| | | quote | Originally posted by Patrick: I never said it was continuous under any/all conditions.
My upper intake plenum feels much warmer to me than the "general engine bay heat"... but no, I've never measured it. |
You didn't straight out say it, no, but your statement did imply it, especially by adding the colored and capitalized emphasis on the word hot.
There's a reason I said
heat soak there. When you open the decklid, the hot air trapped in the bay will escape very quickly, but the heat that is soaked into the metal components will escape much more slowly. If you leave decklid closed, and just let the car sit and warm up to operating temperature from idling, the upper plenum will
feel about the same temperature as if you were to cruise on the highway at 60 MPH for an hour, and then pulled into a rest stop and felt the upper plenum.
I merely wanted to clarify that the EGR is almost certainly unrelated to any concerns about how hot the upper plenum on a 2.8 feels, unless the EGR system is not functioning properly; but then you'd also notice worse problems than slightly elevated temperature of an aluminum intake plenum when felt by touch.
