  Coolant overflow tank repair (Plastic welding with soldering iron and milk jug)
Coolant overflow tank repair (Plastic welding with soldering iron and milk jug) by danscrazymodshop
Started on: 08-25-2015 09:22 AM
Replies: 3 (548 views)
Last post by: weloveour86se on 08-27-2015 08:01 AM
danscrazymodshop
Report this Post08-25-2015 09:22 AM Click Here to See the Profile for danscrazymodshopSend a Private Message to danscrazymodshopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recently when I rebuilt my fan in my Indy I had to repair my Coolant overflow tank. The top tab was broken and the bottom tab cracked. I am a welder by trade so I figured I'd try my hand at plastic welding. First I watched a video on plastic welding. I should note that I used no filler rod at all, just the milk carton and a small soldering iron with a modified tip made from a sawed off flat tipped screwdriver. I cut up the milk carton and folded it into an envelope type sleeve that fit over the tab. Then sleeve was 4 folds thick (2 on either side with the tank in the middle). Then I welded tab on trimmed the edges with a bench grinder, then clamped and rewelded the edges, then drilled the hole and welded around the hole. It's best to clamp wherever the seams come together. Don't grind where you welded the seams or you'll ruin your weld. It's stronger than the original. The video suggested to melt in cut and formed pieces of paperclip around the hole to give the same reinforcement as rebar in concrete. I didn't do that because it's kind of messy looking and it's not necessary if you weld both sides around the hole. It was harder to upload this picture than to weld the plastic [url=https://www.facebook.com/photo.php?fbid=10153218289969022&set=a.10153218255719022.1073741826.671459021&type=1&theater][/url]
[This message has been edited by danscrazymodshop (edited 08-25-2015).]
Ponnari
Report this Post08-25-2015 05:39 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice Job!
Thanks for the info & details. I will be giving this a try soon.
"Because in a split second, It's gone"
Ayrton Senna
danscrazymodshop
Report this Post08-26-2015 12:58 AM Click Here to See the Profile for danscrazymodshopSend a Private Message to danscrazymodshopEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you need help with this let me know. The key to making a plastic weld bead look like a TIG welding bead is to dig the soldering iron into the plastic at a 45 degree angle and essentially start at one end and come towards you by Dig in push the melted plastic forward over itself and repeat until it looks like a TIG weld joint. Once you got the hang of it, it's surprisingly easy and will give the stacked quarters look of metal welding.
weloveour86se
Total ratings: 75
Report this Post08-27-2015 08:01 AM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Super glue and baking soda works GREAT. Been 6 years and not a drop.
