  Front Tie Rod End; 84-87 vs. 88, geometry or thread/rod size difference?
Front Tie Rod End; 84-87 vs. 88, geometry or thread/rod size difference? by hdryder
Started on: 05-06-2016 06:10 PM
Replies: 2 (641 views)
Last post by: tesmith66 on 05-07-2016 07:35 AM
hdryder
Report this Post05-06-2016 06:10 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am aware that the 1988 model year has a redesigned steering, suspension and brake systems.
But does anyone know what the actual difference is between the front outer tie rod ends?
I am thinking it most likely is a geometry, or inner tie rod diameter or thread difference.
At most parts shops, the 1988 part is less expensive than the '84-'87 part.
Thank you for the input.
[This message has been edited by hdryder (edited 05-06-2016).]
Total ratings: 460
Report this Post05-06-2016 08:06 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if this will be useful or not, but the 88 Fiero uses the same outer tie rod ends as the '97 (and I have to assume all 4th gen) F-bodies.
[This message has been edited by Raydar (edited 05-06-2016).]
tesmith66
Total ratings: 135
Report this Post05-07-2016 07:35 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
84-87 have a different taper on the shaft than 88. They are not interchangeable.
The line labeled 93-95 Camaro also applies to 88 Fiero as Raydar said. I'm not sure about 96-up Camaro, as the catalog I got this from stopped at 95. The Camaro and 88 Fiero parts are cheaper because they make more of those than the 84-87 parts.
Also note that it lists the thread as male on the Fiero part. That, of course, is incorrect.
Sorry about the picture size
1986 SE Aero coupe.
[This message has been edited by tesmith66 (edited 05-07-2016).]
