| quote | Originally posted by deanearl:
Patrick, do you suggest to re-torque things once they have been driven a little bit or just after it has been set back down on suspension?
I should make it absolutely clear that in the case of my Formula, the trailing arm to knuckle bolt
didn't work its way loose. There were three of us working on the car getting it put back together after tipping the cradle to replace the clutch (among other things). It was ultimately
my responsibility to double-check everything... but somehow that one one bolt got missed.
To answer your question (not that I'm any expert), I don't think it would be necessary to re-torque any of these suspension fasteners after a short bit of driving
as long as they've been torqued correctly in the first place.
