No leaking outside then injector(s), regulator, and/or fuel pump have problems.
Possible line inside the tank is bad but most times you can't start the engine for low pressure.
| quote | Originally posted by Lou6t4gto: The Lines are "Pressurized" so fuel Can leak out, But because tit's under pressure, air can't leak IN |
Plus "Air" is likely boiled fuel.
Many systems will have some to a lot of fumes when you open Pressure Test port on the fuel rail. Very normal but many still can't understand.
1. Gasoline can Boil as low as 100°F w/o Pressurization.
2. Opening test port w/ engine warm to hot in same issue as opening hot coolant system by simply removing the Radiator cap... Hot fuel/coolant will instantly boil and flash you w/ fumes/steam.
Even Duke w/ test adapter could see same depending just where the adapter is used. Example: Old Dukes, fuel filter/adapter is on top of the engine bay and area can get warm/hot or just close enough to other hot parts.
