  Trying to help someone out 3800SC (Page 2)
Trying to help someone out 3800SC by Lou6t4gto
Started on: 09-12-2015 03:11 PM
Replies: 46 (1203 views)
Last post by: Lou6t4gto on 07-10-2016 02:49 AM
Lou6t4gto
Report this Post10-12-2015 01:43 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Now I am getting "info" about a Dual Check Valve oil filter adapter that was needed and that that could be starving the ac compr side Lifters oil"
please POST "what" it SAYS and where it's FROM. and a PICTURE of said part.
Lou and Blue
Report this Post10-12-2015 02:51 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the reply I got , no picture though.
Does the oil filter use a filter mounting adapter.....the type with the dual hi pressure bypass pistons (one pressure relief piston for each cylinder bank?.......could one of them be stuck open?
From this thread
http://www.gmforum.com/pont...or-oil-issue-309653/
Ryan says he's never heard if a dual check valve oil filter adapter and either have I.
I gotta pull this engine out before everyone gets fed up and stops offering advice.
[This message has been edited by Lou and Blue (edited 10-12-2015).]
Lou and Blue
Report this Post10-13-2015 05:17 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou , read the last post on this thread
http://www.grandprixforums....e-gasket-orientation
Lou6t4gto
Report this Post10-14-2015 01:12 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the "gasket" being "backward" would do anything but cut oil to the" balancer shaft". I DO think the "Crossover PASSAGE" is somehow plugged UP. Did you clean it before reinstalling ? That's the only thing it CAN be. It would have to be COMPLETELY shut off, even 5 psi of oil into that passage would "quiet" it.
In the" front", (behind the timing chain) are ONLY "Plugs" that "Cap" the oil passage, if they somehow come out, oil will come out, dropping oil pressure, but they Do Not affect oil going IN. The ONLY way the oil gets in that passage is through the REAR Plate groove. After taking off the rear plate, I would run a coat hanger through Both Passageways all the way to the front, just to make sure. It is just a hollow hole from rear to front ending at the front "plug" behind the chain. (if the plug was out, you could SEE all the way through)
*WHY GM did not put an" oil pressure tapped hole" at the rear of the block (like a Small block chevy) is beyond me*
When you take it apart, Take PICTURES of the plate before and after Cleaning, A picture of the hanger (Wire) in the oil passage front to rear (BOTH SIDES). ** DO THIS FOR PEACE OF MIND* * While the Engine is OUT, with a Mechanical Oil gauge hooked up, Take the Spark Plugs Out ( so there is no compression) , use" jumper cables" battery to starter and crank it over, Both With and Without the "Rear Cover" On. With the cover on you will have oil pressure, Without the cover, Oil SHOULD shoot out Only the lifter bank HOLE that gets the oil First. This way you will know for SURE, that it's working the way it should "BEFORE" you go to all the work of re-installing it. PICTURES !!
Lou and Blue
Report this Post07-02-2016 08:37 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, so it's final. I took off the rear cover plate today and the passage was clogged hard as a rock with anaerobic gasket sealer . I wasn't supposed to use any gasket sealer but I did and now I'm paying for it by redoing the area. If you look for me on Facebook you can see pictures
Founder / President
Long Island's Little Fiero Owners Club
L.I.L.F.O.C.
"Blue" <= '85 Fiero GT 3800sc series 2
"Boo" <= '81 Delorean DMC-12, VIN #5835, Stock PRV engine, Peugot 604 Intake manifold, Exhaust headers, Anti-3rd brake light
Lou and Blue
Report this Post07-10-2016 01:36 AM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update : finished re-installing engine and got her fired up all is well , no rattle , good pressure . Sounds nice !
Thanks to all !!!
Founder / President
L.I.L.F.O.C.
Lou6t4gto
Report this Post07-10-2016 02:49 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
only thing it could have been. glad it worked out. Now for the Test Ride ! LOL
