I need some help with the grooved idler pulley for the supercharger. The pulley is not symmetrical. One side has a larger lip then the other side. How is it supposed to be installed?
![](https://images.fiero.nl/2015/Sc_Pulley_1.jpg)
I did not dissemble the donor motor so I don't know how it came apart. When I assembled it I put the larger lip to the engine, because I had not noticed any difference. I ask because the belt occasionally jumps to the outside on the crank pulley. I removed the pulley to see if there was something behind the pulley and found the difference. I flipped the pulley and put the larger lip away for the motor. I am just wondering which is the right way. Time to drive it a few hundred miles to see if there is a difference.
Thanks
88 GT 5 Speed Black with gray interior
3800 SCII Swap Complete.
Paint Complete
Detailing in Progress
IT RUNS!!
IT'S QUICK!!
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
