  installing radio in fiero
installing radio in fiero by 90turbo1
Started on: 04-20-2016 11:00 AM
Replies: 5 (525 views)
Last post by: 90turbo1 on 04-21-2016 11:29 AM
90turbo1
Report this Post04-20-2016 11:00 AM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
when you install the radio into a fiero do you cut that metal bracket out of the dash to make the radio sit flush with dash? i am having troubles with mine I wants to stick out.
let me know what you need to do to sit them in flush.
i have the hummount kit comming. tried a plastic metra kit.
fierosound
Total ratings: 286
Report this Post04-20-2016 11:14 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes - you can remove that support bracket to allow a different radio to sit further back.
https://www.fiero.nl/forum/A...090219-2-085853.html
(picture by NetCam...)
Total ratings: 460
Report this Post04-20-2016 11:17 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I recall, that bracket is just held in with rivets. A long screwdriver and hammer will remove it in short order. I would put something in its place to support the rear of the radio, though. Even a wood or styrofoam shim is better than nothing.
Edit - Fierosound beat me to it. Good stuff!
[This message has been edited by Raydar (edited 04-20-2016).]
TXGOOD
Total ratings: 87
Report this Post04-20-2016 01:04 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just put a Pioneer unit in my car and used the installation kit from Crutchfield and it was a breeze.
My unit didn`t come close to hitting that bracket though.
And the brackets that came with the installation kit bolted right up to where the stock radio bolted to.
It does stick out past the faceplate just a tad but that doesn`t bother me.
It`s only about a 1/4 or so.
E.Furgal
Total ratings: 278
Report this Post04-20-2016 04:52 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd pop the rivets and then make a 1.25"-1.50" spacer to move it back 1.25"-1.50"
allowing you to still support the head unit..
90turbo1
Report this Post04-21-2016 11:29 AM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks, I will do this.
