  Gas smell in Garage
Gas smell in Garage by MoonflyGT
Started on: 05-09-2016 12:20 PM
Replies: 10 (346 views)
Last post by: Riddick85 on 05-10-2016 07:25 PM
MoonflyGT
Report this Post05-09-2016 12:20 PM Click Here to See the Profile for MoonflyGTSend a Private Message to MoonflyGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Everyone,
Lately I've been smelling gasoline in my garage but I don't see a gas leak. My Fiero is a 1987 GT. I did however notice a small coolant leak. Does anyone know what could be wrong?
Lou6t4gto
Report this Post05-09-2016 01:41 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hoses from the tank to the Charcoal Canister ?, canister saturated ?
MoonflyGT
Report this Post05-09-2016 03:11 PM Click Here to See the Profile for MoonflyGTSend a Private Message to MoonflyGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
so where is the Charcoal Canister located? Would I be able to reach it?
Total ratings: 465
Report this Post05-09-2016 04:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my '88 Formula, I noticed a very slight gas leak a couple days ago in the metal tubes that run under the stock battery location to the fuel expansion tank near the passenger side rear fender. I've moved my battery to the front tub, so the original battery area in my Formula is now pretty easy to inspect. I imagine what has happened is that over time, battery acid had worked its way down to these metal tubes (which probably isn't too unusual with '87-'88 Fieros) and proceeded to corrode them.
[This message has been edited by Patrick (edited 05-10-2016).]
Lou6t4gto
Report this Post05-09-2016 05:29 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
remove the drivers side air vent behind the rear Glass. it's under it.
MoonflyGT
Report this Post05-09-2016 10:33 PM Click Here to See the Profile for MoonflyGTSend a Private Message to MoonflyGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. I see rockauto sells the Vapor Canister Filter. So Im guessing the canister can be opened. Would replacing the canister filter fix the gas smell?
Total ratings: 465
Report this Post05-09-2016 11:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
First of all, replacing the canister filter will accomplish nothing in regards to a gasoline smell.
And replacing the whole canister will also accomplish nothing if the gas smell/leak is elsewhere.
[This message has been edited by Patrick (edited 05-09-2016).]
Monkeyman
Total ratings: 182
Report this Post05-10-2016 03:21 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
I noticed a very slight gas leak a couple days ago...
Me, too. Turns out mine was due to too many tacos the night before.
Shho13
Report this Post05-10-2016 07:17 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check the o ring on the cold start injector?
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Report this Post05-10-2016 09:44 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
An 87 Fiero should not have fuel in the charcoal...more likely is rusty lines under the battery.
Riddick85
Report this Post05-10-2016 07:25 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Something else that hasn't been mentioned is your fuel fill tube could be rusty. I had to cut a section of mine out and replace it with rubber fuel hose. Kinda hard to see since it snakes trough the car. Try to narrow it down to passenger side or driver.
