  3800 Series III Super Charged: Coil Pack Mounting bracket; Remove it or keep it?
3800 Series III Super Charged: Coil Pack Mounting bracket; Remove it or keep it? by JohnWPB
Started on: 02-19-2016 04:55 PM
Replies: 16 (2102 views)
Last post by: JohnWPB on 02-27-2016 12:29 AM
JohnWPB
Total ratings: 144
Report this Post02-19-2016 04:55 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, as the title says, I am not sure what can be done with the coil pack mounting bracket. I have researched and looked at tons of pictures, but have found nothing addressing what they did with their bracket. It is a combination coil mount, Engine mount, idler pulley and finally a tension pulley tossed onto the mix.
Here it is on my engine:
Is it best to:
a) remove the bracket, as well as the pulleys, and use a different size belt
b) just leave the bracket, and relocate the coil packs.
My intent is to make a bracket to mount the coil packs onto the 3800 close to where the 2.8's coil/distributor is located. This give a nice clean look from some of the photo's I have seen. I do want as clean of an engine compartment as I can accomplish with this swap.
MulletproofMonk
Total ratings: 78
Report this Post02-19-2016 08:27 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a couple options:
1. Relocate the coil pack and cut the engine bracket off or it won't clear the decklid hinge. Also, it needs to be the Grand Prix or Regal supercharger tensioner. The other ones will need to have the decklid hinge box trimmed.
2. It is possible to remove the decklid hinge box and make a low profile hinge like I did. This was based on fieroguru's design. I ran it on my car for 2 years with no issue. It allowed me to keep the coil pack in the stock location, but still had to cut the bracket off.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
Dave E Bouy
Report this Post02-19-2016 09:34 PM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I usually relocate the coil packs/ICM to the trunk wall and just cut off as much of that stock bracket as I can without interfering with either of the 2 pulleys. You're going to need both of those to run your supercharger belt.
Dave
carwhisperer
Report this Post02-19-2016 09:53 PM Click Here to See the Profile for carwhispererSend a Private Message to carwhispererEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1, remove the giant, heavy bracket and relocate the coil pack somewhere convenient. Also, remove the belt driven compressor and replace it with an exhaust driven one, so you can make some real boost
JohnWPB
Total ratings: 144
Report this Post02-19-2016 10:23 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not looking to modify the decklid hinge if not absolutely necessary. I would rather make the engine fit the car, than the other way around. Not being sarcastic, just that I have the engine out, and am happy to do what needs done to it, verses modifying the engine AND the car.
I forgot to mention, yes this is a Series III out of a 2004 GTP. That being the case, I do not have to trim the hinge box?
JohnWPB
Total ratings: 144
Report this Post02-19-2016 10:25 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
JohnWPB
Member since May 2009
Nah, I never have been one to have to wait around a couple of seconds when I want to go somewhere
[This message has been edited by JohnWPB (edited 02-19-2016).]
carwhisperer
Report this Post02-19-2016 11:04 PM Click Here to See the Profile for carwhispererSend a Private Message to carwhispererEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yah, good point.
JohnWPB
Total ratings: 144
Report this Post02-21-2016 10:22 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have another issues, that I am not sure what it is. I took all the plugs out of the engine, and engauged the starter to turn the engine over. It is making a rubbing noise, and I can not determine where it is coming from. It is not the flywheel, as there is nothing remotely close to it when it is spinning.
Is this just because the engine has been sitting for some time, and some sort of surface rust somewhere that will quickly wear off, or something I need to dig further to figure out.
Here is a video of it:
Spoon
Total ratings: 61
Report this Post02-21-2016 11:24 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hope you have oil in the engine. That sounds horrible. With all plugs out I'd expect it to sound more like burping an air impact gun. Battery may be weak or motor may be tight from sitting. That motors not spinning very fast in my opinion.
Try shooting oil into the cylinders to see if it sounds any better?
Edit to add / coil pack. Borrowed pics. / Bracket can be cut.
Spoon
[This message has been edited by Spoon (edited 02-21-2016).]
JohnWPB
Total ratings: 144
Report this Post02-22-2016 02:36 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the info on the coil bracket! I saved the pictures, and will take to to a machine shop to cut it. I have nothing even remotely big ot touch enough to cut through that thing!
As for the engine noise, I do not think it is the cylinders, as I think the sound would change as they went up and down. This sound is "circular" and constant. Almost like a dust shield hitting a rotor. I will dig deeper and try to determine what it is.
Darth Fiero
Total ratings: 361
Report this Post02-22-2016 04:28 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Spoon:
Spoon
I cut the coil pack mounting plate off that bracket and mount the coils either on the right strut tower or in place of the stock alternator mounting location. That way no modification at all is required to the right side deck lid hinge.
I DO NOT recommend mounting the coil pack on the trunk wall. It will get bathed in heat from the exhaust back there and the trunk wall isn't thick enough to dissipate enough heat from the ignition module with the added exhaust heat.
More is more. Less is not enough.
[This message has been edited by Darth Fiero (edited 02-22-2016).]
JohnWPB
Total ratings: 144
Report this Post02-22-2016 06:17 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did not have to cut mine off, there were just 3 tiny bolts holding my coil pack mounting plate to the engine mount.
In all my research, I totally agree. I will probably fashion a mounting bracket to go in place of the alternator, before relocating it to the Power Steering location.
I took the engine mount / pulley assembly off:
I then went to 2 different machine shops. Neither said they had the equipment to cut it. The one shop has been in business since 1982 and has a long waiting list of months to get some stuff done there. Kinda crazy they can not cut a cast iron motor mount. Any suggestions on how to get this done?
Also the bearing in the pulley is SHOT, so it's good to dissemble everything and check it all out before putting it all back together.
[This message has been edited by JohnWPB (edited 02-22-2016).]
Spoon
Total ratings: 61
Report this Post02-22-2016 10:10 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cut mine with a sawzall using a bench vice to hold it. Fresh blade took all but 5 minutes.
Spoon
bjc 350
Report this Post02-22-2016 11:49 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is the bracket on my 84 3.8 SC. PO built it or had it built. I always have thought that it was well done. Seems like he told me the tensioner was off a Subaru. I'd have to research that . As you can see, it sits over the rear cylinder bank. Does not seem to get overly warm, but the header below is wrapped in that area.
As it sits in the car, currently.
JohnWPB
Total ratings: 144
Report this Post02-23-2016 04:42 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
Thanks you! I called around today, and found one place that would do it. He explained how, being cast iron, he would go through quite a bit of material / blades, and the time involved, would be around $150 ! ! ! ! I stopped by Home Depot on the way home, and picked up a 5 pack of Milwaukee blades for metal for $10.
It took all of about 10 minutes, and only a single blade to do the trick!
Thanks for all the suggestions and help!
MulletproofMonk
Total ratings: 78
Report this Post02-26-2016 02:43 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't take it as a negative, I completely understand. My logic for doing it was:
1). I got to use stock spark plug wires because it was in the stock location. If I needed replacement parts, stock parts and part numbers. That is always plus to me.
2). I liked the cleaner look of not having the hinge box in there. Mine wasn't nearly as awesome as Paul's (fieroguru), so I will boost his picture...
https://www.fiero.nl/forum/Forum1/HTML/085829.html
JohnWPB
Total ratings: 144
Report this Post02-27-2016 12:29 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
That does look nice without the hinge boxes there, I have to admit! More than I want to tackle right now, but maybe down the road.
I am not concerned about the stock location and wiring lengths. I will purchase the kit to make my wires, as I will be routing them differently, and cut them to the exact lengths I need. I did this with my 2.8, and it really looked nice and clean.
