  Cracked 3800 heads
Cracked 3800 heads by Fierobsessed
Started on: 04-24-2016 01:10 AM
Replies: 2 (935 views)
Last post by: LFiero67 on 04-25-2016 04:01 PM
Fierobsessed
Total ratings: 147
Report this Post04-24-2016 01:10 AM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been struggling with finding 3800 heads that are not cracked. I went to the local U-Pull it a little bit ago, and I found 2 3800 supercharged heads already off the car. Don't know the year. I brought them home and cleaned them up only to find that both heads were cracked between the intake and exhaust valve on one of the cylinders specifically the exact same place in the casting on both. The crack is a hairline that goes from just inside one port, across the combustion chamber into the other just a bit. I took out my borescope and took a look at the crack from the water jacket side, It was pretty obvious that it did go through the casting and into the water jacket. It definitely leaked. I could easily see that there was a white stripe in the center of the orangy walls inside the head.
I brought the heads back and got store credit
I went back for another set, I tore apart a virgin 3800. 04 Buick. I figured that would be about the least abused, and the newest series 2 I could find anyway. It didn't take too long to get a head off of it, but it is a bit of work. I checked that head for cracks, and sure enough it had the one in the exact same place. I also found a 3800 NA head kicking around on the ground. Also cracked.
I'm stunned by the frequency of finding these cracked heads, later model or not.
I'm sure I can get my dad to ship me a pair of heads from one of his, but he doesn't yet know if they are cracked. Hopefully he can figure it out.
Anyone else have this problem? I've read that it does happen, but it seems like a good core is actually a bit difficult to come by. However, I can't bring myself to put a pair of heads on that are at best, flawed.
Lou6t4gto
Report this Post04-24-2016 07:53 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see you are in Nevada, gets hot there. the ONLY way heads crack is, if someone runs the engine out of coolant and Keeps On Driving ! They have to be incredibly Hot to crack. it's not from someone blowing a hose, the dash light comes on and they turn off the engine . you'll probably find the Bottom end of those engines are Shot also. best bet it a machine shop like Clearwater heads, just buy a set of "rebuilt Heads" for about $225
LFiero67
Report this Post04-25-2016 04:01 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty normal for the 3800 heads to be cracked there. You will have a hard time finding some without cracks. They usually do not leak though, and most people just run them. My supercharged setup heads were cracked in almost every cylinder, ran them for years that way. I'm sure my current heads are the same way. Look on some Grand Prix forums, there has been discussions of the issue there.
10.007 @ 135.54MPH. <-- Video
Best 60' 1.42
Best mph 137.66
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 140lb springs, comp pushrods, HV3, stock L32 bottom end and heads.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
