  PAG or esther oil in swap for AC
PAG or esther oil in swap for AC by car54
Started on: 07-15-2016 06:02 AM
Replies: 8 (806 views)
Last post by: larafan on 07-17-2016 09:56 AM
car54
Report this Post07-15-2016 06:02 AM Click Here to See the Profile for car54Send a Private Message to car54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did a 3.8 swap and now I am doing the air conditioning. GM says to only use PAG oil in the compressor but others say to use only esther oil on a conversion . I am getting many conflicting ideas. What have people who have done this swap done and any problems or success that they have had?
Thanks much, car54
larafan
Report this Post07-15-2016 07:53 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 134 conversion uses PAG oil. Which one depends on your compressor. Best results if you pull lines apart and flush the system. Add correct oil to compressor and new dryer and inject the balance before the Freon. Be sure and use new green O rings.
Total ratings: 328
Report this Post07-15-2016 09:40 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have used Ester oil in several R-12 to R-134a conversions and all were successful. You need to open lines blow them out , replace accumulator, orifice tube and use green O rings on any lines that have been opened. On lines left alone and not opened, you can leave the black O rings in place and they will hold. I also believe that with an R-134a conversion, that its a good idea to replace that 28-33 year old compressor with a new one. IMO, you are on borrowed time with a compressor that old.
[This message has been edited by Dennis LaGrua (edited 07-15-2016).]
car54
Report this Post07-15-2016 10:40 AM Click Here to See the Profile for car54Send a Private Message to car54Edit/Delete MessageReply w/QuoteDirect Link to This Post
I probably was not clear enough. I have a 2006 GM compressor that GM says to use PAG oil but I have read many things stating that you should use ester oil with a R12 to a R134 conversion. Will the ester oil cause problems with the GM compressor?
Thanks car54
darbysan
Report this Post07-15-2016 10:58 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
PAG oil and Mineral Oil ( R12 oil) will not mix, and can cause issues. That is why a complete flush is important. However, it's nearly impossible to get all the old mineral oil out of a system, especially the evaporator and condenser. That is where Ester Oil comes in. It will mix with Mineral Oil, and is compatible with R134a. If I was not sure I could get 97%+ of all the mineral oil out of the system, then I would use Ester. That being said, I've always flushed mine to the point that I could use PAG oil. I think either solution will work fine. Well documented on the net.
Whichever one you use, get the one with the Dye. Makes tracing a leak so much easier. Put a few ounces (3) in the compressor, and 3 OZ in the accumulator. Once it is installed and the hoses attached, turn the compressor by hand a few revolutions to distribute the liquid oil out into the line, so you don't hydro-lock the compressor. With the extra long lines in the Fiero, an OZ or 2 more in the condenser is not a bad idea either.
'87 GT in Swap process: '00 3800 Series II SC, 4t65e.
larafan
Report this Post07-15-2016 08:39 PM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I posted in my swap I installed a new GP 3800 compressor and basically converted my Fiero A/C to a 1999 GP A/C. Flushed the system and used the proper PAG 150 oil for that system. If you convert a Fiero A/C and don't flush that is different. But the original oil will not circulate in a 134 system. My new compressor came with 7oz in it.
Total ratings: 328
Report this Post07-15-2016 10:11 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
On Fiero R0134a conversions it is likely that you will have small amounts of 525 mineral oil, and PAG oil left over. (if you use the GTP compressor). Still the R-134a conversions that I have all done with Ester oil have all worked out well . I have no idea why some people must have an R-134a conversion using PAG when a system oil charge with Ester oil works well and will last . It like GM recommends 5w 30 oil in a 3800SC but I use Mobil One 15W-50 oil for greater engine protection.
sardonyx247
Total ratings: 219
Report this Post07-15-2016 11:42 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
PAG is ONLY for 134a from the factory, or EVERYTHING new. PAG and mineral will mix and turn to varnish, you want ester for any kind of conversion.
BTW you can't flush an evaporator, it has parallel tubes and a Reservoir in the bottom that can/will hold old oil and flush, not good.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Now on my 11th Fiero
larafan
Report this Post07-17-2016 09:56 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Obviously if you are not confident in your flush or don't flush you should use esther oil.
