  3800 hole in block. Freeze plug?
3800 hole in block. Freeze plug? by johnnyray401
Started on: 01-25-2016 01:12 PM
Replies: 4 (1326 views)
Last post by: Darth Fiero on 01-26-2016 02:19 PM
johnnyray401
Report this Post01-25-2016 01:12 PM Click Here to See the Profile for johnnyray401Send a Private Message to johnnyray401Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have this hole on the back of my series 2 supercharged 3800. Transmission side of the block, front side of the car. That is the coolant temp sensor in the top right of the picture. What is the hole? Does there need to be a freeze plug there?
[This message has been edited by johnnyray401 (edited 01-25-2016).]
Lou6t4gto
Report this Post01-25-2016 02:39 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
PICTURE ?
cmechmann
Report this Post01-25-2016 07:25 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Imagining this without a pic. But. In the rectangular corner casted area that forms into the bell housing shape below the deck?
Then ,no it's normal not to have anything in it. Not certain, but I think it is used during machining to hold the block.
johnnyray401
Report this Post01-25-2016 10:51 PM Click Here to See the Profile for johnnyray401Send a Private Message to johnnyray401Edit/Delete MessageReply w/QuoteDirect Link to This Post
oops! forgot the pic. Just added it. Sounds like what you are talking about though cmechmann, thanks.
Darth Fiero
Total ratings: 361
Report this Post01-26-2016 02:19 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing goes there. It's probably a hole put there by the factory for a mounting fixture on the assembly line or something. Don't plug it or do anything with it.
More is more. Less is not enough.
