  88 Fiero: Replaced Strut. Question? Pics Included
88 Fiero: Replaced Strut. Question? Pics Included by jon2009
Started on: 09-18-2015 03:53 PM
Replies: 16 (741 views)
Last post by: Patrick on 09-20-2015 03:09 PM
jon2009
Report this Post09-18-2015 03:53 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys,
i just replaced the rear struts on my 88 fiero gt. I used the Monroe 71814 Sensa-Trac Struts.
The installation went fine. But when i put the tires back on. The tires were sitting differently. The top of the tire seems like its sticking out more than the bottom.
Did something go wrong when i installed the struts. I used the old mounts and the old springs.
Here the are the pics: http://imgur.com/a/9zMem
Please any suggestions will be greatly appreciated.
Thank you
[This message has been edited by jon2009 (edited 09-18-2015).]
Domtech
Report this Post09-18-2015 04:12 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
The alignment of the 2 large bolts at the base of the strut adjust the camber of the wheel. they should be special cam washers or bolts to allow easy incremental adjustment.
If you do a search for Fiero camber bolts you will see what I am talking about.
Since you replaced the struts It now needs an alignment, you can read up on ways of doing it yourself or take it to an alignment shop.
Formula88
Total ratings: 554
Report this Post09-18-2015 04:48 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure about the Monroe struts, but I did have a clearance problem with KYB struts and they wouldn't align until I ground some clearance. On some cars there's enough tolerance that it's not needed, but not all.
Look where the two large bolts attach at the bottom of the strut. That's where the camber is adjusted. There's a clearance issue behind the suspension knucle hitting the strut body preventing the wheel from being able to shift into alignment. It's more pronounced on the passenger side. If you loosen the camber bolts, you'll find the drivers side wheel moves freely through it's full range of camber adjustment, but the passenger side won't.
Grind down the knuckle there for a permanent fix, or like I did grind slightly on the strut body. It doesn't take much. It's because 88 struts were originally a different part number but all you'll find today is a single part number for all years. The clearance issue only affects some 88's depending on how the tolerances stack up.
Edit to add: The Camber Bolts mentioned above will not fix the problem. They are a good idea and make adjustment much easier and you're likely to get a better alignment but you have to address the clearance problem first. I highly recommend the camber bolts for any Fiero.
[This message has been edited by Formula88 (edited 09-18-2015).]
Jims88
Report this Post09-18-2015 09:25 PM Click Here to See the Profile for Jims88Send a Private Message to Jims88Edit/Delete MessageReply w/QuoteDirect Link to This Post
As Formula88 suggested; here is where I had to grind some clearance on my knuckle and Sensa-Trac strut. To dial in the camber.
Formula88
Total ratings: 554
Report this Post09-18-2015 09:48 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's it. I didn't have a clear picture. Thanks for posting that.
On my car it only affected the passenger side.
fierosound
Total ratings: 287
Report this Post09-19-2015 09:27 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
You want this type.
Where they go
Calgary time/temp
Total ratings: 465
Report this Post09-19-2015 04:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You want this type.
For sure. The other style is next to useless.
jon2009
Report this Post09-19-2015 04:38 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the input guys.So the bolts that i have in the pics are no good in terms of adjusting the camber. Those bolts were bought new from Brafasco for like $50. So there's no choice but me to buy new fiero camber bolts? Is there anyway to use the bolts i have installed now. The oem bolts are not camber though. Sorry for the confusion guys.
Total ratings: 465
Report this Post09-19-2015 04:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, but I've got to ask... why?
What was wrong with the original ones?
They'll hold the struts on just fine, but that's all they'll do. They're useless for adjusting the camber.
Let's make it clear that camber adjustment bolts are not absolutely required to set the camber, but they make the job a helluva lot easier.
jon2009
Report this Post09-19-2015 05:01 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
The old bolts were damaged because i hammered the bolts out. Not a smart move on my part. I should of had a nut on them. My mistake. So the question is should i purchase camber bolts. Or just get the camber aligned with the ones from Brafasco. What should i do, as i am newbie.
Thanks
jon2009
Report this Post09-19-2015 05:28 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
jon2009
Member since Dec 2013
Just so i know. I just need 2 camber bolts right not 4? Each for the bottom strut holes.
kindly let me know guys.
thanks
jon2009
Report this Post09-19-2015 05:51 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
jon2009
are these cam bolts ok, from rockauto. TRW 13209A
Total ratings: 465
Report this Post09-19-2015 06:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just make sure you don't get the style with the cam on the shaft of the bolt. They don't give nearly as much adjustment.
Jims88
Report this Post09-19-2015 08:31 PM Click Here to See the Profile for Jims88Send a Private Message to Jims88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, mine was on the passengers side only also.
Total ratings: 461
Report this Post09-20-2015 02:39 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I told my alignment guy that I had installed camber bolts, he was very appreciative.
Not enough to get me a discount, but appreciative, nonetheless.
Edit - I installed Sensa-Tracs on my 88, and didn't have to "clearance" anything.
[This message has been edited by Raydar (edited 09-20-2015).]
Lambo nut
Total ratings: 262
Report this Post09-20-2015 02:50 PM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any alignment shop that has any clue as to what they are doing will have no problems doing the job with what you already have installed. I used to do them all the time. The special bolts handy, yes. Needed, no.
Kevin
Total ratings: 465
Report this Post09-20-2015 03:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same here.
