  Fiero White Paint
Fiero White Paint by 85fieroguy
Started on: 10-22-2015 10:53 AM
Replies: 6 (562 views)
Last post by: rogergarrison on 10-27-2015 11:12 AM
85fieroguy
Report this Post10-22-2015 10:53 AM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The color code for 84-88 white paint is a code 40 WA 8554. Thought I saw something on one of Pennock' sites that in 2015 the same paint is available under a different gm code. . Any info would be appreciated.. Its hard to find a Duplicolor ds gm 338 which was close.
bonaduce
Report this Post10-22-2015 01:39 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are correct, it has been used on Enclave/Traverse/Acadia since 2007- present GM# 19328535 for t/u pen (still is 40U or WA 8554)
dan
[This message has been edited by bonaduce (edited 10-22-2015).]
85fieroguy
Report this Post10-24-2015 12:01 AM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need a spray can of White code 40 WA 8554 for the 84-88, go to automobile touchup.com, look under Pontiac Fiero 1991 ( why I don't know, no listing for 84-88). 12 oz. for $19.99 + postage. Previously bought from these people for a touch up on a 1990 neighbors car medium metallic gray..perfect match up. You might try them for other colors..give them a call, very helpful people.
rogergarrison
Total ratings: 551
Report this Post10-24-2015 07:32 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
40U (upper) 40L (lower) body color codes been used for 40 years, then became 8554 when basecoat/clearcoat paints became oem. Always go by the codes...never the names. ie/ Classic White on a Chevy is Castilian White on a Caddy for say one year, and the names frequently change to different but similar colors the next. Classic White was once called Pure White, then Coca-Cola White (because Coke made it their fleet color along with red).The codes never change.
IMSA GT
Total ratings: 253
Report this Post10-24-2015 07:55 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
And if you want to touch up an entire panel without worrying about blending, spray your color on very light just to cover the panel and then finish with Spraymax clear. It is a 2 part clearcoat that is activated by a push button on the bottom of the can. Once mixed, you have 24 hours to use it before it hardens in the can. Also you will need fresh air to spray it since it is a high chemical compound almost exact to automotive paint and comes out shiny as hell:
84fiero123
Total ratings: 325
Report this Post10-24-2015 10:10 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know some NAPA stores will premix you whatever color you want and put it in a spray bomb for you. Not sure about price.
Steve
rogergarrison
Total ratings: 551
Report this Post10-27-2015 11:12 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most Sherwin williams auto paint stores mix cans for you for about $20. They can also mix it as single stage so you dont have to clear it.
