reffered me to a place called "tennesse clutch supply." I was talking of having him wire up my fiero after my 4.9 swap gets done and he suggested this company cause they will build you a clutch from scratch. You tell them what its for and what kind of power you want it to hold up against and how you want it to grab and they will make it for you. His brother had a clutch built for a datsun V8 swap pushing 400 hp and the disc and pressure plate they made for the car only ran $160!! Check into it and lemme know how works if you decide to go that route. I hear they really know their shi*.
Neils88
Total ratings: 56
Report this Post Click Here to See the Profile for Neils88Click Here to Email Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
LSC uses a stock, undrilled Fiero flywheel. The only thing they do is drill the bolt holes. I'm not understanding why you see the flywheel as being at fault. Maybe I'm missing something.
Total ratings: 290
Report this Post Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageClick Here to Email phonedawgzSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a worn out clutch.
When the rivets are hitting the flywheel, the clutch is worn out.
Total ratings: 465
I'm not so sure that that's true. Either that or the Fiero Store RAM clutch is just not compatible. I don't recall anyone else using that clutch and having that issue.
I looked at replacement flywheels at Rockauto. They show a wider "dish" in the middle of the flywheel. (One thing I like about Rockauto... Their pictures and descriptions seem to be accurate. If it's a "stock photo" they tell you.)
http://www.rockauto.com/cat...9208&jnid=634&jpid=0
[This message has been edited by Raydar (edited 08-07-2015).]
Total ratings: 465
The rivets in the lining are not touching the flywheel. The lining is barely worn.
It's the rivets in the hub that are touching the flywheel.
Neils88
Total ratings: 56
This is a pic of the clutch I use with my LSC flywheel. You can clearly see the difference between your hub and mine. Mine is a Fiero clutch and the hub has no issue fitting inside the recess. Perhaps yours was mislabelled by RAM?
Total ratings: 465
What kind of clutch is that? It doesn't have all the rivets in the hub.
To eliminate any confusion, I have marked the rivets that are rubbing, and where they are rubbing on the flywheel.
My clutch came from the Fiero Store. I have looked up the RAM part number on the box on various websites.
It is, indeed, the correct part number for an 88 V6 5 speed Fiero.
Neils88
Total ratings: 56
My clutch is a Krupp. Pretty much similar to all the inexpensive 6 puck clutches that you see, but it had some design features that seemed just a bit better than the rest. Downside with 6 puck clutches is normally the chatter, but I never got that with this one. It was also gripped hard right from the first drive (which coincided with the first hard acceleration...).
What do Specs and other popular clutches look like in that area? Have to look and see if they all have rivets at a similar radius to yours.
Total ratings: 465
Thanks for the info.
I can't really comment on the Spec or any of the others. Haven't really paid attention to this particular issue until just now. (Go figure.)
I don't know of anyone else who has experienced this problem, but that's kind of how my luck runs.
I am that person who could inadvertently tear up a crowbar in a sandbox.
[This message has been edited by Raydar (edited 08-08-2015).]
Report this Post Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a RAM HD clutch in my Formula, and year ago it failed (at about 40,000 miles)......all the hub rivets sheared, or so I thought. Maybe the rivet heads wore down and let go. The pad surface was about half used up (similar to yours). I replaced it with a LUK, which is working fine with the stock 2.8.
edit: when I took a look at the damage, there were loose hub parts and springs, but I did not find any rivet heads.....
[This message has been edited by Gall757 (edited 08-08-2015).]
Total ratings: 465
Okay. Found a machine shop ten minutes from my house. Go figure.
Got the flywheel resurfaced, and the edge of the dish (where the rivets were hitting) beveled at a nice 45* angle.
Original
Reworked
Have another Ram clutch on order, along with new flywheel bolts and a rear tranny mount.
Everything should be here by the middle of the week.
Edit - I was almost tempted to put the same clutch back in, but as much of a PITA as it is to change out, it's worth the price of a new one, especially since you can see the "heat bluing" of the hub, where the rivets were rubbing.
But I will hang on to it, for a rainy day.
[This message has been edited by Raydar (edited 08-14-2015).]
Total ratings: 465
Update...
Got my new Ram clutch. The new disk doesn't look quite as sturdy as the one that came out.
It's only got four springs, instead of the six, pictured, but they're bigger, and they're double springs, where the others are single. So I guess it's a "wash".
The center hub flange is incrementally smaller. This was an area of concern with the first disk. It looked like it might get into the flywheel bolt heads, after the facing wore down a bit. That won't be a problem on the new one. The only reason I didn't reinstall the old one is that the center section is "blued" a bit in the area where the rivets were rubbing. Figure it may be compromised.
Also... There are tons of posts regarding pressure plate bolt torque. The factory service manual specifies 15 ft.lbs. Believe it.
15 lbs sounds stupidly low for the task at hand. So I cranked the torque wrench up to 20 lbs. They still didn't feel tight. Figured that maybe the lockwashers were influencing the reading, so I went to 25.
After doing that, I second guessed myself, and came upstairs and did a search.
Basically, everyone said 15 lbs. No higher than 18.
I decided to remove the bolts and ditch the lockwashers, and retorque them to the proper setting. When I removed them, I noticed that at least two of the bolts were visibly stretched. I'm sure they would have broken.
To add to the damage, I had blue loctite on the threads. Loctite acts as a lubricant, so I actually had them way too tight.
[This message has been edited by Raydar (edited 08-23-2015).]
2tone86gt
15 ft lbs? Wow man i could see that as the first round in the sequence but not as a final step. That sounds a little dangerous. I have never heard of any pressure plate being torqued that low.
Total ratings: 465
I know... right?
That's what the FSM says.
But do a search on the forum. That is the "accepted" answer. (And ~25 lbs visibly stretched my hardened bolts, so that's something...)
2tone86gt
Keep us posted after you get it back together. I love your car btw. I think the formula fast back is a great look. I will be following your foot steps soon as my jeep gets done before winter. I just bought an 88 coupe i am going to convert to a fast back and I have a 4.9 sitting in my garage so i may have to hit you up after i get started on it.
BV MotorSports
Total ratings: 189
Report this Post Click Here to See the Profile for BV MotorSportsClick Here to Email BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have always used 18# w/ blue locktite. It always seemed low to me but I haven't had a PP bolt come lose. FW, yes, PP no. lol
Total ratings: 465
I'll be using 15-18 this time. As soon as I get some more bolts.
My FW bolts were torqued to 50#. Since they're the same thread as the stock Fiero crank, I used the stock specs.
Total ratings: 465
Okay... All is well. Survived the "tourist route" of RFTH, but still got driven enough to test.
I have no complaints. None at all.
Total ratings: 465
Update!
I emailed LSC this morning and got a response from Tom. He was quite appreciative, and has promised to look into this.
From his email...
I looked through the post and I see what you are saying. I really appreciate your input. I can easily open that counter bore up on future f/w's. Someone mentioned in your thread that we "just drill stock flywheels".
We actually manufacture the entire wheel. That's pretty much all we do, make flywheels. We make them hundreds of different motors.
I'm not at my shop right now so I can't look at the drawing but I believe we cut those at 5.000 inches. I can easily start machining them at 5.250 or 5.5000. (or whatever dimension)
If I do that, will that still accommodate the other discs that people are using? I've never had anyone point this out. I have no problem changing them, I just don't want other people to start saying their disc now hangs over.
Let me know.
You can call me during the week if you want to or if you have any more questions.
Thanks again for the input.
Tom,
LSC Performance
(951) 677-8895
P.S. We had to move our shop that we had been in back in June that we had been in for 25 years. You can pass that along on the forurm if you want.
Our new address is
LSC Performance
25839 Jefferson ave.
Murrieta ca 92562
To the point..
The question is, How large should the "dish" be?
I'm thinking it should be back cut for another 1/2" total diameter. Will that still accommodate the disks that everyone is using?
Neils88
Total ratings: 56
Originally posted by Raydar:
Update!
From his email...
Let me know.
Tom,
LSC Performance
(951) 677-8895
Our new address is
LSC Performance
Murrieta ca 92562
To the point..
My apologies to Tom for stating that they just drill the holes in stock flywheels. Someone had told me that when I was researching the flywheel for my 4.9 build. Good to hear that they make them themselves.
As for the requirements of the dish...you are the first person I've heard of having a problem, so I'm guessing your specs should work for everyone.
Total ratings: 465
Bump for the folks who were gone, over the weekend. Then I'll let it go...
