Working on my wiring harness for the 3800SC swap. Donor car was a '95 Riviera. Got the entire wiring harness from the vehicle, so lots of extra wire. Spent the last 5 days buzzing out the harness, tracing wires, etc. Also spent a lot of time online confirming stuff that wasn't clear. Came down to just a few questions that I know someone here can help with!
1) Riviera harness has a large connector in the engine bay connecting the engine to the ECM. Very convenient, and I plan on using it. I want to locate it where the battery was located ( already moved battery to front). Any issues with locating it there ( such as water?). If not there, where else would you suggest.
2) Coil pack going in same battery area. I know this has been done many times, so I don't expect any issues???
3) 3 wires were missing from the ECM connectors that I would like to use. Want to know if I can just use some of the "extra" wires from the ECM, and re-pin to these missing locations:
a) RB1 BRN Alternator Charge warning lamp control - goes to B3 of C500 connector
b) RB10 Dk GRN Engine Hot warning lamp control - goes to D3 of D500 connector
c) WD7 Lt BLU Performance shift switch input Goes to switch, then to ground to enable performance mode for shifting
4) WD14 Dk Blue Theft Deterrent Fuel Enable. Info suggests to ignore, that it can be programmed out in ECM. I will be deleting VATS in ECM- does this take care of this issue. Wiring diagrams in Buick Manual indicate that this might "go to ground", but not sure it it should just be grounded permanently.
NOTE: I have the capability to re-program and burn chips, although I believe that these "features" should already be there. Please let me know if there is something else in the programming I need address for these issues.
'87 GT in process, including GA / Seville brakes, Poly Suspension, '95 3800 Series 1 SC ( 225 hp ) 4t60e.
