  Looking for a list of parts to get my LS4 to 400hp
Looking for a list of parts to get my LS4 to 400hp by Madess
Started on: 04-01-2016 12:00 PM
Replies: 16 (1527 views)
Last post by: mr_corean on 04-04-2016 02:58 PM
Madess
Report this Post04-01-2016 12:00 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't care about keeping the DOD, so I would like cam and lifter choices. I have also read that I need to replace the intake and headers and I should be able to get there, correct?
Thanks for the help
Matt
dobey
Total ratings: 371
Report this Post04-01-2016 12:43 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Intake and maybe injectors and throttle body (LS2 intake requires different injectors and TB for example).
Decent camshaft (even a stock LS2 cam might get you there).
If you want to do a DoD delete, then lifters, valley cover, and I'd suggest switching the oil pump and swapping the oil pan to the LS2 vette pan.
And tuning.
Fast Red
Report this Post04-01-2016 12:56 PM Click Here to See the Profile for Fast RedSend a Private Message to Fast RedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Call WCF 661 822 8111 they know about deleting the DOD and Ecu, Intake, Headers, etc.
Total ratings: 259
Report this Post04-01-2016 08:15 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 382 whp (430ish fwhp) LS4/F40:
LS7 card MAF in 4" cold air intake tube (stock LS2 MAF would work as well, stock LS4 one is smaller)
LS2 90mm throttle body, LS2 Intake, LS2 injectors, LS2 fuel rails (Cheaper/easier than the slightly better LS6 - both support 450+ hp)
224/232 .564/.575 DoD compatible camshaft and matching pushrods and springs
LS7 factory exhaust manifolds (headers are also and option)
3" in, dual 2.5 out magnaflow muffler
My next upgrade will be to delete DOD and switch to a 222/226 .604/.604 custom camshaft - this should nudge me past 400 whp.
Gwhite18
Report this Post04-01-2016 10:38 PM Click Here to See the Profile for Gwhite18Send a Private Message to Gwhite18Edit/Delete MessageReply w/QuoteDirect Link to This Post
On normal ls engines long tube headers make a big difference on power. I wonder what to do about the exhaust.
I just saw you posted ls7 manifolds. .
[This message has been edited by Gwhite18 (edited 04-01-2016).]
dobey
Total ratings: 371
Report this Post04-02-2016 10:04 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Long tube headers don't do jack for power. They're a waste of money.
mender
Report this Post04-02-2016 11:02 AM Click Here to See the Profile for menderSend a Private Message to menderEdit/Delete MessageReply w/QuoteDirect Link to This Post
One test showing about 50 hp and 50 ft.lbs over cast iron manifolds at the peaks:
http://www.ultimateheaders.com/dyno.shtml
But the real story is in the lower rpm range.
They're selling their swap headers so they don't directly compare the long tubes to the LS3 cast iron manifolds but comparing the graphs shows 410 ft.lbs at 3000 rpm for LS3 vs almost 500 ft.lbs at 3000 for long tubes. Gains in the lower rpm = more street-usable power.
[This message has been edited by mender (edited 04-02-2016).]
Thunderstruck GT
Total ratings: 99
Report this Post04-02-2016 11:09 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL!
That's funny!
E.Furgal
Total ratings: 278
Report this Post04-02-2016 11:35 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
since when???
even the cheap 99.oo set will add power.. not ideal but..
I think 60 years of dyno test say your wrong.. including every test done since the first ls based engine
hint, what does the COPO Camaro come with.. there is a reason for that
[This message has been edited by E.Furgal (edited 04-02-2016).]
dobey
Total ratings: 371
Report this Post04-02-2016 11:59 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would be interesting to know what all was done to that "LS7" that was used, as it's obviously not stock. At a minimum it's running a different tune, and probably a different cam. I presume the LS3 manifolds were the Vette manifolds. Other vehicle manifolds will likely flow a bit better than the Vette manifolds do.
Granted the stock LS3 Vette manifolds are not the best, the stock LS4 manifolds certainly aren't either, but bolting on long tubes to a bone stock LSx isn't going to do jack squat. It might even make it run worse. And you certainly aren't going to bolt them up to an LS in the back of a Fiero anyway.
The topic of this thread is how to get an LS4 in a Fiero to 400 HP (presumed BHP, not RWHP). Headers are a given for pretty much any engine swap in a Fiero, especially a V8. But still, headers are not power adders, and any stock LSx exhaust is easily capable of handling a 400+ HP engine (as is obvious by the fact that the LS6, LS2, LS3, LS7, LS9, and several truck variants are rated at 400+ BHP.
dobey
Total ratings: 371
Report this Post04-02-2016 12:09 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
Originally posted by E.Furgal:
since when???
Where are there $99.00 long tube headers for swapping a V8 into a Fiero?
The COPO Camaro is a purpose built drag car. NHRA regulations require exhaust to exit headers at a certain point. COPO Camaro also comes with no emissions equipment, and has a camshaft meant to make power in the upper RPM range, not have a broad powerband for street or autocross driving. It only has enough of an exhaust system to satisfy the NHRA class regulations.
But I guess we should just all install zoomies in our street cars, because top fuel cars use them.
E.Furgal
Total ratings: 278
Report this Post04-02-2016 12:13 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
and when toss the manifolds, or oem short headers, and bolt on good headers, you make more power, this is fact, and yes you can put long tube headers on a fiero.. sure it's a custom job and not as easy as most..
The suck, squeeze ,bang, blow will always make more power when the exhaust is scavenging the bang when the cyl. is on the "blow".. less pumping losses= more power to the wheels..
busa_powered
Report this Post04-02-2016 01:56 PM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm taking my LS4 to be tuned next month on the dyno!
mender
Report this Post04-02-2016 03:12 PM Click Here to See the Profile for menderSend a Private Message to menderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure why you say that with so much evidence to the contrary:
http://www.chevyhardcore.co...r-dyno-test-install/
"With the stock exhaust, we were consistently dyno testing in the 385-387 rear wheel horsepower range. With the Kooks/Corsa system, power increased to 421 rear wheel horsepower with no tuning. This is a gain of over 30 rear wheel horsepower, and we were running a very fat 11.0-11.25:1 air fuel ratio."
Being basically an air pump, more air through the engine either by lower restriction, better scavenging/wave tuning or (preferably) both will result in more power.
Some good reading:
http://onthedyno.com/GM-LS-...headers-and-exhaust/
Fieroking
Total ratings: 78
Report this Post04-04-2016 03:03 AM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I built several with the following
DOD delete, GM performance lifters, LS 6 intake, 60 lbs. injectors, GM Performance Corvette Hot Cam, Doug Thorley LS 4 performance headers. That hit the 400 bhp mark.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
Thunderstruck GT
Total ratings: 99
Report this Post04-04-2016 08:34 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe Sokol
Now that ^ ^ ^ is an engine swap worth doing and Joe's way is how you do it.
mr_corean
Report this Post04-04-2016 02:58 PM Click Here to See the Profile for mr_coreanSend a Private Message to mr_coreanEdit/Delete MessageReply w/QuoteDirect Link to This Post
200 shot of nitrous. 400hp+ immediately.
