  Wiring in a LC-1 wideband to 2003 3800 N/A
Wiring in a LC-1 wideband to 2003 3800 N/A by SSN669chris
Started on: 02-17-2016 08:13 PM
Replies: 2 (974 views)
Last post by: Blacktree on 02-18-2016 09:07 AM
SSN669chris
Report this Post02-17-2016 08:13 PM Click Here to See the Profile for SSN669chrisSend a Private Message to SSN669chrisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to wire in my LC-1 in place of the stock narrowband O2 sensor.
The ECU has an O2 high signal and O2 low signal.
I think I can wire the analog output to the O2 high and nothing to the O2 low.
The LC-1 does not need the heater circuit.
Can I just leave it unwired or will that give me a error code?
Thanks
Chris
Total ratings: 291
Report this Post02-18-2016 06:35 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
But your 3800 computer is looking for the O2 sensor to be heated. Is there a reason you don't want to wire it up?
Blacktree
Total ratings: 350
Report this Post02-18-2016 09:07 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The LC-1 controller connects directly to the WBO2 sensor, and controls the heater circuit. It also takes the data from the WBO2 sensor, and converts it to a simulated narrowband signal, which it then hands off to your ECM. I'm guessing you have a 4-wire O2 sensor (see graphic below)? The signal line should be the "O2 High" in your case. The "O2 Low" should be a ground.
Just to put things in perspective, here's another graphic showing typical 4-wire O2 sensor wire colors and pinouts:
That said, there are OBD-2 trouble codes for faults in the O2 sensor heater circuit. I'm not very familiar with the 3800 V6, so am not sure if its ECM uses those trouble codes. Maybe someone more knowledgeable with the 3800 ECM can chime in here. A couple possible solutions to that problem would be to put a dummy resistor in the heater circuit to fool your ECM, or maybe reprogram the ECM to ignore those trouble codes.
Or you could sidestep the whole issue by installing a second O2 sensor bung for the WBO2, and leaving the stock one in place. Just move the signal wire over to the LC-1.
Edit to add: I had to edit my post, because my experience using the LC-1 with a GM 7730 ECM is going to be a bit different than yours. But hopefully I can offer something helpful here.
[This message has been edited by Blacktree (edited 02-18-2016).]
